Question about Bose Av321 Series I Media Center For A 321 Home Theater System-works Perfect
My video 1&2 stopped working, everything else is working
Just stopped working after unit was accidentally left on about for 24 hr. Shut the unit off. The next time I turn on TV the video 1&2 work the unit stopped. I shut it off and the next day tested the unit again. The video1&2 program will not work the wires were never touched. The DVDs, radio work, just won't transmit the TV on video 1&2.just dead
    Habit-Forming:
  • 166 Answers
Check for faulty capacitors inside unit
Posted on Dec 01, 2014
4 Suggested Answers
Siliconchip
  • 52 Answers
SOURCE: dvd door stuck shut on my BOSE 321 home sys
Try to unplug the whole system from any power source for 2 minutes to reset. Hope it will help.
Good Luck.
Posted on Jan 03, 2008
petraman7
  • 1175 Answers
SOURCE: 321System No sound just humming with TV connected to Video1 or 2
Hi...
Get new audio cables . It seems there's a broken Ground (shield ) wire somewhere in the cable. NO ground means HUM usually
Posted on Jan 15, 2009
SOURCE: my AV3-2-1 Bose system wont
try open the unit and resolder all dry joints
Posted on Jul 29, 2011
I conected my sub wrong and the unit shut down , I reconected my sub and everything seems to work fine , should I send it in for servicing?
If i'm right, the system powers down as a safety precaution. It prevented itself that it will breakdown. It's your choice but I recon you can just enjoy and listen to your favourite music.
Apr 26, 2014 | Harman Kardon AVR 7000
Change 12 to 24 hr & date
Hi bobwesley,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 17, 2010 | Timex 1440 Nylon watch
I have a bell f20 bicycle program...i have been trying to set the time...can someone tell me how to set the time without erasing everything on the program...
Click on the right side of the red button until you reach the clock (after SCAN). Hold down the left side of the red button until you see "12 HR" click--choose "12 HR" or "24 HR" (24 HR is military time). Click on the right side of the button to select the hour and change with the left side to change the hour. Click the right side of the button to change the minutes. Finally, click the left side of the button to move away from the clock. Other settings are intact.
Nov 15, 2010 | Cycling
I have an old unit approx.11yrs old.When turn on for heat,kicks my breakers off. It runs for about 1/2 hr. before shutting off. Tried running the emergency heat bu t, it continues to kick the breakers off...
Well, obviously your furnace is overloading the breaker it is on. Try this, turn off the breaker that the furnace is on and go through your house to make sure everything else still works. Furnaces are large power users and should preferably be on their own breaker/breakers. If everything still works then have someone you trust check the connections at your breaker box. I have had the same issue where after approximately a half hour or so my furnace would kick off.
Upon further inspection of the breaker noticed a loose connection that apparently was causing an arc and tripping the breaker. After it was tightened down I stopped having the problem period.
Jan 09, 2010 | Amana Heating & Cooling
Just installed a T101. Unit will not switch to on position works perfectly to off position. Can it be adjusted.
Yes.
Programming Instructions for the Intermatic T101 - 24 Hr. Dial Time Switch:
1. TO SET ON AND OFF TIMES: Hold trippers agains edge of clock-dial, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A.
2. TO SET TIME-OF-DAY: Pull CLOCK-DIAL outward. Turn in either direction and align the exact time-of-day on the CLOCK-DIAL (the time now, when switch is being put into operation) to the pointer. DO NOT MOVE POINTER.
Operating Instructions:
* To operate switch manually: move manual lever below clock-dial left or right as indicate by arrows (graphics) This will not efect next operation.
* In case of power failure, reset clock-dial to proper time-of-day. See Programing Instructions (top lines).
Good luck (reemmber rated this help).
Oct 23, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Change Clock - Logitech Pure-Fi Elite
hold the src button left of power along with button to the right power.a model number will appear once it does let it disappear and the unit will go into reset. set the language, 12/hr, 24hr etc and the time. :)
Dec 13, 2008 | Logitech Pure-Fi Elite High Performance...
Aquatech watch
press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
hope this helps
jeff
Jul 23, 2008 | Watches
Setting model number jr3060-59f
1. set mode to CHR with the bezel fully in.
2. pull bezel out 2 notches. This will set all (or most) hands to 12.
3.press A (top button) repeatedly until you get MIN in the left window
4.turn the bezel to move the min hand forward.
4a. turn the bezel several clicks in quick sucession to get the minute hand to continue to move in the forward direction. This will "drag" the 24 hr UTC hour hand froward 1 hour per 1 revolution of the minute hand. if the minute hand stops before you want it to repeat step 4a. continue till the 24 hr UTC hour hand points to 24.
5. to stop the minute hand turn the bezel backwards 1 click. remember however to approach the 12 position with the minute hand in a clockwise direction.
Mar 25, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Timex Mid Size Sports 1440 WR50M
If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
Than follow these steps:
1. Press Lap/Reset and hold. You should see the time the alarm was set for.
2. While holding Lap/Reset, press Mode.
3. Let go of all buttons.
4. There you go!
Hope that was a help
Mar 11, 2008 | Timex 1440 Nylon watch
Ice cubes coming out with silver (grey) paint specs on them
Do you know exactly what part he changed? It sounds as though it was some sort of water flow regulator, or valve. The service person should have flushed the system prior to installing the part, and replaced the filter.
Without knowing exactly what he changed, it's hard to tell.
Ive heard horror stories where the techs replace ice maker units, and accidentally put the OLD water source filter on backwards instead of replacing the filter, and all of the contaminants end up in the new unit, and in the ice / cold water.
Feb 07, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Bose Av321 Series I Media Center For A 321 Home Theater System-works Perfect Logo
98 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
