Question about Lands Phones
There's no dial tone -- what do I do to fix this?
I can receive calls, but cannot make calls or check voice mail
    Master:
  • 623 Answers
It's possible the "tip" and "ring" are reversed, sometimes that'll block dial-tone. Try another jumper between your wall jack and the phone. You should also try a different phone plugged into that jack to make sure it's ok.
Posted on Nov 14, 2014
  • 84 Answers
SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Posted on Feb 13, 2008
SOURCE: RCA Model 25204 2 line speakerphone corded with call waiting caller ID
As bsmither said, how voice mail is accessed is very dependent on your phone company and how they've set things up. They would be the best place to ask about any problems you're having there.
As for programming the voice mail buttons on the 25204, I was confused by that one as well until I finally figured it out. Specializations aside, they're just speed dial buttons, and are programmed in exactly the same way as the ones along the right side of the phone. RCA could have documented that detail better than they did.
In my case, with Vonage, I just programmed the buttons with the numbers for the lines that they're associated with. When they dial and I'm connected to the voice mail system, I'm prompted for my VM password, which I then enter manually.
Posted on Jul 29, 2008
SOURCE: voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Posted on Oct 03, 2008
consultel1
  • 860 Answers
SOURCE: My phone says check Tel Line
Sounds like your telephone line might be dead. If you have a gray or tan telephone box on the outside of your house you can plug your phone in there to test the line. If you get dialtone then thrers a problem in your house wiring, if you don't get dial tone then the line is dead and you need to conact your telco provider.
Posted on Apr 14, 2010
SOURCE: No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
Posted on Feb 05, 2011
Why does dial tone go beep beep beep?
It is called a stutter dial tone and usually means that you have messages on you voice mail.... But its is sounding like a motor boat, and sounds like your in a tunnel while talking. You may need to call your local repair. Could be a bad line card.. as long as its happening on all your phones..
Aug 15, 2015 | Lands Phones
Toshiba dkt 2010-sd voice mail doesn't answer
To help you I would need to know what type of Toshiba main cabinet you have. If you have a CTX or CIX it may be that your system call forward is turned off. If you dial #620 at the extension in trouble it will turn the system call forward on. #621 turns it off. The proper sequence for "No Answer Call Forward" is Press ext. button + #6031 (tone) + dial main ext for voice mail + timer (08~60)
(tone) . #6051 removes this type of forwarding.
Mar 12, 2014 | Toshiba Strata DKT-2010-SD Digital Display...
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
Mar 31, 2013 | ZTE Mf190 Unlocked 3g Gsm 7.2 Mbps...
Tryna check my voice mail but my dial pad ain't
Make sure your phone is turned to "Tone Mode". When the call is on press # and then try to use your dial pad. I hope it helps you out :)
Mar 16, 2012 | Samsung Cell Phones
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
I can't get a dial tone on my phone and can't check the messages because of it
Not exactly true. You can check your mail from anywhere if you know where the Voice Mail extension is, or call in from remote and while the greeting plays dial #6 * (your ext) wait, then put in the Password and # when prompted.
Ooh, your mailbox. Now work on fixing the phone.
Carl
Jul 05, 2009 | Panasonic KX-T7630 Corded Phone
How can I access my voice mail?
Usually you press and hold #1 and it will call your voice mail or dial your own phone number and press # or * during your voice mail msg
Jul 04, 2009 | Motorola Mobility W510 Mobile Phone
Calls go straight to voicemail
Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
Dec 11, 2008 | Toshiba DKT-2020 Corded Phone
Voicemail
Press and hold the "Mute" or "Clear" button until the handset beeps to clear the New Voice Mail allert.
Jul 04, 2008 | Panasonic KX-TG1033S Cordless Phone
Voice mail
Do your Dial tone sound different. Your phone listens to the dial tone. if you have a new voice mail your dial tone changes.and your phone does the flashy thing accordingly. Contact your phone company.
Aug 18, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
Lands Phones Logo
50 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
