Question about Ovens
Ok so my father in law was cleaning the oven and I guess he was leaning on it and when he went to go shut the door it wouldn't shut properly could u plz help
  • 34 Answers
Bind hing back
Put a nail in the hole on both hings and gently push on the door
Posted on Nov 17, 2014
catriver
  • 878 Answers
SOURCE: Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Posted on Oct 25, 2006
  • 33 Answers
SOURCE: Oven door locked
if the oven cooled down and door still wont open unplug oven for 15minutes and see if that helps ive seen in many cases were the door had to be destroyed to gain access to the oven
Posted on Dec 30, 2007
localwonder
  • 6784 Answers
SOURCE: Interior oven light won't shut off.
Hi, i would check the pressure switch and its connection as well. either the switch is malfunctioning or the wires and connectors are corroded. simply replacing the wires or switch will fix this issue. the switch is usually located on the rim of the inside of the oven door. it will make contact with the oven door and as the oven door closes, the pressure switch is depressed inwards, thus, opening the circuit and cutting power to the light.
Please rate and god bless:)
Posted on Apr 16, 2009
SOURCE: Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Posted on Dec 18, 2009
SOURCE: 7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Posted on Feb 13, 2010
We've got a broken door spring on our Maytag CWE5800ACE Oven. We pulled off the top door and disassembled it when we realized the springs are inside the oven unit. OK....Can anybody can offer some...
My father-in-Law has the same issue and I found the spring as part of the hinge assembly. The link is "http://www.appliancepartspros.com/part_details.aspx?part_id=4092260&image=1" and the part number is Part Number: AP4092260
Made by WHIRLPOOL. Hope this helps!
Dec 01, 2010 | Maytag CWE4800A Electric Single Oven
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I need to get my oven unlocked. The cleaning cycle went haywire
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Oct 25, 2009 | Whirlpool RBD305PD Electric Double Oven
I did a self-clean session and the oven remained locked way after it completed the cleaning. The error message on the backsplash reads E1- F5-. I am not able to open the oven. What's wrong?
I hit the cleaning button instead of the broiler and the oven lock went in mode so now it thinks it is cleaning but I can't close it and it won't shut off the cleaning mode. What can I do?
Sep 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
The oven will not heat up. The range works great but the oven won't.
My father in law checked it out and determined it was the ignitor and he fixed it.
May 11, 2009 | Magic Chef 9122 Gas Single Oven
Dacor ECPS130 fan won't shut off
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
Mar 20, 2017 | Dacor PCS130 Preference Electric Single...
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 | Ovens
Self cleaning oven not working right
shut the power off and see if it resets.
Jan 09, 2008 | Ovens
DOOR LOCK WONT OPEN
do both of you have a digital display? if so are you getting any codes that f- with a number?
Nov 20, 2007 | GE JGRP17 Gas Single Oven
Oven shuts down
My mother-in-law's oven was doing the same thing. At first it was actually turning completely off which led me to think it was a loose connection on the circuit board. That turned out to be exactly what it was. I had to dismantle the front of the oven, remove the circuit board, and resolder the connections. The first time I did this I must have missed a few bad joints and that's when it started doing what you described (shuting off and showing lock door). I pulled it back apart and found a few more bad solder joints which I fixed; so far so good. This is of course one of those "don't try this at home" fixes but it least lets you know what is causing the problem.
Nov 09, 2006 | Kenmore 40161 / 40169 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
