Question about Casio Privia Px-130 Px130 88 Key Digital Stage Piano Nu
<!-- from fixya rte -->Where is the power fuse located - Casio Privia Px-130 Px130 88 Key Digital Stage Piano Nu
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 28 Answers
Insidr near whete you plug the power in
Posted on Nov 26, 2014
SAMICK Digital Panio SGP-151G fuse location
try opening the back cover, usually located on the power supply, u should have a little knowledge in electronics as some fuses come in form of fusible resistors. not the usual fuses we are used to,
Sep 06, 2016 | Samick Music
I have my adapter plunged in and the power want come on what can be the problem. Is their a fuse
You don't mention what specific make and model instrument you're asking about, but yes, in general most electronic instruments have a fuse. it's normally on the power supply board which will be located close to the power supply input.
However, often the problemm will be a bad power suppply rather than the instrument. i suggest you put a voltmeter on the power supply to make sure it's operating correctly.
Nov 07, 2015 | Music
My fender cybertwin amplifier wont switch on where is the power fuse..
remove the amp. section from the cabinet. you should see a fuse inside near to the main switch.
Nov 22, 2014 | Fender Music
Where is the fuse located in a marshall ma100 h amp head
The fuse should be located on the back panel near the power cord. However, there are also internal fuses as well....If the amp is vacuum tube you will also have a HT fuse as wall as a power fuse. If it is a solid state unit then it will have a power fuse.. Hope this helps.....If you need more info let me know....
Jan 16, 2014 | Marshall Amplification Marshall MA100H and...
Numark C3usb - how to replace a fuse
Trace the inout power wiring. You will find a fuse someplace very near where the power comes in. Note that they MAY be one of several types that don't look like common glass fuses. ALSO a common thing is that the fuse is in a little "boat" that is right adjacent to where a standard line cord like on tower PC's use. This boat has to be pried out to get at the small fuse in it. Choose the right size fuse for the 230 v operation.
Mar 04, 2013 | Numark Industries Numark C3usb Rack Mount...
Keyboard not powering up. Want to change the fuse/s. Don't know where fuse is located.
There probably is NOT a fuse and usual cause is problem with the adapter or the power connectors. Broken solder of the connector in the keyboard is common. Broken cords on the adapter is common as well.
Oct 29, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Hello, I recently bought a Mackie Profx8 mixer here in the UK and I cannot locate the fuse. The AC socket does not have the fuse tray underneath (unlike my Mackie speakers) and there is no indication...
Essentially if the fuse goes, the unit is rendered useless until it is repaired. Replacing the fuse without repairing would likely cause further damage in the unit. Fuses blow for a reason that is usually a failure in the unit. Failures don't fix themselves. The ability to replace the fuse is therefore a moot point. To keep your unit safe ALWAYS power all interconnected equipment from the SAME power receptacle or conditioning module. This means running extension cords to powered speakers if that is what you have to get power the mixer. Powering mixers at one end of a room from a receptacle and the amps or speakers from a recpetacle on a stage at the other end will likely damage you equipment when a ground fault occurs or ground bounce in the building wiring ruptures the sensitive input/output circuits of your equipment.
Jun 18, 2011 | Mackie ProFX8 / TH-15A PA Package
Does it have a fuse and if it does where is it located? Power blew and now it won't turn on.
Fuse is internal and unit needs to be repaired BEFORE replacing fuse as additional components may be damaged if fuse is replaced before repair is done.
Jan 15, 2011 | Line 6 Spider Iii 75 Guitar Combo...
I need to replace the fuse for a used Marshall MG100HDFX that I bought. Where is the fuse located inside the head?
If the fuse is blown make sure the reason it blew is repaired before replacing the fuse. Start the amp up after replacing it with a 100 Watt light bulb in series with the hot side of the power into the unit. This will act as a current limiter to verify it is repaired and will not blow the fuse. When you open the unit the fuse will be obvious... Follow the hot side of the power cord, through the switch to the fuse.
Dec 08, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
We are not getting any power from out Fender 15G amplifier
Some amps do have a small buss fuse located in the back of the unit, but this will usally be only to cut the power to the amp off, if you are sure you have no power, i.e. no lights are on as well then the fuse could be blown, if you find it MAKE SURE THE POWER IS DISCONNECTED BEFORE REMOVING IT and replace it with exactly the same type, but first make sure all controls are up even the ones on the instrument.
Mar 17, 2009 | Music
Casio Privia Px-130 Px130 88 Key Digital Stage Piano Nu Logo
71 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
