Question about Cuisinart CMW-100 Microwave Oven
Electronic buttons work, countdown timer, etc. But microwave is not warming
    Prodigy:
    An expert who has answered 500 questions.
  • Cuisinart Expert
  • 650 Answers
This is usually caused from a bad magnetron. Check the door switches first.
Posted on Nov 15, 2014
Microwave quit working, timer, number buttons timer, all functions on micro side of control panel quit working , timer numbers start etc.
Check to see if the fuse went. If negative then something is wrong with the electronic pad for the unit.
Nov 25, 2015 | Microwave Ovens
How do you use the kitchen timer and cook at the same time?
If you have the kitchen timer set for instance for 10 minutes and it is counting down, and then you want to reheat you coffee for 2 minutes. You would hit either time cook or reheat button and enter 2 minutes ten hit start. The microwave will heat your coffee and show the 2 minute countdown for that. When done it will revert back to what is left on the 10 minute kitchen timer without missing a beat on most microwaves.
Feb 26, 2015 | Microwave Ovens
Emerson MW7300W7 acting strange.
You may have multiple problems with this unit. All of them might have been caused by a loose connection on the power cord. If current is abruptly interrupted when it is running, any component which contains a coil of wire (transformers, relays, etc.) will generate a voltage spike. These spikes can take out sensitive electronic components. I suspect that is what happened to this oven.
Apr 29, 2014 | Emerson Microwave Ovens
Our Magic Chef microwave timer counts down, but no longer cooks
Probably not because the timer works.Try the door switch.
Jul 03, 2012 | Microwave Ovens
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
OK, so our microwave stopped working. All the electronic parts are working (lights, timer, turntable, etc...) however the microwaves aren't being produced (nothing ever warms up inside.) This was...
the problem could be with 2 component. The diode or the magnetron. normally when the diode goes bad, the microwave will make a humming sound. The microwave will tend to sound almost normal when its the magnetron. Or sometimes it will make a sparking noise when put to heat.
Feb 26, 2011 | LG LRM2060ST Microwave Oven
When I set the timer and close the door, the door latches fine. When I push the start button the timer starts to countdown but the microwave doesn't start. If I push the door release in about 1/8 " ,...
If your model number is in the Sharp R-1500 series, then that's a problem with the bottom door switch or its mount.
See these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
Jan 14, 2011 | Sharp R-1511 Microwave Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
May 25, 2007 | Emerson MW8168B Microwave Oven
Cuisinart CMW-100 Microwave Oven Logo
348 people viewed this question
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
noel
noel
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
