Question about Toshiba 65H84 65" Rear Projection HDTV
Vertical lines My Toshiba 65H84C television has vertical lines when turned on. The lines fade a bit but are still noticeable even after being on for several hours. The local small town shop said parts were not available for a TV of this age. Could I get parts on eBay or somewhere and have the shop put it in? What part(s) would I need?
    Master:
  • Toshiba Master
  • 495 Answers
Its not worth it. the internals are so old that once you fix that, another part will fail. I hate to say it but since the mid 90s TVs are not worth fixing once they get this old. The parts that need to be changed are the CRTs and they are upwards of $1000 if you can even find them. Used CRTs are not worth the money as they will be just as worn out.
Posted on Apr 02, 2015
  • Frank Mitchell
    Frank Mitchell Apr 02, 2015
    That is what I figured. I have it for sale on Craigslist for cheap
SOURCE: Vertical lines across the screen
I now have the same problem. Lines are on the left side of the screen almost have way across the screen, with a thicker line int he middle which is the same length. It started last week and stopped after fiddling with it. Now it comes on fine then about 5 min . in the lines appear. I have had the tv for 1.75 years myself and have had to deal with bulbs popping numerous times (3). Was this the same as yours? Did solutions work? Please do tell.
Posted on Dec 02, 2007
djnick989
  • 1067 Answers
hair line cracks in motherbord on soldering jobs look all over re soilde rthem back togther nicely
Posted on Jan 29, 2008
SOURCE: Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Posted on Apr 30, 2008
  • 53 Answers
SOURCE: Red vertical convergence out. Where can I find DIY repair info for this older set? I found the part online. Is it a solder job or a board replacement?
yes it a soldering job, replace the 2 ics, model no. tsk..., and check the resistors at the pins.
Posted on Apr 20, 2009
  • 1030 Answers
SOURCE: Vertical Lines that occur for the first 5 min the tv is on
sounds like you have sa bad what is called the hypermodule. ideally the best coarse of action would be to replace this. but do to the fact it is a common problem these cuircit boards are hard to come by. Toshibia has told us service centers how to repair these boards which involves replaceing 11 micro caps very very small compnents that usally involve twezzers and magnifier. not for the do it yoursefer. you can easlly damage the board and if that happens that ends the tv right there. at my shope such a repair runs 250 with the parts and labor but it will depend on the shop it is rather labor intensive even to remove the board
Posted on Jun 19, 2009
Toshiba 32" Full Picture w/ vertical White Lines?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 03, 2014 | Televison & Video
Vertical lines when I turn on my Toshiba 51HX84
Thats a common issue caused by bad capacitors on the hyper module
Feb 10, 2013 | Toshiba 46H84 46" Rear Projection...
Why would there vertical lines on my toshiba theater wide tv?
this sounds like a bad capacitor. If you want to fix it yourself and know how to solder on a pcb, then replace all of the electrolytic capacitors.
Nov 18, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
I have a 6 year old 32" Toshiba tube .tv. I have
thir is somecondensers on the tv needs to be changed especialy on pwer supply and vertical circuit it is easy fault but needs technication,,,but first be sure thir is no floresent lamp common with the same supply of the set
Dec 23, 2010 | Toshiba 32A14 TV
Vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Apr 03, 2009 | Toshiba Regza 46RV525U 46 in. LCD HDTV
TV Toshiba CF32G50
I think you have a vertical problem. Turn up screen voltage to see if there is a tin horizontal line across screen. If so replace vertical output IC and the 100uf/35v capacitor in the vertical circuit.
Oct 31, 2008 | Toshiba CF32G50 32" TV
Toshiba 27AF44 shows vertical lines and crakles very loud
The capacitors at the vertical stage must be faulty resulting in the above symptoms.
Sep 20, 2008 | Toshiba 27A44 27" TV
Vertical lines
Oct 31, 2007 | Toshiba 46H84 46" Rear Projection...
Toshiba 65H84 65" Rear Projection HDTV Logo
105 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
