Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
I dented the top of my dryer (Whirlpool Cabrio model number WGD5600XW0) and want to know how to remove top to fix dent.
MOdel WGD5600XW0
    Genius:
  • Whirlpool Master
  • 1,848 Answers
-Here a sample to remove most brand 's top.
-Unplug the power, then remove couple screw on the upper back
-Now use Flat head screw driver wrap the tip with clothe then pry the front that sit on the end up.
Good Luck
Mai
Posted on Nov 14, 2014
zeusfaber
  • 247 Answers
SOURCE: no heat
First port of call is thermal cutouts - little switches that monitor the temperature of the air going into the drum and cut the heat off before it sets your house on fire if something goes wrong and it all starts to get too hot.
Disconnect the power, then open the machine up. Look for the metal duct that directs the hot air into the drum (you'll recognise it by the funny-shaped blower bit at one end, and the collection of terminals sticking out of it at odd places about halfway along).
You'll find that some of those terminals are associated with flat coin or button like objects held tight against the surface of the duct (the number and exact appearance of these objects varies a little from amachine to machine). Look carefully at these, and you'll find that one or two of them have a little reset button in the middle of them. Check again that the power is off, then give each of these buttons a gentle prod. With a bit of luck, one of them will make a sharp clicking sound - you have just reset a tripped thermal cutout.
Check whether this has worked by running the machine. If it has, then you need to find out what made it overheat in the first place and stop it happening again. This usually just means giving all the filters and ducts a thorough clean to remove lint that's restricting the airflow.
If the thermal cutouts aren't to blame, then the next suspect is the heating element. Diagnosing this is a bit more involved, though still managable as a DIY job. Check the cutouts first, then come back if you need help checking the element.
A.
Posted on Feb 24, 2008
projdoc
  • 2236 Answers
SOURCE: Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
Posted on Jul 24, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
  • 4 Answers
SOURCE: Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Posted on Apr 17, 2010
  • 523 Answers
SOURCE: Whirlpool cabrio gas dryer does not turn gas on to
first change the ignightor if its a glow plug
Posted on Jul 01, 2010
How to remove top on dryer
Hey friend, I appreciate your post!
I understand that you are trying to remove the top from your Electrolux dryer. Could you provide me the model number please? With that information I can better assist you. You can locate your serial tag (which lists your model number) on the inside of the door. I look forward to better assisting you. -Matt
Aug 02, 2014 | Electrolux Dryers
Electrolux dryer model EIED55HBM0 dented on top and is now grinding when it runs. How do I take the covering off to push out dent?
There are two clips, one on each side that are between the top and the front piece of the machine. Take a flat screwdriver and press each clip in and the top should just lift up
Jun 03, 2012 | Electrolux Dryers
My whirlpool duet dryer is working but is very loud like there is loose change in it. It is also banging at the top and has left a dent in it.
Maybe you can take off the cover, one of the rollers is either off or broken..best thing is to replace both rollers. When cover is off gently push dent out make sure dent doesn't reoccur. Hope this helps. PS..Never put anything heavy on top.
Feb 28, 2012 | Whirlpool Dryers
Hello - I have a Kenmore 62942 dryer that making noise because the top is slightly dented. Does anyone know if you can open the top in order to work on the inside of the dryer?
Newere dryers than this simply remove a few screws from the back and lift the top off.
Jan 24, 2011 | Dryers
Dented top on kenmore ge3 dryer
Yes it is, remove the 4 set screws and top comes off.
Apr 28, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
The top of our whirlpool duet 8300 dryer just got dented and is now making noises. You can see the drum rubbing and making the top bounce. Any ideas on where to start so I can get access to the underside...
The shell must be removed from the unit to service.
There are 2 screws in each rear corner.
Remove them - then slightly pull the front forward to disengage the clips.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Cannot find the model number on my Whirlpool washing machine. It is a top loading machine, with such features as: 4 Load size, 4 Tempature settings, 8 cycles, 4 speed combinations, commercial quality....
If this was a scratch and dent model, model number may have been removed prior to sale. If not, you should find it on the back edge of the washer at the very top as you look over the back of the machine. If you can't find a model number, bring the part(s) you need to a servicer. They may be common parts or there may be some identifying numbers on the parts themselves. Good luck.
Sep 01, 2008 | Whirlpool Washing Machines
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
120 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
