Adjusting Base - Audio Players & Recorders
    Problem Solver:
  • 10 Answers
Turn volume 3/4 high with base and treble down. Slowly turn base up to preferred strength. Then do Tue same with treble.
Posted on Nov 28, 2014
How do I adjust idle speed?
You can't adjust the idle , There is a minimum idle adjustment set at the factory , you don't want to mess with that . The PCM / ECM ,engine computer controls the idle speed by the idle air control valve (motor) . You may have a dirty throttle plate mess with the base idle .Check out this video on ford base idle adjustment . Some one who didn't know cranked up the base idle causing problems Ford IAC valve test how to adjust minimum idle speed
Dec 19, 2015 | 1996 Ford Contour
How to adjust the base sound ?
If there is no Volume Up/Down (+/-) button on the base or on the remote, then you have to adjust the volume on the audio source (in this case, the TV).
Oct 16, 2014 | Samsung WAM-750 Wireless Audio Speaker
Installing a reflexion 7 base
Problem with Stearns and Foster Stearns & Foster Reflexion 7 Adjustable Power Base
Dec 07, 2013 | Stearns and Foster Stearns & Foster...
How to adjust universal mount for the xtc-205 camera
Hey man I was having the same problem I figured out that its velcrowed on just keep pulling hard and it will seperate
Aug 14, 2012 | Cell Phones
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Accidently moved timing base plate whil trying to adjust points now bike refuses to statr how do I reset without adjusting the timing by wat of the timing chain
moving the base plate is how you adjust points. sometimes there is marks/scratches where the screws were tightend onto the base plate. try to line them up with the screw head.
Dec 22, 2009 | 1975 kawasaki Z1B
The base ringer on my Uniden TRU9480 base station rings very loud and cannot find where to either adjust or discontinue the ringer. Jackgee1
I found my owners manual and to adjust the ringer on either the Base Station or Hand Set as follows:
with the hand set in place just use the base arrow up or down to go from 0 (off) to 2 (loud) and on the hand set just use the arrows for high low or off. Just bew sure to have the hand set on the base before adjusting the ringer
jackgee1
May 01, 2009 | Uniden 2.4 GHz Cordless Phone System
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Apr 13, 2009 | Dewalt Tools & Hardware - Others
Car Seat Belt keeps getting stuck
check the adjustable strap then check the spring of the strap .
Feb 02, 2009 | Graco Quattro Tour Travel System
53 people viewed this question
 Grubhead
Grubhead
