How do i change a wick in a sears kerosen heater model 40303?
SOURCE: Lost user manual for kerosene heater
Figured it out on my own and it was FREE
Posted on Nov 15, 2008
heavy389
SOURCE: I need to change the wick on my dk 23 corona kerosene heater
what make and model is it? They are very simple to change,never heard of 1 "Not" lighting tho,unless you have water in tank and the wick sucked up the water...water don't burn,You can also raise the wick in their now if it has never been raised,as long as it don't have "riviet"looking things attached to sides of wick to fit it wick housing(Sears is good for that)If it a round or square heater it pretty much the same you have to remove the outer shell of heater, its always a good idea to dump out fuel first,at the base of wick their is usually 3 wing nuts or screw that hold wick Assembly in,after removing them you pull housing up to remove ,notice how the old one is on and remove and put new one on,when putting back in make sure wick fans out and goes to bottom tank,put back to gether and your done,most replacement wicks come with directions and height setting for the wick, Its not real hard as long as you pay attention
Posted on Nov 30, 2008
  • 3 Answers
SOURCE: kerosene heater
Dyna Glo 95 c4 Manual
http://www.owneriq.com/mdownloads/8979e0af-dfee-45f1-a8ba-c05c2f5ed4a8.pdf
Posted on Dec 07, 2009
SOURCE: My Dyna glo kerosene heater
I have the same problem and I have checked the carbon on wick. It's still not working. Help!!
Posted on Dec 16, 2009
  • 30 Answers
SOURCE: Changing Wick in Kerosene Heater
http://www.ghpgroupinc.com/heaters/manuals.aspx
Here is the complany website..parent group name is GHP group..crazy they don't link DynaGlow more easily in a web search
Posted on Nov 06, 2010
How do replace the wick in a turco kerosene heater
This a very odd question about cell phones, isn't it? There are two videos on you tube to help you do this.
Kerosene Heater Wick Replace - YouTube
How To Replace a Kerosene Heater Wick Tutorial - YouTube
Jan 26, 2014 | Lands Phones
Looking for a manuel for the sears portable kerosene heater model 583.403080. iwant to replace the wick. contact me at billnlis@netzero.net. thanks
Check with your local Ace or True Value Hardware. They have the crossover numbers for the wick you're looking for.
Jan 19, 2011 | Heating & Cooling
Is it true that if you use moth balls with the fuel in my kerosene heater it burns cleaner & there wont be any build up on the wick? I get alot of soot build up on the wick of my kerosene heater &...
I can't answer about moth balls cleaning the wick but off the top of my head I would not try it as I do not know just what gases your unit would give off. I use kerosene heaters and find that after about 5 tanks of fuel I put on a pair of household rubber gloves, remove the chimney and turn the wick all the way up. Then I roll the wick between my fingers and get the hard carbon off. Once I have the wick clean I use the shop vac to vacuum it all up. I have found that by doing this my wick is never dirty, I do not get any smoke and the wicks last more than 20 years. Probably a better idea than moth balls. Let me know how you make out.
hardrocko
Feb 09, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Wick not burning properly and smells
You need to use pure kerosene do not use died or color kerosene it depletes the wick faster and causes a distinct odor. Pure kerosene should be clear.
Dec 16, 2009 | Heating & Cooling
Nov 26, 2008 | Heating & Cooling
Nov 08, 2008 | Heating & Cooling
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
