Question about Drills
<!-- from fixya rte -->I nead crh 240re Ryobi drill charger - Drills
    Master:
  • 623 Answers
Contact your local Lowes or Home Depot. One or the other will be able to get one for you.
Posted on Nov 14, 2014
rowdy45176
  • 2176 Answers
SOURCE: Charger Repair for Ryobi drill 14.4 volt
It has been my experience that when one component of a board goes bad that something else is wrong and even replacing that part still will not work. But you can try contacting Ryobi direct at their website and see if their tech service can get that for you. They are very vague when it comes to some of their products so good luck. Also as a thought if you have a tool repair facility in your area you might contact them and see if they have a junk charger laying around that you can scavenge for parts.
Posted on Dec 31, 2008
glenmann62
  • 91 Answers
SOURCE: Missing fuse in RYOBI CTH1202 Charger.What size fuse .5,1.0 2.0 ?
that would be a 2.5 amp fuse , sincerely glenn
Posted on Mar 06, 2009
SOURCE: Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
Posted on Mar 20, 2009
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
i have the same problem and have returned once for replacement charger and battery, still no working well help andykrin@yahoo.com
thanks
Posted on Mar 26, 2010
  • 8 Answers
SOURCE: I bought the two pack
I would not say they are not defected, but I think they are not getting fully charged. I have the same problem with my battery once I have used it all day and the red light comes on from the fuel gauge. I have the P104 battery. I would return your charger and try to charge them on the new one first. If you have the same trouble, then return the batteries for new ones.
Posted on Nov 29, 2010
I would like a new charger Ryobi bc-1807t charger and 2 batteries. or a repair to my charger
home depot -lowes -most hardware stores--go online to buy the replacement for repair do a search for tool repair store in your area but might be cheaper to do replacement
Sep 09, 2016 | Ryobi Drills
Is there 2 type of battery chargers for ryobi one+ and lithium 18v one +
I just went through this with Porter Cable 18V but I can't say it is the same for Ryobi. On the PC, all 18V batteries are interchangable on the tools, but the charging needs are different. A dedicated NiCad charger can't shouldn't be used for liOn but the later chargers will work for either battery.
Ryobi offers an 18V upgrade:
RYOBI Tools
Jan 02, 2015 | Ryobi Drills
I have a Ryobi set ( elec saw, jack saw, tourch and drill,but my battery charger has gone kaput! I will like to buy a new battery charger BC-144T so I can use my Ryobi set. Where I can buy a new battery...
I checked a couple sites and would suggest calling RYOBI parts supplier at 1-877-545-4099 to ensure that you get the correct charger. They might ask you what the model nnumber and the voltage and type of battery so have these numbers handy. Let me know if you need more assistance.
Jun 15, 2011 | Ryobi Multi-Volt Battery Charger
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Can you charge ryobi lithium batteries in a regular ryobi charger?
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
Dec 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Lithium batteries?
Just got a reply from Ryobi tech service and it says that "all Ryobi 18V platform power tools can accept and use the lithium batterys, but you must use the charger for the lithium to recharge them. Hope this helps. Dave
Feb 11, 2009 | Ryobi Multi-Volt Battery Charger
Drills Logo
65 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
