Question about Hunter 44110 Set & Save Programmable Thermostat
Up arrow not working
It shows 68 as the temperature. I'm trying to set the temperature to 72. The up arrow is not moving the temperature setting. However, the down arrow will lower the temperature setting without a problem.
    Master:
  • 602 Answers
Replace the thermostat
Posted on Nov 17, 2014
Heater temp is 78 the water temp 68 how do I reset heater temp to match pool temp.
Sounds like a faulty temp sensor. Check it for debris, clean it good and see if that does it. If not try replacing it.
Jun 02, 2015 | Pool & Spa
My robertshaw thermostat works well in summer when using my Air conditioner. I have a heat pump. but in the winter the thermostat frequently displays "ER" during cold winter nights when the unit...
what it sounds like happening is the unit is realizing it is falling behind most thermostat s have a 3 degree deadband if they fall 3 degrees or more at a time after running for so long then it will bring on the emergency heat which is located in your inside unit... when it gets really colds and you see this you need to go outside and look is the outside unit still running and is it freezing up on you...also if running check the larger of two pipes make sure the large pipe is hot to touch...based on the description you have given the thermostat is calling for emergency heat but for some reason is not bringing it on or there is a problem with the emergency heat.... hope this helps out some
repost with any additional questions...
Jan 08, 2011 | Honeywell Electronic Programmable...
The heater will not kick on. It's a programable 7 day that reads 69 degrees and if I arrow up to 72 degrees, nothing happens
Change Temperature Setting Until the Next Program Period (Temporary Change)
? Press UP Arrow or DOWN Arrow until the screen shows the desired temperature setting.
NOTE: The temporary temperature setting is displayed for about 3 seconds and then the room temperature is displayed.
Temporary appears in the display. The setting cancels when the next program period starts or when
you press RUN PROGRAM.
Change Temperature Setting Indefinitely (Hold)
? Move the System switch to the desired position (Heat or Cool).
? Press HOLD TEMP then UP Arrow or Down Arrow to change your setting if desired. (The display changes from showing the setpoint
temperature to room temperature after approximately three seconds).
? To cancel Hold press RUN PROGRAM.
The downloadable manuals for this t-stat are here, and the addendum, here. Page 17 and 18 detail thermostat operation I have copied above. It has graphic representations of keys that do not copy over very well, so if you have questions about the steps above, you should view the manual in the links provided above.
I hope this helps! Please take a moment to rate my reply - thanks!
Dec 23, 2010 | Honeywell CT3600 7 Day Electronic...
What control turn on heat
OK, just set the temperature to 'Auto/Econ' on the buttons on the heater control and adjust the 'temperature' up or down with the hottter/colder buttons until it has a comfortable temperature like 68 deg. F or 72 deg. F. The system should work automatically after that.
Oct 28, 2010 | 1995 Cadillac DeVille
I have a Rinnai 556F Heater and I set it to a specific Temperature and a temperature higher is always flashing. What is wrong?
The temp you are looking at may be an error code. 72 Room sensor, 68 Over heat, 76.80 Room sensor short, etc. What is the exact code??
Tom
Oct 14, 2010 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
No heat 2006 f150 5.4 liter i changed thermostat ,still no heat
Is there no heat even with the temperature set to max ? There is a TSB ( TSB 08-23-6 ) where when the temperature is set between 68-72* F, EATC ( Electronic Automatic Temperature Control ) has intermittent operation. The same TSB covers inability to control temperature output on the EMTC ( Electronic Manual Temperature Control ) HVAC controls. There is a new temperature blend door actuator ( p/n : 9L3Z-19E616-E ) to cure the problem, if these symptoms match the ones you are having.
Apr 14, 2010 | 2006 Ford F-150
What is the correct temperature for a gym class
gyms around here stay around 68 to 72, 68 summer and 72 winter. theres no way i could work out in 76 that would be very uncomfortable, if you are really working out your not going to be cold.. hope it helps
Nov 11, 2009 | Omega Trane Furnace Draft Inducer Blower ...
How to use a SUNBEAM twin window fan with
Intake brings the air outside into your room, exhaust pushes the air inside your room out.
What setting you use depends on your personal taste of temperatures and the temperature inside vs outside. If you set the thermostat to 72 degrees and it is more than that outside then I would use the exhaust setting. If you set it to 72 degrees, and it is 68 outside but 84 inside then I would set it onto intake to cool the inside air.
Jun 21, 2009 | Dryers
Hunter 44110 Set & Save Programmable Thermostat Logo
103 people viewed this question
Top Hunter Heating & Cooling Experts
Jay Finke
Jay Finke
Mack Baxter
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
