Question about Hasbro Furreal Friends Butterscotch Pony
Were can I find the plastic holder that batteries are held in for Hasbro butterscotch pony
    Sergeant:
  • 146 Answers
Scroll about half way down the page for the instructions. Takes 6 D batteries.
Furreal Pony Instructions eHow
Posted on Jan 11, 2015
4 Suggested Answers
SOURCE: computer novice--hasbro battery
Once you backout the retaining screw, put your fingers in the gap between the battery compartment and the switch. Push the battery compartment to the rear of the pony then you can remove it.
Posted on Jan 18, 2009
  • 8 Answers
SOURCE: Looking to repair the tail on Butterscotch pony
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Posted on Jul 23, 2010
jacksparr689
SOURCE: I need a battery compartment for butterscotch fur
I found one of this on a garbage deposit. I opened the battery box and it was completly destroyed. A good technician could restore all the conections on this...not a big deal, but I'm not LOL, so I took out th two main cables (red and black) by take out the three screw placed where the battery box snaps in. The I conected a 9v battery directly on this two wires and voila! the pony is alive again
Posted on Apr 16, 2013
Plastic holder that batteries are held in
Could you elaborate? I can't see the question beyond "Plastic holder that batteries are held in"
Nov 12, 2014 | Hasbro Furreal Friends Butterscotch Pony
Butterscotch pony head not working
First, calling poor Grace at Hasbro will provide fruitless. Hasbro does not make any parts for the full size FurReal Ponies, they have nothing in stock and cannot help you. I, however, can. I am going to post a link to a distressing site that turns the normal FurReal Pony into a fire breathing demon. However, in the process, you can see the diagram of the skeleton of the pony and head. You can search for other links but this is pretty comprehensive. Just don't open when kids are around.
Lisa
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/
Dec 08, 2013 | Hasbro Furreal Friends Butterscotch Pony
I need a replacement battery compartment for my pony is there anywhere where one of these is available?
Call Hasbro's Customer Service and see if they can offer any suggestions. If they make any other FurReal friends that are so large that they require 6 D cells, then the box would probably fit. If they don't you'll have to do some internet searches for "Plastic On Off Battery Compartment" or see if HASBRO can tell you what the part number was and you can try searching for that. Hope that helps.
Dec 15, 2011 | Hasbro Furreal Friends Butterscotch Pony
Replacement battery holder
Hasbro doesn't even have FurReal ponies on their site anymore and emails don't get answered. I would call Hasbro directly from the following link and ask about the battery compartment.
http://www.hasbro.com/customer-service/phone-directory.cfm
Good luck :)
Nov 25, 2011 | Hasbro Furreal Friends Butterscotch Pony
How do I reassemble the head of the FurReal Pony?
The Pony Care Guide refers to an "Assembly Video" on the FurRealFriends.com site. I couldn't find it and even went through a gazillion videos on YouTube. Contact Hasbro directly through this link to see if they can send you a link to the Assembly Video:
Nov 18, 2011 | Hasbro Furreal Friends Butterscotch Pony
Where can i get replacement parts for butterscotch? bought at sam's 3 years ago Kids now really into horses and of course our pony needs a few things. battery pack, tail, brush, and carrot any help?
I have had similar problems with toys myself. Seems as if when I am sure that my boys are done with a toy and it is long forgotten- it resurfaces needing some tlc... Here is a link to get the battery pack and cover. I would also suggest checking auction sites, as I have been able to find elusive little plastic parts of helicopters there too :-) Best of luck, and looking at Butterscotch; I would love her too!
http://www.hasbro.com/customer-service/orderform.cfm?sku=76471
Mar 24, 2011 | Hasbro Furreal Friends Butterscotch Pony
Where can i buy a replacement halter for butterscotch pony
Go here :
http://www.hasbro.com/customer-service/replacement_parts.cfm
You can order replacement parts for your Hasbro Butterscotch Pony.
Mar 05, 2011 | Toys
Computer novice--hasbro battery
Jan 15, 2009 | Hasbro Fur Real Friends Smores Pony
Hasbro Furreal Friends Butterscotch Pony Logo
281 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
