Question about AT&T DECT6.0 1-Handset 2-Line Landline Telephone - TL88002
I'm receiving a "no line" message and cannot receive or make calls what can I do?
    Master:
  • 623 Answers
Replace the jumper cable between the wall jack and the phone. You've probably installed a "roll over" cable by accident.
Posted on Nov 14, 2014
2 Suggested Answers
aviral_srms
  • 1216 Answers
SOURCE: We have the ML17939 2
i am not sure how are you doing it.
this guide will help
check the procedure again
else you must try a reset of your phone
you may find in the guide how to do it
Posted on May 30, 2011
How do I reset the message indicator light?
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 18, 2012 | GE Rca 25414re3-a Executive Series 4 Lines...
My Motorola Photon Q will not receive or send texts or calls, what can I do?
I would check with sprint to see if your account is up to date. Otherwise, I would suggest going to your settings and see if you can update your phones's prl and profile. go to settings, tap "About phone", Tap "System updates", then tap each option. Good Luck!
Dec 05, 2012 | Motorola Mobility Sprint Photon Q 4g Lte...
I am receiving my friends messages but she's not receiving mine
Use Facebook, Twitter, Gmail Chat. For whatever reason you're using Yahoo messenger, if you're too attached to it to use something else, try disconnecting and reconnecting, or send a different type of message, or try to connect with a video chat or phone call through Yahoo.
Jun 07, 2012 | Yahoo Messenger
My Nokia c2-00 shows "Contacts not ready" message after I turned it on. I can't see received calls, missed calls, dialled calls & contacts list. I can make a dial call, but I can't get receive...
i have faced the same problem in my Nokia c2-00 and i did the following and problem solved.
1. switch off the mobile.
2. Remove the battery.
3. Remove the sim cards & memory card from the slots and reinsert it one by one.
4. restart the mobile. Now i can view the contacts and msg's in my phone..!!
Mar 29, 2012 | Nokia mobile C2-00 Dual SIMbiosis
I have an HP 8500A printer/scanner/fax. Everything works but the fax. I can receive but I can't fax out. I get error 348, 321 & 358.
Hello and Welcome to FixYa!
Sir/Ma'am these error are basically due the Communication error of Receiving/Remote Machines. But each error shows different meaning.If during fax you receive the Error 348 then it may be because of several reasons like:-
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise,Other reasons can include power outages and other power-related problems.
  2. When The call-waiting service can cause this error or the remote user pressed the Stop key while the reception was in progress.
You can solve the Error 348 by the following
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
If during fax you receive the Error 321 then it is because of:-
  1. There was a communication error with the receiving fax machine due to poor telephone line conditions.
You can solve the Error 321 by the following:-
  • Set the receiving machine to receive at a slower transmission speed
  • If the session fails after sending several pages of a large document, resend the document as several smaller documents.
If during fax you receive the Error 358 then it is because of:-
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
You can solve the Error 358 by the following:-
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 05, 2011 | HP Photosmart 2710 All-In-One InkJet...
I'm able to receive/send text
check your message center number, if changed contact your service provider for the message center number :)
Aug 11, 2011 | Nokia C3 Cell Phone
I have nokia e63, sometimes even the signals are there but I can't receive calls/sms, also I can't send sms or make any call, what should I do ? plz help
There are two possible causes of such a problem for you. One of them is that your line has been blocked by the service provider possibly due to violation of terms stipulated by them. On the other hand, it could be as a result of barred calls.
To analyze them carefully for you,
It is important for you to note that there is a function that comes with most phones that enables you to disable calls from being made and from being received. Also, what most people do not know is that while they are disabling the calls from being received or made, they also disable any communication from being made or received through that network. This includes barring incoming and outgoing messages. If this feature has been accidentally activated, it could lead to your inability to make or receive calls and messages.
Also, if your network provider has blocked or deactivated your line for some reasons, you might not get a notification and you won't be able to make or receive calls and messages too. The best way to figure this out is for you to try to recharge your line and see if it works, if it does then it is not from your line or better still just call the customer care and explain your ordeal to them.
Lastly and most unlikely, if it is a new sim card, you have to activate it depending on your network, there are different methods by which this can be done.
Hope this was helpful?
May 29, 2011 | Cell Phones
Hi Friends, We have info print installed on our iseries box. When we are generating PDF files under email using info print server, we can customize the following two messages under email:- 1. Subject...
insert x'0d' or x'0d' x'0a' where you want the end of lines i.e.
EVAL MSGTEXT='wELCOME'+X'0D'+'WE HAVE RECEIVED YOUR INVOICE'
or
EVAL MSGTEXT='wELCOME'+X'0D'+x'0A'+'WE HAVE RECEIVED YOUR INVOICE'
X'0D' is the new line code in hexa
Nov 22, 2010 | IBM Infoprint 6500 Matrix Printer
Can't receive fax but can send
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Dec 03, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
AT&T DECT6.0 1-Handset 2-Line Landline Telephone - TL88002 Logo
56 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
