Question about Breville Fresca BES860 2Cup Coffee Maker
Water leaking My breville fresca is leaking water from under the tand and also from the bottom of the machine. I have purchased a new tank to eliminate this possibility, but it is still leaking. Any ideas what could be causing this and how I could fix it? Thanks!
    Problem Solver:
  • 9 Answers
The hose going from the tank to the spout may have a split or not be seated correctly. Check that.
Posted on Nov 14, 2014
5 Suggested Answers
mirran
  • 515 Answers
SOURCE: Water leaking out of the tank
i think you have to replace the gasket where the water tank fits, it´s very tight there, you have to take off the bottom from the machine then you will see two screw, loosen this.
Now can you put down your hand in the hole and take of the plastic above the gasket.
Hope this will help you.
/Mirran
Posted on Aug 15, 2008
  • 18 Answers
SOURCE: A lake of water
anyone else w/ this problem: cheap workmanship = cheap, malfunctioning machine. turn it upside down, unscrew the 4 screws w/ metal washers and the six screws with out washers from the base of the housing. once removed, you can see that cheap metal clamps are used around the plastic hoses which supply water from resevoir to steamer & brewhead via the pump. either length of hose above pump or below pump has come loose or pump is fauly or there is a hole in a tube. good luck!
Posted on Jan 11, 2009
  • 232 Answers
SOURCE: Where can I purchase a water filter for the
From either Breville or try ebay.
Posted on Jul 29, 2011
  • 232 Answers
SOURCE: Does anyone know about the
There should not be a problem, it has moulded holders built in to both the back of the machine and in to the reservoir. They fit together, not just against each other. Once fitted together it locks securely, do not overfill it and do not fill it while on the machine. That will cause it to spill.
Posted on Jul 31, 2011
Water is leaking from my Breville Barista Express Espresso machine's water tank valve.
u r is the 4th problem with the same unit. take it bak to the store and git another 1.
Feb 23, 2015 | Breville The Barista Express BES860XL Open...
Replace water tank seal
Just had this replaced by a electronics repairer. There are two screws needed to be removed to take the top off first. One under the tamper, the other near the steam wand. Once they're out (and after removing the 6 out of the back) apparently you can take the back off to replace the water seal :)
Jul 11, 2013 | Breville Fresca BES860 2Cup Coffee Maker
I purchased a Fresca FTL2336 Apus One-Piece toilet and installed it. I can hear a constant drip of water escaping from the tank causing the toilet to refill every few hours. I have lifted the flapper,...
The flapper may be defective or not seating completely which causes a continuing slow leak until the tank level drops low enough to cause the flush valve to refill it. I find a cheap flapper lasts just as long as more expensive ones and lasts about as long. Arbitrary replacement of the flapper is a regular periodic maintenance item
Feb 16, 2013 | Fresca FTL2336 Apus One-Piece Square...
I have a Breville Fresca BES860 2Cup Coffee Maker and I've lost my manual. The Clean light is on and I can't remember what to press to start the clean process on my machine. Can you please...
Turn your machine off, then push and hold the 1 and 2 cup buttons and then while still holding them push and hold the power button. Wait until the clean cycle begins.
Sep 07, 2011 | Breville Fresca BES860 2Cup Coffee Maker
No steam no hot water
Do you have enough water in the tank? Is the filter secured in the tank?
Move the steam dial from standby to steam and wait about 20-30 seconds, should steam if it doesn't most likely faulty.
Jun 14, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Does anyone know about the issue with the water holder on the Breville Fresca BES860. It wont sit in place correctly and spills water all through the machine...
Oct 17, 2010 | Breville Fresca BES860 2Cup Coffee Maker
/Mirran
Aug 15, 2008 | Breville ESP8XL Espresso Machine
Breville Fresca BES860 2Cup Coffee Maker Logo
262 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
