7/3(x+9/8)=20 - Office Equipment & Supplies
    New Friend:
  • 16 Answers
First convert your fractions into decimals. From there you want to multiply your decimals together, and then subtract that total from 20. That should give you X. So, 7/3 translates into 3 1/3, which becomes 3.33. 98 becomes 1 1/8 which translates to 1.25. Multiplying these gives you an answer of 3.74625, which can be rounded up to 3.75.now subtract 3.75 from 20 and you should get 16.25. This is X.
Posted on Nov 14, 2014
Regrouping mixed fractions
5 4/20 = 104/20
2 9/10 = 29/10 = 58/20
104/20 - 58/28 = (104-58)/20 = 46/20 = 2 6/20 = 2 3/10
Mar 18, 2014 | Office Equipment & Supplies
How to find the arithmectic or geometric for this Q. -2/5+(-3/20)+1/10+7/20+...+8/5
Input: -2/5-3/20+1/10+7/20+X+8/5
Result: X+3/2
Geometric Figure: Line
Alternate form: 1/2 (2X+3)
Oct 24, 2012 | mathway.com
I have a bad Paragon 8145-20 its Sunday all I have in stock is a Paragon 8045-20. I know voltage is the same. Will the 8045-20 work? What is the difference betweentime out and temperature out. If the...
See wiring diagrams and manuals at following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
8145-20 is 240V time initiated, pressure or temperature terminated with back-up time termination.
8045-20 is 240V time initiated, time terminated.
So 8145-20 has pressure or temperature limit switch that connects to terminal X that turns timer off, and ends defrost cycle. This timer is for hot gas defroster that has pressure/temperature limits. Check and see what the back-up time termination is set at on 8145-20. Look at small inner dial.
The 8045-20 timer does not use pressure/temperature limit switch, and instead you have to estimate length of time you want defrost cycle to run, and set inner dial to that time. Use same time as back-up time termination on 8145-20. Of course the pressure/temperature limits would not be exact and defrost cycle might not work correctly.
Here's the change-over wiring from 8145-20 to 8045-20.
There are other wiring variants depending on equipment.
240V hot wires from breaker box are L1 and L2
a) 8145-20 L1 is at terminal 1 > move L1 to terminal N on 8045-20
8145-20 L2 is at terminal N > move L2 to terminal X on 8045-20
b) 8145-20 hot gas defroster is at NO terminal 3 > move defroster to NO terminal 3 on 8045-20
Complete the 240 circuit to defroster by connecting to L2 at terminal X
c) 8145-20 refrigeration is at NC terminal 4 > move refrigeration to NC terminal 4 on 8045-20
Complete the 240 circuit to refrigeration by connecting to L2 at terminal X
Sep 12, 2010 | Paragon 8145-20 Defrost Timer
8y-4(5-6y)+20 distributive property
You are talking of the distributivity of multiplication with respect to the addition or subtraction. The only term where you have multiplication and addition/subtraction is the one with parentheses because
4(5-6y) = 4*(5-6y). * means multiply by
Distributing the product consists in removing CORRECTLY the parentheses.
I consider the term alone
4*(5-6y) = 4*5 +4*(-6y)= 20 -4*6*y = 20 -24*y
You put this result in a package and replace it where it was it the original expression.
So
8*y -(package) +20= Replace package
8*y -(20-24*y)+20 = 8*y -20 -(-24y) + 20 Remember -*(-) = +
8*y -20 +24*y +20= Remember -20+20 =0
8*y -20 +20 +24*y= Addition is commutative
8*y +24*y = 32*y
Let y be an orange 8 oranges + 24 oranges =32 oranges.Coclusion
8y-4(5-8y)+20 = 32y
Sep 10, 2009 | The Learning Company Achieve! Math &...
How can i use Sony 5.1 Receiver STR-DG520 in India (120V to 230V)
Sorry, but according to Sony this set operates only on 120 volts at 60 hertz. As we have no real need for up converters here in the USA, I cannot recommend one for your application. The best course would be for you to visit one of your local electronics stores and provide them with the specific current requirements. I'm certain that an appropriate converter is available in your area.
Bill
Aug 21, 2009 | Sony STR-DG520 Receiver
Usb compatibility with windows xp service pack 2
Install the service pack 2 and update via Windows Update!(Go to Tools then Windows Update in Internet Explorer) Install the USB Wireless Adapter! Follow the procedures here! http://support.dlink.com/faq/view.asp?prod_id=1398&question=DWA-130%20/%20DGL-3420%20/%20DWL-AG132%20/%20DWL-AG530%20/%20DIR-330%20/%20DWL-AG660%20/%20DWL-G120%20/%20DWL-G122%20/%20DWL-G132%20/%20DWL-G510%20/%20DWL-G520%20/%20DWL-G520M%20/%20DWL-G550%20/%20DWL-G630%20/%20DWL-G650%20/%20DWL-G650M%20/%20DWL-G680%20/%20DWL-G710%20/%20DWL-G820%20/%20WDA-1320%20/%20WDA-2320%20/%20WNA-1330%20/%20WNA-2330%20/%20WUA-1340%20/%20WUA-2340%20/%20DWL-P100%20/%20DWL-P200%20/%20DWL-P50%20/%20DWA-142%20/%20DWA-542%20/%20DWA-552%20/%20DWA-556%20/DWA-642%20/%20DWA-643%20/%20DWA-645%20/%20DWA-652%20/%20DWL-M60AT%20/%20DWL-R60AT%20/%20DVG-G1402S%20/%20WBR-1310%20/%20WBR-2310#sp2 Now try the connection! If you still have problems, let me know! regards, babb
May 04, 2007 | D-Link : DWL-AG132 a/g Wireless 108M USB...
74 people viewed this question
jasbo
jasbo
