Question about Microwave Ovens
I have a sticky door release button. It still works but it pops back out very slow. Any idea as to how to free it up?
    Master:
  • 623 Answers
Clean the latch and hinges with a good detergent cleaner then lubricate with food-grade silicon spray.
Posted on Nov 14, 2014
Thermador Microwave Door Sticky
By sticky do you mean as dirty or not working properly. If the door sticks squirt a little WD40 in all the working parts like hinges and latches and try that.
Apr 10, 2015 | Thermador Microwave Ovens
The door no longer pops open when the latch button is pushed. How do I fix this?
One of the door latch arms or the latching mechanism inside the oven have broken. you may have to buy a complete door lock / latching assembly . Might not be worth it. Check with your nearest parts supplier.
Apr 09, 2015 | Emerson Microwave Ovens
Microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Jul 19, 2012 | Samsung SMH9187 Microwave Oven
Door release does't work
It may be a broken door open button, door open lever, or grease in the channel where the door open button moves in the control panel frame.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
You can order Panasonic parts from Encompass here but without part numbers, it may be best to call them toll-free at 866-779-5835.
Dec 20, 2011 | Panasonic NN-H275 Microwave Oven
Hi, the button to open the door not working properly, I am able to press the button in but it is not releasing the door. what should we do?
This sounds like the door release may have broken (duh!) It may be that a peice of plastic has broken or maybe a spring has come off.
It may be an idea to have a quick look inside the microwave to see if you can see any broken parts near the door release... in some cases it is possible to re-glue broken plastic. Do not use super glue as this will not hold plastics properly, you need "evo stik - hard plastic adhesive" for this job.
BE VERY CAREFULL WHEN GOING INSIDE YOUR MICROWAVE! not only does it contain lethal voltages (even when turned off and unplugged), but if you do not put it back together properly you could have microwave leakage which is not good.
Given the prices of microwaves these days it may be nearly as cheap to buy a new one as pay a microwave expert to fix yours.
Mar 06, 2011 | Microwave Ovens
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Sharp R-9h91B microwave oven stopped working
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Sep 28, 2008 | Microwave Ovens
Whirlpool Microwave GT4175SPS0 - door button is jammed or spring broken. I cannot open the door anymore and there is food inside the microwave. Any ideas?
This model appears to be a counter top model (if not, please reply back, since procedure differs).
You will first need to unplug the unit and remove the outer cover.
Then you'll be able to see inside where the door open button presses on the release lever, which lifts up the hook-like projections (latches) on the door so that the door will open.
Usually the part that breaks is the release lever.
You can find helpful exploded views for similar models (such as the GT4185) here, but your best bet is to call the number at that site.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 26, 2008 | Microwave Ovens
Panasonic microwave start button
You may have a sticky door switch. Try a simple "slamming" of the door, don't over do it, just a little harder than normal. This may help pop the plunger in the switch back up. The switch could have also become loose and moved out of its adjustment.
If this does not help, a technician should save you time and money with this sometimes perplexing problem.
May 22, 2008 | Microwave Ovens
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
