Question about Lexibook SERENITY 8 inch Tablet with 8GB Memory
Help my lexibook was doing great when one day i accidently put my charger away into storage and now i cant charge my lexibook tablet. i traid a different one and it fitted perfectly but when i turned
I would like to know if i need a new battery or just a new charger for my lexibook
    Sergeant:
  • 247 Answers
Try using a USB cable from your PC to charge it. It will have USB at on end and Micro USB or Mini USB at the other end to fit your tablet.
Posted on Nov 15, 2014
My Charger Port is no longer there is there any other way to charge it
Jillian, Check warranty, I beleive should be one year, call manufacturer right away if under warranty. Option 2 Have charger port replaced at a computer/cell phone repair shop. Check links below and see how they fixed this issue.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to Fix the Charging Port on Tablet
Is there any way to charge my tablet without the micro USB port
http://forums.androidcentral.com/amazon-kindle-fire/283806-anything-i-can-do-if-my-charging-port-broke.html
Apr 26, 2016 | Tablets & eReaders
My tablet will not charge only had it 5 months?
Depending on how many charge cycles your battery has had it may not accept charging anymore.
May 02, 2015 | Tablets & eReaders
Why did my RCA 10 inch tablet power down and now will not turn back on? It does not show any sign of charging - no battery symbol, no lights, nothing.
battery have residual power which last few minutes to allow safely switch off, as you used this power, it shut down. this residual reserve is usually between 3% to 5% of capacity.
and do not fiddle with it till you recharge it, reset will not work while there is no power, any other "trickery" will not work either.
now, plug battery to known good charger and charge it for 24hrs, do not switch it on during that time nor disconnect from the charger.
after this it should be starting and working normally, if it does not - it is still under warranty and you should return it to the place of purchase for repair or replacement, even if you do not have receipt. tablet have it's serial number and can be traced in the store to day, and even hour and minute when it was sold...
hope this short info will help you - do not forget to vote...
Feb 02, 2015 | Tablets & eReaders
I have a lexibook junior tablet I purchased for my son it will no longer turn on nor charge. Don't know what I should do
If that was one of those 40 or 50 dollar tablets you may be out of luck, try holding the volume down button then turning it on. I do also know that some cheapo tablet manufacturers have " cheaper than buying another one " repair
Dec 13, 2014 | Tablets & eReaders
Charging battery
The battery may be failing.
Apr 11, 2014 | Toshiba Portege M200-S838 Tablet PC
Power Problem
I have the matsunichi 9.7 my email has amessage saying connection problem no emails has come in for 2 days. What can i do to fix the problem
Mar 05, 2014 | Matsunichi Marquis Mp977 Marquispad 9.7"...
Samsung tablet
you may set it back to factory settings .most of the time you can hold down the volume and power at the same time for about 10 seconds until it goes to a screen that gives you options on how to boot. or just try to do it by going to settings.
Dec 28, 2013 | Tablets & eReaders
Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
Nov 09, 2013 | Tablets & eReaders
My sons versus tablet will not come on ... it looks like its charging as the screen is showing this, but he's unable to get anything else working
If the battery had completely died, it takes awhile for it to come back to life as it charges. If you are using the supplied power adapter, it may only be doing a trickle charge on the battery and so when you try to Energize the Tablet PC, IT BURNS MORE JUICE (ELECTRICITY) THAN WHAT'S BEING SUPPLIED AND THEREFORE WILL NOT COME ON. Be sure that both charger & micro USB connections are Secure and then walk away from it. Maybe get a cup of coffee or something while a charge builds up in the battery. And even then, if you use the Table PC, it may still burn more Energy than what it has received and shutoff, again.
Using my personal experience, I bought a $20 charger from a gas station in Dandridge, TN and that thing put a powerful charge on my cell phone and also my Table PC and they stayed charged for quite some time. Unfortunately, it got left behind - plugged into a hospital bed where it probably remains to this day! I'll have to build a new one or let go a $20 bill and buy another one. That charger that came with the Tablet PC is garbage and now you can see why! Be sure not to overcharge your battery as that can be detrimental to it longevity.
~ PC-Doctor
Oct 29, 2013 | Tablets & eReaders
My Nextbook 7 won't turn on
Every tablet has a button sequence, the reason being for a fresh restart. Either you unplugged it before full recharge, or didn't use proper charging adapter or cable.
There is a solution to avoiding this but first get tablet started by:
Hold power button and volume up button for eight seconds, release and hold power button again, tablet should turn on.
If not, do the opposite hold power button, volume down for eight seconds, then power button. You need to do this with proper adapter and charger you tablet came with plugged in. You may also need to do this more than once.
Once your tablet has started up, the way to avoid this is to swipe right on screen until you see settings app, should be round looking similar to a sprocket, or clock gear.
Open settings / display / sleep. I set mine for 30 mins.
Now you no longer need to power off you tablet manually, thus skipping the button sequence process.After unplugging from charge adapter you will still need to press power button to start.
Hope this helps I have yet to have this problem again, and remember to always let your tablet fully charge before disconnecting.
Jan 11, 2012 | Tablets & eReaders
Lexibook SERENITY 8 inch Tablet with 8GB Memory Logo
27 people viewed this question
Top Lexibook Tablets & eReaders Experts
Are you a Lexibook Tablet and eReader Expert? Answer questions, earn points and help others
