Question about Kitchen Ranges
When I use the oven, after some time the fan comes on and the sound is disturbing to people around...cant even talk.....it comes on even after its switched off...is this normal ?
Workingwise...there is nothing wrong. it works fine.
    Prodigy:
    An expert who has answered 500 questions.
  • 650 Answers
It is common for a cooling fan to come on after a few minutes of operation of the oven. If it is very noisy it may be a bad motor and need replacing. It shouldn't be very loud.
Posted on Nov 15, 2014
4 Suggested Answers
SOURCE: Oven failure
Panick Over!!
We had to pull out the oven and discovered the problem was a blown 3amp fuse in the plug at the back of the cooker! A bit of a scramble for a spare fuse but at least we're back in action!
Posted on May 27, 2008
javeedcare
  • 316 Answers
SOURCE: nothing on my lofra oven
Hi You need to check out the fuses and the power supply. Dont forget to check the power point as well.There seems to be no power supply to the unit.
Regards.
PLZ. dont forget to rate my suggestion.
Posted on Jul 19, 2011
SOURCE: door locked
Your door lock mechanism failed. Needs to be replaced
Posted on Apr 11, 2013
When i use oven ...after sometime the fan comes on with a noise and its very disturbing to poeple around. Otherwise it works fine. is this normal ? I don't like noisy fan coming on.
It sounds like you have a faulty fan motor it is important you replace it immediately or if it stops your element will blow costing a lot more, so just replace the fan motor should sort the problem
tk
Nov 14, 2014 | Ovens
Fan stays on without cooking or starting
Sounds like a door switch problem. Relays can stick too so tap them to release, they may need to be replaced
Nov 24, 2013 | Sharp R-1610 Microwave Oven
Remove fan motor
Have more children (I cant even hear myself think)
>> design problem, not going to fix it with new parts..... ear plugs?
Oct 16, 2013 | Belling Ovens
I am facing some disturbing sonds like air/wind's sound while calling with G.Talk... pls help me to solve this prblm.
The sounds could be coming from an open window a fan or just general noises from where you are.
May 09, 2011 | Google Talk
Bosch HBN 70 Fan oven will not heat up to temperature, fan and light are working just no heat
99% of the time the problem will be a faulty element or burnt off wire at the element terminal. Best way is to pull the back cover off the oven and check the terminal connections. If these are okay put a set of test lamps across the terminals and you should have 240 volts. If you have 240 volts this tells you that the wiring is okay and the element is faulty. When you turn the oven setting to fan forced selection the power is delivered to the fan forced fan motor and the oven element at the same time. I am not familiar with this exact oven but most fan forced ovens have two fans. There is the fan at the back of the oven that comes on with the oven element and then the extractor fan in the cavity of the oven, which you cannot see but can hear. I trust you are talking about the fan forced oven fan which is generally at the back of the oven.
Feb 05, 2011 | Bosch Kitchen Ranges
I have an GE Eterna Microwave Model Number: EMO3000HWW01 The microwave resets itself after aboout 10 seconds of use. Before it would do this and we would reset the time and date and it would work for...
It may be that the internal cooling fan is not working or the filters or air duct may be clogged, but it may also be a "noisy" magnetron.
First, check the filters. Then determine if the internal cooling fan is coming on.
I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
If that is working, and you have good air flow, then see this FixYa solution.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Sep 07, 2010 | GE JVM1650 1000 Watts Microwave Oven
HELLO MY FAN OVEN STOPPED WORKING ALTHOUGH THE ALL OVER FUNTIONS ARE OK. WHEN I TURN THE FAN OVEN ON I CAN HEAR THE SOUND OF THE FAN BUT THERE IS NO HEAT EVEN AFTER A LONG PERIOD OF TIME.
If it is an eletrically heated fan oven, thei it sounds like the oven element has failed.
This is usually located at rrear of oven behind a removeable cover.
Hope this helps you.
Dec 06, 2009 | Ovens
Fan Oven cooks at high temp when on any setting
Sounds like main oven stat is faulty.
Is the stat sensor fixed properly inside the oven?
Could have been disturbed when element fitted
Please leave feed back.
Thanks
Nov 25, 2008 | Jenn-Air JJW8530C Expressions Collection...
Fan won't turn off even after day and disconnecting power a number of times
if you talking about you convectin fan you proably have a stuck realy in the control bd and will need to replace it
Jan 30, 2008 | Dacor Epicure 30" Double Wall Oven,...
Kitchen Ranges Logo
103 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
