Question about Singer Sewing Machines
It is a Singer stylist 834 and I can't get the machine to feed the material through. I already checked the settings and cleaned it out but had no success
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
I just downloaded the manual for your serger from the Singer site, and on page 30 under Troubleshooting, it says that either the presser foot isn't set with enough pressure, or the differential feed is not set correctly.
Posted on Nov 18, 2014
  • 980 Answers
SOURCE: I have a Singer Stylist 543. The feed is not
If you have taken the needle plate off recently make sure you have put it one correctly, failing that you need to get underneath the teeth by taking the machine bottom off and you will see a large screw that you can adjust
Posted on Mar 09, 2010
SOURCE: Free manual for singer stylist 834
go to website
diplodocs.com
on the page go to the right side, there are alphebet letters,,go down to S & click on the name singer
it will take you to the next page
go down to box that says---most common searches
click on your sewing machine number-it there because I looked for it
it will take you to another page answer the questions about your sewing machine & then you can download the pdf file for free
Posted on Aug 05, 2010
hazelgrace
  • 340 Answers
SOURCE: do you prefer the singer
Here's a review for the 834.
http://zigzaggers.typepad.com/zigzaggers/2008/07/singer-stylist-834.html
Although it mentions you cannot raise and lower the feed dogs, you can change the throat plate to cover the feed dogs when you don't want to use them.
I couldn't find any reviews for the 518. I think the higher the number, the newer the machine although I may be wrong about that! I have a Singer Stylist 416.
I would look at how easy and expensive it is to get replacement parts for both machines before making your choice.
This is a good site for Singer Stylist parts. http://www.tandtrepair.com/index.html
Why don't you email the guy who runs it and ask him what his preference would be?
Hope this helps, Hazel
Posted on Aug 30, 2010
  • 1788 Answers
SOURCE: Singer Stylist 834
It needs a good cleaning of lint, thread etc. take your bobbin case out and make sure that there is nothing in there. DO NOT TURN YOUR HAND WHEEL BACKWARDS! It will mess up your timing. If you cannot free it up take it for service
Posted on Sep 08, 2010
  • 233 Answers
SOURCE: I purchased an older Singer Stylist zigzag model
I can definitely help you with the owners manual. Go to http://parts.singerco.com/IPinstManuals/457A_105_125_135_143A.pdf and you can download it direct from singer, no viruses, nothing. Just save it in Adobe format.
The bobbin thread problem is called a birds' nest and can be from a number of problems. First thing to do is to change your needle, especially if it was the one you bought the machine with. It may look perfectly straight to the naked eye. But it only needs to be a little bent to cause a problem. If this doesn't clear the problem up, make sure you're using a new bobbin, freshly wound. If the bobbin isn't wound properly or is an old bobbin that's slightly bent or not quite round, it'll cause problems, too. Finally, the machine may need a new bobbin casing. Do a google search for Singer sewing machine parts and search for a bobbin casing for a model 457. You'll remove the plate from the top of the machine CAREFULLY (the screws are small, so be careful not to lose them!). Take pictures if you need to with your cell phone so you can see what to do when you need to put the new casing in. Bobbin casings are usually $25-30. This is the last thing, and I would only do this if you see that thread is catching on something in the bobbin area when you're moving the wheel by hand.
I've tried to be clear on the last bit, but I realize it can be a little awkward. If you need any other help with that, please leave me a comment back. It goes straight to my email, so I'll see it quick and will get back to you right away. The manual doesn't help a lot with your bobbin problem, so I'll do whatever I can to help you through it and get you sewing. Good for you for finding a great garage sale find!
Posted on Jun 08, 2011
Feeddog singer stylist 776 how would the feeddog gt lowered
Consult the owner's manual. There should be instructions for how to darn with your machine. It would require either the feature that lowers/raises the feed dogs or a cover plate that attaches over the feed dogs.
If your machine came with the cover plate accessory, and the feed dogs are not rising to feed the fabric, then I suspect the machine has not been cleaned & oiled in quite some time and perhaps the feed dogs have seized. When you run the machine (remove the needle and presser foot), watch if the feed dogs actually drop below the needle plate, move toward the front of the machine, then rise above the needle plate and move toward the back of the machine. This is a repetitive motion that actually pulls the fabric through the machine. If this is not happening with your machine, it needs service.
Singer Stylist 776 Manual Page 8
Oct 30, 2016 | Singer Sewing Machines
Singer stylist 834 manual
It's right at the Singer site, and it's a free download. www.singerco.com.
Aug 15, 2014 | Singer Sewing Machines
Why will the feed dogs on my singer stylist 834 only move if the pressure foot is up?
Sounds more like a settings issue than a repair.
Check here -
http://www.youtube.com/watch?v=d3khJG7L_Tw
Jul 31, 2014 | Singer Sewing Machines
Why is singer stylist 834 feed dog is not working
After flipping the lever, button, or dial (whatever brings it up on your machine), you must ALSO turn your hand wheel TOWARDS you (ALWAYS turn it towards you for anything) at least one revolution, but it can be up to three revolutions before it will raise. You will hear it snap into place.
This is true of every sewing machine manufactured by anyone, by the way.
Jul 07, 2014 | Singer Sewing Machines
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
I just got a Singer Stylist 834, the feed dog will not move? Please advise!
normally when the feed dogs do not move then they need to be check to see if they are out of time or they might be broke
the machine needs to be serviced
Mar 10, 2012 | Singer Sewing Machines
Do you prefer the singer stylist 518 or 834? I am looking at purchasing one of them
Aug 28, 2010 | Sewing Machines
go to website
diplodocs.com
Aug 05, 2010 | Singer Sewing Machines
I have a Singer Stylist 513 & I cannot get the feed dogs raised.
The model 513 Singer has two gears which operate the feeding mechanism. If one of these gears is broken, the machine will run except the feed dogs will not move. This is a very common problem with this model.
Aug 03, 2010 | Singer Sewing Machines
Singer Stylist 834
Nov 04, 2008 | Singer 132QRFB Mechanical Sewing Machine
Sewing Machines Logo
145 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
