Question about Whirlpool LTG5243D Top Load Stacked Washer / Dryer
Stacked washing machine dryer
The barrel in my washing machine has tilted and when it begins to fill all the water runs out.
  • 5911 Answers
SOURCE: Washing Machine
Do you have the hose inserted too far down in the drain standpipe? If so, you may have created a situation called "siphoning". You need to have an air gap so the hose will drain properly, and doesn't drain when you don't need it to. If the hose is resting in the trap area of the drain, it stays submerged in water and will siphon the water from the washer as it fills. Another situation that occurs is when consumers try to seal the top of the standpipe to keep odors from coming back up through the drain and/or to prevent overflows. This can also cause siphoning. Just some things to consider. Double check your drain hose and let me know if this helps you.
Posted on Aug 02, 2007
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
  • 750 Answers
SOURCE: water running out when washing machine is filling?
Hi jojolevaokah
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
Posted on Apr 07, 2009
  • 4 Answers
SOURCE: Leak coming from the bottom of my washing machine
you probably have a tear in the bellow. cost to replace a few hundred dollars.
Posted on Jun 09, 2009
  • 464 Answers
SOURCE: Washing machine fills with water, but won't begin
Sounds like you may have a bad lid switch and won't acitivate the machine.
Posted on Jan 24, 2010
  • 1531 Answers
SOURCE: Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Posted on Jan 31, 2010
0 characters
1 Points
It won't fill . the water on. the dryer works but no power going to the wash machine??
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Jun 21, 2011 | Frigidaire FLEB8200DS Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
LSE7806A stack: the wash fills to the water level/load size selected. it starts to agitate then stops and begins to fill with water again which causes overflow, help please
Your fill sensor is leaking and allowing air pressure from the clear tube to seep out. First make sure your clear tube from the tub to the water level valve is firmly connected. If it is then you may need to get a new water level adjuster switch.
Mar 09, 2010 | Maytag LSE7806A Top Load Stacked...
Washer fills up with water but will not begin the wash cycle
check the timer,it controls all parts of the wash cycle(wash,spin,rince,spin),try getting a used one at an appliance repair store. hope this helps!!!!!!!!!
Sep 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer not working.
Renee, after you hit your wash cycle selection does the washer begin to fill with water and rotate the wash basket? I need to know what does work , it will tell me what does not. capnhook
Oct 01, 2008 | Maytag LSE7806A Top Load Stacked...
Washer won't start water fill/ the dryer works fine
I'm Neil, Glad to be of assistance for you!
Sounds like an Electronic problem.
You should call service.
Try :
A&E Factory Service
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Aug 24, 2008 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool LTG5243D Top Load Stacked Washer / Dryer Logo
22 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
