Question about Master 1500ID Combination Padlock
Where do i store my combination
1500iD instructions say that i can store my combination here??
  • 1,631 Answers
I am not aware of a "Lock Box" or "storage" capability on FixYa.
If you want storage capability for free...
Google free online storage.
  1. Googledrive.com
  2. box.com
  3. dropbox.com
  4. iCloud.com
  5. evernote.com
  6. bitcasa.com
These are just a few available that are very good.
Posted on Nov 14, 2014
I lost the combination to my speed dial master lock and it is in the locked position. How do I open it and create a new code?
It's not easy to fix this problem, because these locks do not shim open and it's not obvious how a person could figure out the old combo. I was able to loosen and remove the security screws, disassemble mine and repair it. They are very tricky to reassemble and it took me hours to find the spring that was out of position. The root problem was the lock did not clear when the shackle was pushed in. Until I figured that out, it would take up to 30 tries to get it open. The security screws are Metric - so you can replace them with regular screws until you get it working. If you do open the case, there are a lot of small parts inside, including a bunch of springs.
Aug 18, 2014 | Master 1500ID Combination Padlock
How do I get it back open when it won't open to the combination I gave it?
Make sure you push the shackle down firmly to clear the lock and try the combo again. It is possible to open it by trial and error, but not easy. I have removed the security screws and repaired one, but it was tricky to reassemble. The problem with mine was a spring that slipped out of position and the lock wouldn't reset correctly. There are a lot of parts inside, so chances of getting it to work correctly are not good unless you're really good with complex mechanisms and puzzles.
Aug 05, 2014 | Master 1500ID Combination Padlock
What is the code in enterfactory
Hi.
Hi. There is no factory fixed code. Thieves would be the first to benefit from such feature! The factory code is uniquely associated to the safe serial number and it is stored in Sentry protected database. When original code is lost the only way to unlock the safe is bay following Sentry's procedure.
Contact Sentry immediately. They will first try an emergency unlock code, and then they will give you instructions in case the safe must be serviced. Here the contact: Call or Email Us
Here general instructions about what to do when combination does not work. Instructions are addressing lost combination.The procedure is the same in all cases when combination does not work (malfunctions, lost combination etc.) . Please contact sentry and follow procedure to get the safe open.
Regards.
Ginko
Oct 05, 2011 | Sentry Fireproof Safe
Reset combination of this 1500iD.
Here is the page:
http://www.masterlock.com/pdfs/5400D_Instructions_Sheet.pdf
Sep 11, 2011 | Master Lock 5400d: Portable Select Access...
I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone...
Try 2 options:
1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
Ity
Sep 06, 2011 | Office Equipment & Supplies
My friends were messing around with my 1500ID lock and changed the combination, then closed it. How can I reset it and change the combination?
Make your dumb friends find the code or buy you a new lock.
there is not trick to it... it'll have to be done by trial and error...
Sorry for your troubles.
Aug 31, 2010 | Master Lock 5400d: Portable Select Access...
Master 1500ID Combination Padlock Logo
85 people viewed this question
Top Master Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Master Lock and Locksmithing Expert? Answer questions, earn points and help others
