Question about Music
My clavanova cvp-96 sustains all the time, pedal up or down. Pedals have normal mechanical action. It started intermitant but now all the time.
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • Music Expert
  • 128 Answers
You could try this ( some pianos determine polarity when turned on if pedal is plugged in )
1.Remove the pedal from the keyboard. Turn on without inserting pedal. Plug in pedal whilst turned on. If it works you're done.
If it is still backwards go to step 2.
2. Remove the pedal. Plug in the pedal. Turn on. Try it. If it works you're done.
If not go to step 3.
3. Buy a genuine Yamaha product or a switchable pedal.
Posted on Nov 26, 2014
  • Becketts Music Ltd
    Becketts Music Ltd Nov 26, 2014
    Sorry wrong reply this was based on a P90 shown in the question lower down. This will almost certainly be either a broken cable or rubber dome switch found inside the pedal assembly.
    Contact me if you need more info on parts etc. www.beckettsmusic.co.uk
SOURCE: Sustain pedal not working on my Yamaha P-90
What I figured out is that when i turn on the keyboard, if i hold down the pedal by accident, it will work in reverse. I dont know if this is what you mean. If it is, just dont touch the pedal when you turn it on. If it isn't, try to return the pedal. I dropped one, it had this problem, and they gave me a new one. Your cord for it might have been bent (?). Also, turn the keyboard on with the pedal already plugged in. It's not made to be plugged in while it's on. Hope this helps. - Matthew
Posted on May 15, 2009
  • 4 Answers
SOURCE: Roland DP-2 pedal not functioning correctly.
There are two types of damper pedal switches, on that is closed until you press it, and one that closes when your press it. It sounds like your Casio is expecting one type and your Roland pedal is the other type. A quick way to test this is to plug a guitar cable into the Casio pedal input and see if the keyboard sustains. If it does, then your Casio requires an "normally closed" switch.
Some pedals have a small switch near the cord or even on the bottom of the pedal that will reverse the switching operation (BOSS pedals, a division of Roland, have this feature). If you can find that, then change the switch position and you should be OK.
If not, and you feel like digging into your pedal, you could take the bottom off of the pedal and check out the switch itself. Many pedals use a switch that can be used either way. The clue will be on the switch itself. If there is an extra tab on the switch that is unused, then switch the wire that is furthest away from that tab to that tab. This will probably involve soldering, but it is nearly impossible to damage anything.
If moving the wire that is furthest away does not do anything, then try putting that wire back and switching the other one.
If your pedal does NOT have an extra tab, you're SOL, unless you want to buy a replacement switch (unsure of make). If this is the case, you are probably better off getting a different damper pedal - preferably one that is marketed as "universal"
Posted on Jul 02, 2009
  • 4 Answers
SOURCE: Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Posted on Aug 15, 2009
  • 1138 Answers
SOURCE: Ensoniq KT-88 - sustain pedal works opposite the way it should
Usually that indicates that the polarity of the jack for the sustain pedal has been switched or someone has substituted another pedal with the wrong polarity. Try looking in the manual to see if that is an editable parameter for people who might not be able to obtain an original pedal. You may have to initialize the keyboard which is on page viii of the manual. The jacks on the back for footswitches are on page 1 and 2. The footswitch settings are on page 9. I found the manual here:http://soundprogramming.net/manuals/Ensoniq_KT-76_KT-88_Manual.pdf I don't know if you have the single footswitch or the optional stereo footswitch. If it is the single footswitch, the default setting should work correctly if it is the original SW-2 or SW-6 pedal switches. If it is the optional SW-10, the FTswL setting should be Unused. Hope this helps.
Posted on Aug 17, 2009
  • 4090 Answers
SOURCE: The sustain is on all the time.
The pedal activates a microswitch fitted to the circuit board. I suspect for some reason unbeknown to man and spirits this switch has become "stuck" or collapsed. If the latter then it has to be replaced as they are soldered to the board. You coulod open the unit trace the pedal back to the sustain switch and "jiggle" it manually to try and release it. A small amount of WD40 on your finger and rubbed over the pole of the switch( do not spray it) should help it to stay releaased until wanted. If you see corrosion on the board near the switch then take it to a music repair shop as this corrosion is like a cancer and will spread to other keys.Mice piddle is not unusual on keyboards and a great destroyer.
Please rate my help++++Thanks for using FIXYA
Posted on Dec 02, 2009
Is there a sustaining pedal Casio keyboard model ctk 401
Generally, all Casio sustain pedals are compatible with all their keyboards, but i normally recomend the SP-20. SP 20 Pedals Products CASIO
Apr 22, 2016 | Pedal Music
Are the currently manufactured Roland Home Piano series pedal assemblies compatible with the Roland HP237?
This wish an after market pedal, or the original 3's connector? If the keyboard is on when you plug and unplug that, it is likely due to a voltage reference getting confused. Usually when you get constant sustain then most likely a switch is stuck closed, or open, down there in the pedal. How these things work normally is that a pliable switch is opened, for sustain, or closed. It depends on the keyboard. Some keyboards have a setting inside them to accommodate both types of pedals, and some pedals have a switch to choose either. Your keyboard does not have a setting that I can tell, other than adjustments for a resonance option (nice feature). I am not sure the newer RPU-3 pedal is compatible, it seems to be for the newer models. If you are handy with a volt meter, then can check the cable's pins for a common, then a pin that changes with each pedal (use continuity mode, beeps when circuit is closed). Could be a piece of dust is in there, or hair or carpet stuff, and a good cleaning would fix that from blocking the normal function. Manual Link: http://media.rolandus.com/manuals/HP-237_OM.pdf
Aug 02, 2014 | Roland Hp337 Digital Piano
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
Hi, I hope can help me with this problem because I start to get desperate. I have a Clavinova CVP-85A. The sustain effect is always activated, whether the pedals are plugged in or not. I read that to...
It sounds like the inputs from the pedal switches are "floating", that is, not pulled up or down and they are drifting across the logic threshold. If I could find a schematic I could direct you right to the problem. For now, check the voltage across the switch contacts with a high impedance meter. Also check the resistance to ground of the common of the contacts. Without a schematic I am afraid to have you try things lest I direct you to do something that would cause damage.
Jun 07, 2011 | Yamaha Music
When i plug in my sustain pedal instead of it sustainin when i step on the pedal it works in reverse so now when i step on the pedal it stops the sustain
Roland requires a pedal that is normally closed, open sustains. MOST pedals work the opposite. SOME pedals you can open and rewire... but not all can be.
Mar 26, 2011 | Roland Juno-D
When i plug it in to the sustain slot in my yamaha keyboard it makes the notes longer without me pressing the pedal.
You may have a pedal that is ROLAND compatible which is OPPOSITE sense from what the Yamaha requires. The Yamaha takes a NORMALLY OPEN contact.
Some Yamaha keyboards such as TYROS have a parameter that you can set to permit using either type pedal.
Some pedals have a switch to change them to use with either type keyboards.
Feb 22, 2011 | Quik-Lok Quik Lok VP-26 U Sustain Pedals
Hi, i purchased yamaha fc15 sustain pedal yesterday. when i connected this pedal to my Roland E-09 keyboard through foot switch port, it activate Start/Stop button ( of arranger & song controls ) and...
The answer is NO... Roland uses the opposite sense switches on foot pedals... They use NIRMALLY CLOSED and your Yamaha is a NORMALLY OPEN switch.
SOMETIMES you can open these pedals and find that the pedal has the opposite sense switch available and you only have to unsolder and move one wire to make it a NORMALLY CLOSED pedal.
Dec 24, 2010 | Yamaha Fc5 Sustain Footswitch
I do not have a problem. I just want to buy a "sustain pedals".
The only thing to be concerned about is which polarity pedal.
Roland typically requires NORMALLY CLOSED pedals while some other brands require NORMALLY OPEN (press to sustain)
Sep 07, 2010 | Yamaha Music
The foot pedals don't seem to work when start/stop and fills. have had it looked at but it seems to work for them and nopt for me. had another one of these years ago and never had any problems. This one...
Are you using foot pedals that came with it? If you use other brands they MAY not be compatible.
For instance, Roland sustain pedals are backwards action of some other brands. Some are normally closed, some normally open.
Nov 04, 2009 | Alesis Sr 16 Stereo Drum Machine
Jul 02, 2009 | Roland Dp 2 Damper Pedal
Music Logo
60 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
