Question about Electrical Supplies
I have a Steamist SM-8 generator and DSC 425 wall controller. The units are 10 years old. Today when I tried to use the unit I pressed the start button on the control, it showed me the minutes it wa
I checked the circuit breaker - power is on to the unit. I removed the front covers and determined power was flowing through the wiring inside the generator. The system has worked perfectly over the past 10 years. Any idea what is happening?
mamicheddy
  • 79 Answers
SOURCE: ONAN 4000 RUNS FOR ONE HOUR AND DIES--ANY IDEAS WHY?
If your unit is running fine and then all of a sudden it just shuts down it is usually that you stopped creating voltage. You need to check the brushes and rings. If you are able to start the unit right up without any hesitation and voltage is being produced, then your fuel pump is breaking down. If you do have hard time restarting then you may have clogged fuel filters. One at the carberator and one at the fuel pump.
Posted on May 10, 2009
  • 28 Answers
SOURCE: CP685AVR/BF685 Power Contro.
It is likely the battery. These batteries are designed to last 3-6 years in a UPS. The good news is that if it is the battery, it is completely user replaceable and you'll have a Cyber Power unit that works just like new with a new battery. What may have happened is that the battery was weak, and you may have had a slight dip in the AC power. This caused the Cyberpower unit to switch over to the weak battery which couldn't handle the load. The unit then turned off. When you press the "ON" button, the unit will go through a self-test that checks all of the components and the unit will not turn on and be functional unless all of the components come back with a PASS, including the battery. If possible, test the battery with a voltmeter, it should read around 13.5, but not lower than 11.5v DC. However, with the unit over 3 years old, it almost certainly the battery. Here's a link to a replacement battery for the CP685AVR: http://www.batteryinternational.com/cyber-power-cp685avr-ups-battery-ups-batteries-f1.html
Hope this helps.
Posted on Jul 01, 2009
  • 26 Answers
SOURCE: Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Posted on Jul 09, 2009
projdoc
  • 2237 Answers
SOURCE: Air conditioner trips circuit only in the evening?
first off, it's illegal to release freon into the atmosphere. the epa could charge you $32,500, so keep it under your hat. second, if it's getting too cold where the evaporator coils are icing up, it's too lille freon, not too much. as for the breaker tripping, your compressor might be wearing out. if it's pulling too much current, the motor is failing and the compressor needs replacing. and do not do it yourself unless you're certified by the epa to move freon and have the proper equipment to recollect the used freon.
Posted on Jul 29, 2009
protek480
  • 1723 Answers
SOURCE: Fuse blows repeatedly
The auto speed control is failed. Keep it manual and see how it does...It will run at full throttle even when no load is running. Then fix the throttle control when able.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 09, 2009
I have water going to unit, but it will not fill.
Contact company directly for product manual and troubleshoot help from manufacturer
http://www.steamist.com/contact.htm
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-amil or phone while you work on Steamist or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 23, 2011 | Steamist SM-79 7900
I have a Steamist SM-8 and I am receiving an E4 error message on the control panel. What does this mean?
1) Steamist SM-8 is a Steambath steam generator with 5 year parts warranty and 2 years labor
http://www.faucetdepot.com/prod/Steamist-SM-8-IM-InstaMist-Steambath-Steam-Generator-29984.asp
2) Steamist website does not have manuals that we can immediately download and look at error codes alongside you.
3) However your manual has that information, and you can add a comment and say what the manual suggests as troubleshooting, so we can offer some level of do-it-yourself help.
4) Perhaps you could scan your manual into pdf format and post your manual on your website.
And then add a comment with web location of manual so we can download and read your manual, alongside you, and perhaps offer additional do-it-yourself solution for you.
For example check that circuit breaker is delivering 240V to product, and element is not burned out, and there are no loose wires, and condensing reservoir is not clogged with sediments that can be cleaned with CLR.
5) The manual is key: I'm sure the manual also shows regular maintenance needed to ensure long life of product. For example avoid exposure to hard water, use water filter, clean reservoir and lines regularly. Avoid freezing.
I always tell people to save product manual like gold and read it cover to cover because it will save money and trouble long-run.
6) Steamist website has contact us link: With direct e-mail to 'troubleshoot' and 'literature'
I suggest next step should be contact manufacturer and request each of the following: a) a manual b) do-it-yourself assistance c) warranty information d) name of authorized technician to make repairs.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on steamer or any do-it-yourself project.
Feb 03, 2011 | Steamist Hardware & Accessories
No steam is coming out of the outlet in the steam room, but alot of water comes out of it
Check the breakers that feed power to the unit--turn off, then on. If no help, remove power from the unit and measure the resistance of the heating element--it should measure somewhere around 20 to 30 ohms, but not infinity. Hope this helps!
Apr 09, 2010 | Steamaster Steamist SM-8 Fixed 8 Kilowatt...
Our Steamist steam shower is probably a few years
That is a main problem with the analog systems. Just not reliable as the new digital systems. To my best knowledge there is only one manufacturer making the 100% digital steam generators.
Feb 28, 2010 | Steamaster Steamist SM-8 Fixed 8 Kilowatt...
Tripping circuit breaker
what suddenly starts to opperate every couple of days
Jan 13, 2010 | Steamist SM-79 7900
I purchased a new controller TC135 snd connected it via the telehpone like plugs and it still doesnt work. How do I test the unit itself?
If the unit is new, there is likely a problem in the generator it connects to. Since this is all a proprietary interconnection it is unlikely you can find any way to test the parts individually.
Nov 10, 2009 | Steamist SM-79 7900
Electrical Supplies Logo
51 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
