Question about Microwave Ovens
Where can I get a specification sheet for a kenmore microwave model # 721.64683300
    Master:
  • 623 Answers
Go on to the Sears/Kenmore web site, or contact their service center. They keep very good files and data going back years and years.
Posted on Nov 14, 2014
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: NEED SPEC. SHEET.
Head over to the manufacture's website.
www.searspartsdirect.com
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
  • 32 Answers
SOURCE: My Microwave is arcing due
Hello.
Yes you can buy mica sheets made for microwaves at appliance repair/parts shops.Scissors work well for this. A razor knife might be needed for notches etc. If so, several shallow cuts work better than trying for one deep one, as your not as apt to slip. I usually put the leftover material in a plastic bag and tape it to the bottom of the unit so I could find it the next time.
Hope this helps you.
fil
Posted on Mar 06, 2011
Kenmore microwave model 721
You can order just the pad. It peels off like a sheet of paper. Sometimes i put a totally different control panel on. I save as many parts from microwaves that are thrown out as possible
Oct 20, 2013 | Microwave Ovens
Kenmore modle 721.80042700
It may be a blown fuse or a bad thermostat / TCO on the oven cavity or above or on the microwave.
Yours should have a "mini-manual" (technical sheet) hidden either behind the grille or control panel. It is very helpful in locating and testing components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kenmore manuals and installation instructions at http://www.managemylife.com by clicking the Manuals link near the top center of the page. Then enter your full model number from the tag on the oven on the next page.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You can order parts and find helpful exploded views at the Sears Parts Direct Web site .
May 03, 2013 | Kenmore 62622 Microwave Oven
My Microwave is arcing due to its demaged Mica sheet. Can I replace it with any other ordinary Mica sheet cut to its original size & fit in its place? Will it work? Or are there special Mica sheets...
Hello.
fil
Mar 06, 2011 | Microwave Ovens
Kenmore microwave model 665.69682992. I am attempting to replace the door on this model. I ordered the new door but find that the hinges are installed in the new door and cannot figure how to get the new...
I am looking to replace my Kenmore model 665.61612100 combination microwave with an updated model of the same size and specifications. Any suggestions???
Sep 08, 2010 | Kenmore 62622 Microwave Oven
NEED SPEC. SHEET.
Dec 21, 2009 | Kenmore 66469 / 66462 / 66464 Microwave...
F9 code on mod 721-80869400 kenmore elite
This is usually inverter trouble, but it may be the magnetron, controller, wiring, etc.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
May 17, 2009 | Kenmore 63792 Microwave Oven
Kenmore 1200 watt sparking when warming empty plates
Unless specifically stated in the manual, you shouldn't use the microwave for warming plates. That is not it's intended use.
I suspect the microwave circuit has failed in some manner.
Reply the specific Sears model number (in the form xxx.yyyyyyyy), and I can help further.
Jan 23, 2009 | Kenmore 63252 Microwave Oven
No power at all
You probably blew the fuse in the microwave.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
There may also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 22, 2008 | Kenmore 63792 Microwave Oven
Kenmore microwave
If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board. If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically. If you repost with your exact model number (62622 is not a complete model number) then we can advise you further and more specifically.
Nov 22, 2006 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
