Question about Garden
Difference between Universal Farmliner 640 tractor & Farmliner 640 DTC
2nd hand Farming tractor
Is it still possible to get parts for fwd add on to massey 135 I know these are rare but there must be some in existence surely
contact a massey service dealer and discuss the availability
failing that check for tractor wreckers/ junk yards to see if there are any being wrecked that have good parts
if you are in a farming area , many tractor dealers will know of tractor wreckers in the district
Aug 17, 2016 | Toys
What is the essence of farming?
Farming is a single name but it has various steps to do for getting final product.
The soul of farming is the fertility of land, watering and pesticides in right time. Today various technologies and equipment present in the market, to improve the cultivation of products.
Currently Chhattisgarh's Agriculture Minister and irrigation minister is Mr. Brijmohan Agrawal . He has taken various decision to improve the economic or financial state of farmers.
Mar 25, 2016 | Motorcycles
Pto won't disengage, unable to start tractor. pto attached to post hole digger in ground
It could be gear bound and not allowing it to disengage, i experienced that a few times in my farming days, we dug a lot of postholes with a PTO driven digger. What usually happened is i ended up getting caught on rocks and stalled out because i had the engine speed to low. What i generally had to do to fix it was remove the PTO shaft from the digger, disconnect from the tractors output shaft, then get it started and everything moving, then disengage the PTO and reconnect the post hole digger, then give her hell and get the engine speed up before re-engaging the PTO, that would generally shock it loose. If not then i would have to disconnect the PTO shaft again and spin it backwards by hand to rotate the digger in the opposite direction to remove the hangup.
Nov 25, 2015 | John Deere 670 770 870 970 1070 Compact...
How do I get to three point hitch to apply down pressure on the implementI
3 Point Equipment - Tractor Supply Company
www.tractorsupply.com/tsc/.../3-point-equipme...
Tractor Supply CompanyTSC has 3 point tractor disc, trechers, forks, attachments and implements for sale every day. ... modern farming as much as the adoption of the three-point hitch.3 Point Landscaping & Utility ... - ‎3 Point Cutters & Hay ...
Oct 01, 2015 | Toys
What is the difference between a pitchfork and a trident?
Not really, a trident only has three prongs and is used predominantly for fishing, while a pitchfork anywhere from two to six tines and is used for farming, like moving hay.
Jan 28, 2014 | Garden
Service manual for UTB Farmliner 640CDTSD tractor
Hi, I have a manual for the Universal U550M/U640 Tractor if you're still interested. 63affd7a-81a7-4870-acce-b383ea860443.jpg
Dec 02, 2011 | Garden
I have a Ford 3500 backhoe year is mid 70's. I need to replace the transmission fluid. Any idea what tyoe of fluid?
Officially, it's listed as M2C53A trans & hydraulic oil. Hope you can track down an equivalent where you are
Apr 11, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Clutch rather heavy to pull in and already bleaded still no difference
Try the adjustment at the far right hand side of the clutch handle, wind it all the way in and then secure with the locking nut, if no change also try at the box housing end of the cable there will be an adjusment there too.
Oct 30, 2009 | 2005 KTM 640 LC4 Adventure
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
