Question about Apple iPod classic MP3 Player
I need to reset code for iPod but have new computrr
    Sergeant:
    Champion:
  • Apple Expert
  • 203 Answers
Posted on Feb 04, 2015
Password forgotten now say's disabled
Unlock a Disabled iPod
If you own an iPod Classic or iPod Nano, you can set a four-digit security code on your device and then lock it to keep other people from accessing it.
Disabling your iPod is a good way to protect the data on your device, but if you lose or forget the four-digit code, you will need to manually unlock it in order to access your music and other content.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
Or
Hard Reset a Disabled iPod Touch
A hard reset restores your iPod Touch to its original factory settings.
This is useful when your iPod Touch is disabled and won't turn on or off, but all your data is erased.
Luckily, you can restore your data with iTunes after you've performed the reset.
Once you've performed the reset, your iPod is wiped clean and iTunes prompts you to restore the settings from your last sync.
Plug the iPod into your computer and wait at least 10 minutes.
This allows the battery to recharge in case it has drained.
This could fix your disabled iPod, if the problem was caused by a dead battery.
Click "OK" if your computer opens a "Connect to iTunes" alert box.
Depending on your version of iTunes, the message may indicate the iPod is in "recovery mode" and you need to restore the device.
ITunes opens and resets your iPod for you.
Unplug the iPod from your computer if you don't see the "Connect to iTunes" alert box.
Make sure the iPod is charged before you attempt the hard reset.
Press and hold both the On/Off/Wake button and the Home button on your iPod.
Keep the buttons pressed.
Wait for the Apple logo to appear, it may take 10 seconds or longer.
When you see it, release the On/Off/Wake button but keep the Home button pressed.
Release the Home button when you see a picture of a USB cable with an arrow pointing to the iTunes logo.
Plug your iPod back into the computer.
The iTunes "recovery mode" message will appear.
Click "OK" to complete the reset.
http://support.apple.com/kb/HT1808iOS: Unable to update or restore
Jul 30, 2013 | Apple iPod touch
Ipod is disabled
Attach a USB connector to the iPod and plug it into a USB connection on a computer for power, or into a stand alone USB charger plugged into a power strip for electrical power.
Pick up the iPod. Move the "Hold" switch at the top of the iPod to the "Locked" position so that an orange color appears by the switch. Return the switch to the "Unlocked" position.
Repeat this process.
Press and hold the "Home" button and the button at the top right corner together if using a fifth generation iPod, iPod Nano, iPod Mini or iPod with a click wheel.
Press and hold the "Menu" button and the "Play/Pause" button together if using an iPod Touch. Press and hold the "Menu" button and the "OK" button together if using an older iPod.
Continue holding the buttons together until the screen flashes and then displays the iPod name and the Apple logo.
Release the buttons.
Wait as the iPod resets itself and turns itself back on.
or
hope this helps
Sep 15, 2012 | Computers & Internet
DESBLOQUEAR PANTALLA
How to Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod. In order to use the device's functions again, you need to enter the correct code. However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Things You'll Need:
iPod Nano Mac or PC computer iPod USB cable
1 Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
Jan 05, 2012 | Apple iPod nano
Enter code i pod \
Hi
Things You'll Need
Dec 30, 2011 | Apple iPod nano
I need to know how to reset my ipod because for some reason I can't get in itunes it want even let me create a new account all it keep saying is sorry can not connect to itunes so i already tryed to reset...
1. Read this this from Apple "How to reset iPod" @ http://support.apple.com/kb/ht1320 , and
2. Restoring iPod to factory settings @ http://support.apple.com/kb/ht1339
Since you cannot acess to your code, you have to reset your ipod back to factory default, but all your data on your ipod will be lost!!!
Hope it helps.
Jul 05, 2010 | Computers & Internet
My daughters IPOD NANO is asking for a 4-digit code. She says she didn't set a code for it and I can't find the instructions.
  • Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
  • Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
  • Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
    this should get ya going again
  • Sep 25, 2009 | Apple iPod nano
    My dumb ipod volume code:(
    use itunes to roll back/reset ipod you will have to replace all info back on ipod after it resets but should take care of it my sister gave me an ipod without giving me code
    Aug 18, 2009 | Apple iPod nano
    Ipod nano security code
    Try this:
    1. Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
    2. Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
    3. Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
    4. Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
    http://www.ehow.com/how_4793090_unlock-ipod-nano-code.html
    Apr 01, 2009 | Apple iPod nano 3rd Generation
    Asap
    Reset the ipod. Using the computer and ipod. If you do not how to do it, follow the steps to it.
    1. Connect the USB between the computer and ipod. Be sure to have the latest version of itunes
    2. Go to the ipod summary and click restore. Be sure to back up everything.
    Note: Because you need to reset the ipod. Any files will be erased. Be sure to backup any files, Like i said above on step 2. After it resets, you can put it back to normal.
    3. After a couple of minutes waiting for ipod to reset to factory settings. Put the name on and customize your settings.
    4. Now, you can put back files to the ipod so it is ready to use.
    Note: It is not necessary to put a code. It is easier to pick a easy code than rather picking a hard code. Or don't pick a code for ipod.
    Oct 26, 2008 | Apple iPod MA446LL/A MP3 Player
    How do i reset my nano ipod password ive tried the apple instructions?
    ---If you do this you won't lose music"---
    Well I went to my computer clicked my ipod and when the folders came up you go up top to "tools and folder options" and go to the tab that says "view" and click the one that says "show hidden folders." Then click "ipod control" then "Device" and delete the file that says "_lock" or something on that line. If you any questions email me at wolffa@mhs-pa.org
    Dec 25, 2007 | Apple iPod nano
    Apple iPod classic MP3 Player Logo
    51 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
