Question about Electronics - Others
How can i switch a memory card from read only to open
I have bought an unbranded memory card and it is saying it is full but when I go to format it, it says that it is protected by read only and I cant change it
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
You didn't specify the type of memory card so I'm assuming it's a Secure Digital card.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Nov 14, 2014
SOURCE: cell memory card problem
try reading it through a card reader on pc, if it still has the same problem, then the data has somehow become corrupt and you will need to format
Posted on Oct 23, 2008
SOURCE: cant format
you can remove the write protection status by inserting it to your camera and in the preview mode click the button menu, in that scroll down for options and you can see there the option for protection on or off. toggle that option.thanks for using fixya!. please dont forget to rate my solution.
Posted on May 28, 2009
  • 240 Answers
SOURCE: unable to format
of the card is a little switch-its tiny-you can just see it on the photo above this solution. If you slide it the other way then write protected will be off.
Posted on Jun 14, 2009
steve_e_uk
  • 1675 Answers
SOURCE: cannot delete in transcend micro sd 2gb memory card.
hi if you look on one side of the disk you will see a little white switch ( very small ) move this in the opposite direction of where it is and that should sort you out....hope this helps please vote thanks
Posted on Mar 24, 2010
  • 44 Answers
SOURCE: i cant format 2 gb sandisk memory card in my pc,
I would suggest that you have a corrupted inaccessible memory card. Your card is damaged and won't function properly.
Posted on May 29, 2010
Scanner says "full"
Try formatting the SD card before taking photos. Use the camera Menu and select format memory card.
Feb 12, 2013 | Cameras
When i plug in the memory card computert says to format the memory card but it is unable to format it
You have to be the computers administrator to change any values on any hard drive on your computer. Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP Click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start click on my computer you should see your usb drive right click then select format another way is to control panel administrative tools computer management disk management right click on your drive select format
Hope this helps.
Jan 10, 2013 | SanDisk 2GB microSD Memory Card
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
Just bought a 4gb memory card for my cannon eosi rebel - camera says it cannot read the card - does it need to be formatted?
Yes most new cards need to be formatted before they can be read.
If you are having the same issue after formatting, then replace the memory card.
Jul 15, 2011 | SanDisk 4GB microSDHC Memory Card
I can only take 5 pictures with this camera before it says that the card is full. i have already changed the card twice is there something wrong with the camera or the card
This sounds like a problem with the memory card.
Your camera has 19MB of internal memory (used to take test photos in the shop usually) which is what the camera is using here.
You may need to format the memory card before use, assuming it is inserted into the camera correctly.
I have linked to the camera's instructions (PDF Format). Follow the details on page 30 describing how to format your memory card. Please also read through the set up at the beginning to ensure the card is inserted correctly. Thanks
Dec 24, 2009 | Olympus FE-46 Digital Camera
4gb memory card but when songs are bluetoothed sayes mem full
Hi there
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Feb 23, 2009 | LG KS20 Smartphone
    Memory card
  • Jul 03, 2008 | Konica Minolta DiMAGE Xg Digital Camera
    Memory card
    this cam will work up to 2gb sd/mmc
    what's the capacity of your card? if it's above that, it's really not gonna work with this cam
    if your card is 2gb or lower
    2 possibilities:
    defective card - please try another card
    camera memory reading problem - arrange repairs with kodak
    Jan 20, 2008 | Kodak EasyShare C663 Digital Camera
    Bought a new memory card and camera wont read it
  • Apr 20, 2007 | Sharp VE-CG40U Digital Camera
    Electronics - Others Logo
    51 people viewed this question
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
