Done timing belt of 99 grandeur and now wont start. need help please and if anyone got a pic pleas.
SOURCE: 2003 focus timing belt replacement
Firstly if the belt went you probably have bent valves. However if you want to assemble and see remove cam belt covers,remove crank pulley (could be tricky if you don't have an air tool ) remove tappet cover ( you may have to remove the throttle body to do this) Get some flat bar approx. 6mm thick and 400 to 500 mm long. You will see that on the gearbox side of the cams there are slots in the end. Remove the plugs and put a screw driver ( long ) down the hole, any one, and turn the crank untill the piston is roughly half way down the bore. Turn the cams until the plate will sit on the head and slot into the cams thus locking them. The slots are offset so you will have to play around until the plate slides in easy. Then loosen the cam gears untill you can spin them by hand, but not so loose that they are falling off. Put your long screwdriver or preferably a dial guage with extensions into no 1 plug hole turn the engine untill the piston is right at the top. Loosen the tensioner and push it back against the spring and lock it fit the new belt right to left then let the tensioner go. Check play on longest side of belt it should move about 6mm. lock the tensioner. Tighten the cam pulleys and remove plate. turn the engine one full turn clockwise and check belt tension- adjust if neccessary. turn one full turn again and make sue plate slides in when no. 1 piston is on top. Then do a compression test to see if you have bent valves. If the compression test is ok. reassemble and drive away. If not (the exhaust valves are normally bent) you are half way to taking the head off. In which case contact me and I will walk you through it. Good luck Shaun
SOURCE: 99 ford ranger timing belt
Using the same 13mm socket, remove the bolt that you found under the
a/c compressor. Look down and to the right of the bolt that you just
removed, and you will see two more bolts. Both are 13mm. Easiest way
that I found was to go under the driver side tire well, and use 3/8
extensions to reach the two bolts. Once removed, the bracket and the
power steering pump should be moved to the driver's side of the frame,
and the a/c placed on top of the p/s assy.
Remove the bolts (6mm) that hold the timing belt cover in place.
Gently work your way around the cover, and push the tabs in to remove
the cover.
Use an impact wrench and 7/8 SAE socket to remove the crankshaft
pulley. A SOCKET WRENCH WILL NOT WORK. Once removed, gently tap the
pulley with a 2x4 (yes the wooden board) to remove. If you have a gear
puller, use that. I don't own one.
Remove the old belt. Now for the alignment. Crank - sprocket on
bottom. Use the bolt you removed, and a ½ drive wrench, with the 7/8
socket to turn the crank. Once the keyway is at high noon, leave it
alone. Next, move the oil pulley sprocket until the diamonds are
aligned. This should put the oil pulley at high noon, also. The
camshaft should have a diamond and a triangle. The diamond should go to
high noon, and the triangle should align with a triangle on the plastic
behind the sprocket. YOU SHOULD REALLY CONSIDER CLEANING THE ENTIRE
AREA BEFORE ALIGNING THE SPROCKETS. You cannot align the camshaft
without locating the two index (triangle and diamond) marks.
You will also notice a tensioner for the timing belt. You will
need to loosen the tentioner with a 13mm and 17mm wrenches. Loosen,
then use a cheeter bar bar to move the tentioner over. Lock in place by
tightening the tentioner bolts. Place the belt on the crankshaft, move
to the oil pulley, then to the cam pulley. Release tentioner, then
check the alignment. If correct, reverse the above removal plan, and
you should be good.
Don't buy the Haynes manual. I fought with the instructions for this
project, and the picture for the timing belt project doesn't show the
two indexes for the cam sprocket.
Also, while you are doing this, you should replace the antifreeze if you haven't in the past two years.
Best of luck.
SOURCE: 2002 Toyota solar timing belt
Chilton or Haynes manual will have all the pics you can stand on this, they can be bought at most auto parts stores, also check your local library they will surprise you with how many repair manuals they have
SOURCE: need to install belt
i made this with paint. hope it helps. typically on a bmw the belt goes between the water pump and crank pulley to the tensioner; if this is a 99 to 06 ish 3 series and some 5 s you will be good
SOURCE: Timing belt replacement for 2002 hyundai sonata
this is a job for a qualified repair shop. I do not recommend you to do it. If you want to do it, buy a manual, prefer a manual from the dealer. The money you save will more than pay for it.
Welcome to FIxYa.com
Need the year and model and size as in liter engine in order to look this up for you to send pic and info. Engine number does not work in Alldata, Lee
Thank you for using FixYa.com
Regards, Lee Davidian
