Zosi 500 gb harddrive connected via ethernet displayed on HDTV via HDMI. the dvr has an app that you can check your DVR via moblie monitoring. for three weeks it worked fine but now i cannot view the
Having connection issues. only works via wifi but does not work via mobile network. any assistance would be appreciated
    Scholar:
  • 62 Answers
Sounds like maybe your IP address changed from what it was for the first three weeks. Unless you pay your ISP extra for a static IP address, they are subject to periodic changes. I don't know how your mobile monitoring app finds your IP address but you should investigate what your IP address is currently and whether this needs to be updated somewhere.
Posted on Nov 17, 2014
bpcs
  • 112 Answers
SOURCE: Linksys Wireless WRT54G vs. WET54G
For what it is worth, I fhave found streaming video does not function well using a wireless connection. The options of multipale routers will work as long as you configure them as to not have conflicting IP address assignment's via DHCP, and the routers do not have matching IP address's. Never fear all is possible with paticence. BPCS
Posted on Jan 20, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Actiontec MI424 and Direct TV DVR
Your DVR need to be set at 71.182.140.***  *** meaning an available address.  Then they will connect.
What is make and model number of the DVR?
Posted on Sep 10, 2008
kakee
  • 1269 Answers
SOURCE: XBOX 360 not connected to wireless connection on Linskys WAG54G2
You should enter the "Wireless MAC Address" of the XBOX and not just the "MAC Address". You can see it on the system info of the XBOX settings.
Posted on Jan 06, 2009
SOURCE: Wireless Troubles with 2wire
tried to remove the preferred networks on your computer. its under control panel, under wireless network connection properties.. ^^,
Posted on Feb 12, 2009
crapiemael
  • 241 Answers
SOURCE: After replacing Cable Modem, D-Link DI-524 Wireless will not work
Did you call Comcast and give them the new MAC address of the Motorola SB5101 SURFboard cable modem? I'm surpised it works at all without doing this first. This is the hardware address of your modem so the world can see you, no one in the world has the same MAC address, they are all different. It's on a sticker on the modem.
Posted on May 28, 2009
No volume when HDMI cable is connected to Direct TV DVR
Some DVR's do not send audio via HDMI. Mine doesn't. I have to run audio cables from the DVR to the TV.
Also, check on the TV settings to try alternate audio inputs.
Mar 20, 2016 | Apex Digital Televison & Video
I have a mitubishi ws-55313 with a monitor link DVI connection and I have tried to convert that to hdmi for a cable DVR but it doesn't work any ideas?
The monitor link is not a standard DVI connection, it was used to connect a Mitsubishi HD set top box. You can connect your cable DVR using component video cables and get HD that way, up to 1080i but not 1080p
Apr 15, 2014 | Mitsubishi WD-52525 52" Rear Projection...
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
Connection Problem with HDTV, Receiver, DVR, and DVD
check the setup menu to direct your inputs from the hdmis. its all in the setup menu. good luck
Feb 10, 2010 | Yamaha RX-V463 Receiver
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
DVI/HDMI Cable lost my pic and sound
Try disconnecting the hdmI cable and the dvr box.
Connect the cable directly to the cable input.
Sometimes the dvr boxes will cause this problem
after you connect the hdmi cable.
Dec 09, 2008 | Hitachi 57F500 57" Rear Projection...
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
Bose 321 lost sound
Check wiring from DVR to TV and surround system...TV may now be getting audio signal from DVR via HDMI/DVI cable. If so, the Bose needs to be connected to either optical/audio out on DVR, or on the TV's audio out jacks. If there is only one cable from DVR to TV, that is probably the case. This is just a general solution, if it doesn't help, reply with make & model #'s of all devices involved, I might be able to help more.
Mar 16, 2008 | Bose 3 2 1 GSX System
HDtv picture and av reciever sound do not match
I have a hdtv hooked up with a virgin v+ box but slight delay Why?
Dec 06, 2007 | Televison & Video
Wan't boot up
If the dvr isnt booting the harddrive, then the harddrive isnt seated properly in the removeable harddrive drawer, or the harddrive is improperly formated, or you have the wrong type of harddrive, or the master/slave settings on the harddrive are not set properly (master). what ive found is an 80gig/160gig is the most that these things will handle. and some brands work and some brands don't. and the harddrives have to be IDE/EIDE type drives. but it sounds like a harddrive interface problem. They like the older harddrive formatts/(not xp/vista)....good luck!!!!
Oct 27, 2007 | Samsung SSC DVR Digital Video Recorder...
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
