Question about Home
How do I remove a light knob - Home
    Sergeant:
  • 192 Answers
Send a picture of model and make please.
Posted on Feb 20, 2015
How do i re start the pilot lght
You will need:
a wire hanger or something like that about 14 in long
a small clip and matches to clip to wire.
Turn red knob to off
remove small door covers (Both).
look inside you will see a tube pointing up this is where you put the match to light it.
turn red knob to pilot and push down and hold
light match and put it at end of the tube inside it will light a blue flame
remove match.
all this time holding knob pushed down
continue to hold down for 60 sec
then let it up slowly and turn knob to on
should flame up and start whole burner
replace door your done.
OR call your gas company most will light it for free
Jan 17, 2016 | Water Heaters
On my ford freestyle gear indicator light how change it
Remove the PRNDL trim ring.
Remove the upper console panel.
Slide the lower shift knob bezel downward.
  1. Remove the bolt and lift up on the shift knob to remove.
Remove the lower shift knob bezel.
Disconnect the light bulb from the PRNDL bezel. an replace .
26002487-w0jffanovav232xjqcbliw5g-1-0.gif Don't think you need take shifter knob off . Just PRNDL trim plate an upper console plate . They should just pull up , use plastic trim tool to get it so you can get your fingers under an pull up carefully .
26002487-w0jffanovav232xjqcbliw5g-1-2.gif PRNDL trim plate
26002487-w0jffanovav232xjqcbliw5g-1-5.gif Light blub connector !
Dec 11, 2015 | 2006 Ford Freestyle
Remove light knob on 1960 valiant
The knob does not come off, the whole knob/ shaft comes out.
Remove the battery ground, and pull the switch all the way out.
Reach up under and feel for "the button", push it in and pull the shaft out.
Nov 14, 2014 | Cars & Trucks
How to see headlight switch 98 f150
Hear is how you remove the old ford switch assemblys, there is a spring loaded latch keeping it secure to the trim panel, follow these instructions:
To remove the headlight switch:
1. Turn the headlights to on and pull the knob out like are turning on the fog lights.
2.Then look at the bottom of the knob, you should see a very small opening.
3. Insert a very thin tool like a mini screwdriver into this opening, and that should push in a tang and release the knob.
4. Rotate the knob 180 degrees and reinstall it. The bottom of the knob should now be pointing at the headlights on position
5. Now, turn the knob counter-clockwise like you're turning the lights off and push the knob making sure it is seated.
6. Turn the knob back to the headlights on position. This is what releases the tab and the entire switch assembly from the dash.
7. Pull the assembly to remove it.
Jul 10, 2014 | Ford Vehicle Parts & Accessories
No lighting on my climate control knobs. how do I replace the light bulbs?
General advise:Before removing anything check the fuses.For reacing the bulb:Must pull off the panel,remove the knobs by gently force them out,under must have some screw/clips to allow remove the panel.The panel may need help to pop from sides,don't force it,use plastic card/tool.Exersize on a old radio removing the control knobs.Some cars u have to unscrew the down side usually the ashtray.The bulb may be hard to identify,exersize removing bulbs on a wasted dashboard from a car/scooter...
Oct 22, 2013 | 2005 Kia Optima
How do i remove just the knob?
The wiper knob has a clip you release, and the headlight knob comes out of the switch with the rod attached. There is a button on the headlight switch you press to release the knob and rod together.
Oct 04, 2012 | 1985 Ford F150
Bulb out in center console
You are correct, there is a bulb light lights only the center console...you will need to pull up on the shifter in order to gain access to the bulb...you don't always have to remove the shift knob to gain access to the bulb holder...if you need to remove the knob...pull the shift lever all the way down to low gear...this should best expose the rear of the knob...you should see a u clip that needs to be removed...(needle nose pliers) in order to lift the knob off...to reinstall just put the knob back in place...the u clip must be re-installed to hold the knob on...Hope this helps.
Feb 28, 2011 | 2001 Oldsmobile Aurora
Cannot get the windshield wiper and light knobs off in order to remove the cover. They do not just pull off?
For everyone's future reference, the windshield wiper knob has a spring metal clip holding the knob to the shaft.
There is a small slot under the knob. Starting at the back edge of the knob, use a small screwdriver to push into that slot in the same direction you want to remove the knob.
That will push the metal clip and release the knob.
Nov 29, 2010 | 1981 Ford F 150
1993 f-150 headlight switch removal? Take dash apart or is there a better way? No access to the switch from under dash.
the pull switch for the hed lights snaps in place, if you pull out to turn the lights on and turn the knob as to dim the lights you'll see a notch in the knob. with a small screw driver or pick tool you can lift a metal tab and remove the knob, then remove to two trim pieces left and right of the steering wheel and there will be two 1/4 in nut drive screws, remove those and the gage cluster dash trim can be pulled right off exposing the head light switch
Jan 01, 2010 | 1993 Ford F150 SuperCab
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
