Find the 8 digit pin - Televison & Video
    Scholar:
  • 152 Answers
Call the manufacturer and ask for the overide code
Posted on Nov 26, 2014
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Feb 16, 2017 | Chevrolet Express Cars & Trucks
Tip
How to find the PIN code of Cell Phone
Hello <br /> Personal identification number (PIN), is a secret number that is used to unlock the phone, unlock in the sence of accessing the device you are using. It is made up og 4 digits that is giving to you when you buy a phone number. It comes with your phone number not with the device, so that means you can still use the same pin on different mobiles. But always remeber your pin number because if you lose it then your phone will be probably blocked! <br /> Following are the some ways to find the pin code: <br /> Enter the last four digits of your phone number on your cell phone PIN screen. When setting up a cell phone PIN, the default number assigned is the last four digits of your cell phone number for most cell phones. <br /> Enter 9999, and if that doesn't work try 1111. The number sequence 9999 and 1111 are other standard numbers assigned when choosing a cell phone PIN. <br /> Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number under the battery. Reinsert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen. The last four digits on your IMEI number can occasionally be the service provider's preset PIN for the cell phone. <br /> Call your service provider and request the PIN. You will have to prove you are a customer by stating your cell phone number, address and NIC number. <br /> Hope this helps, if so do rate the Tip.......
on Feb 01, 2011 | Cell Phones
My harley wont start
Key fob MUST be present near bike!
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
TO ENTER NEW PIN:
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
Aug 10, 2014 | 2011 Harley Davidson FLSTC Heritage...
How do you access trouble codes on 2003 harley davidson deuce?
With the newer HD Security Systems using proximity FOBs where the key FOB needs to be close to the bike to start, this is now more important then ever. If the battery in your FOB dies and you have not set your Harley Alram Override PIN Code, you will not be starting your bike. It is just as important for those with oler Harley Davidsons with the push button alarm FOB. It you set your alarm and the battery dies before you return to your bike, again you will not be starting the bike.
If you haven't set the PIN over ride for your HD security alarm system...do it now! Here's how you do it...
(To view how to deactivate the security system with the manual PIN code, see below.
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
May 20, 2014 | 2003 Harley Davidson FXSTDI Softail Deuce
Bike will not turn over, security icon flashes alone with the turn signals. Battery test OK.
Have you used the new PIN to manually disable the security system?
Do not turn handlebars, straddle seat or lift motorcycle off the jiffy stand. During a PIN disarm, if the security system detects motorcycle motion the system will activate.
Turn ignition to IGN.
If armed, the odometer window display will read: ENTER PIN and the security lamp will be flashing at a fast rate. The headlight will not be on.
Press and release the left turn signal switch.
In the odometer window, a flashing 1 will appear.
Increment the digit by tapping the left turn signal until the odometer window displays the first digit of the PIN.
The first digit in the odometer will be the first digit in the PIN.
Press right turn switch 1 time.
The first digit is stored and the next digit will flash.
Increment the second digit using the left turn switch until the digit reaches the second digit of the PIN.
The second digit in the odometer will be the second digit in the PIN.
The second digit is stored and the next dash will flash.
Increment the third digit using the left turn switch until it reaches the third digit of the PIN.
The third digit in the odometer will be the third digit in the PIN.
The third digit is stored and the next dash will flash.
Increment the fourth digit using the left turn switch until it reaches the fourth digit of the PIN.
The fourth digit in the odometer will be the fourth digit in the PIN.
The fourth digit is stored and the next dash will flash.
Increment the fifth digit using the left turn switch until it reaches the fifth digit of the PIN.
The fifth digit in the odometer will be the fifth digit in the PIN.
The fifth digit is stored. The security system indicator lamp stops blinking.
Smart Security System is disarmed.
If a mistake is made while entering PIN, turn the ignition Switch to OFF before entering the last digit and then start the procedure from the beginning.
If the procedure fails to disarm the security system, wait two minutes before attempting another PIN disarm.
The security system will remain disarmed until the ignition is turned to OFF.
Apr 04, 2014 | 2005 Harley Davidson FLHTCUI Electra Glide...
How do i reset a pin number on a harley
With the fob present, turn IGN switch:
IGNITION-OFF-IGNITION-OFF-IGNITION
Press LEFT turn signal switch 3 TIMES
Press RIGHT turn signal switch 1 TIME and release
Turn signals will flash 3 times. Current PIN will appear in odometer. The first digit will be flashing.
If changing PIN, enter first digit (a) of new PIN by pressing LEFT signal switch (a) time(s) i.e., for the number 1, press one time. for the number 5, press 5 times.
Press RIGHT signal switch 1 TIME and release.
the new digit (a) will replace the current in odometer window.
Enter second digit (b) with LEFT signal switch.
Repeat until PIN is set.
Apr 16, 2013 | 2009 Harley Davidson FXD Dyna Super Glide
How do you reset the Pin on the Hot Focus Pink Digital Safe
Hot Focus Pink Digital Safe pin reset instructions:
1) Hold down the star button (do not let it up until the process is completed). 2) Press a four number code sequence. 3) Press the pound key. 4) Release the star key.
Nov 25, 2012 | Toys
Lost key fob how to turn off alarm?
You'll need the PIN number.
If you don't know it, you'll have to change it to a 5 digit PIN number you select.
Once PIN is set (either new or old PIN), to disarm security system, DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Turn IGN to IGNITION.
Quickly (within 2 seconds) hold BOTH turn signal switches until confirmation signal (KEY icon flashes at fast rate, in odometer window, a flashing "-" will be followed by 4 more dashes = "----")
Enter 1st digit (a) in PIN by pressing LEFT turn signal switch (a) times (i.e., 5 times for the number 5)
The 1st "-" will become the 1st digit (i.e., "5")
Press RIGHT switch signal 1 TIME.
The 1st digit is stored and the dash will flash.
Enter 2nd digit (b), and repeat sequence until done.
After the 5th digit is entered, the KEY icon stops blinking, and the system is disarmed.
The system will stay off until the IGN switch is turned off.
If at any time during disarming sequence an error is made, wait 2 minutes before trying again.
Nov 06, 2011 | 2008 Harley Davidson FLHR Road king
Dvi port specification
The DVI [Digital Visual Interface] is a standard for high-speed, high-resolution digital displays.
Below is a 24 Pin DVI Female connector seen at the Computer. The connector diagram and pin-out table show a DVI-I Digital and Analog [RGB]; 29 pins [modified D style] connector. A DVI-D Digital only connector with 24 pins [modified D style] looks about the same with out the 4 analog 'C' pins.
The DVI interface is found on a number of devices including TVs, Computers, Monitors, and Video cards.
Digital Visual Interface [DVI] was developed by the Digital Display Working Group (DDWG).
Note that the Digital Display Working Group disbanded around 2006, so don't expect an up-grade for DVI.
Digital Video Broadcasting/Digital Audio-Visual Council (DVB/DAVIC),
developed by DAVIC [inactive] and DVB [dvb.org].
Adopted by European Telecommunication Standards Institute (ETSI) and
International Telecommunication Union (ITU)
DVI has a number of different types connectors:
DVI-D Digital only connector; 24 pins [modified D style];
DVI-A Analog only; [modified D style], I don't think this is part of the standard
DFP Digital Flat Panel, Digital only connector. Pinout is listed on the DFP page
Styles of DVI Connectors
Jan 13, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Security system FOB inactive, battery good, no pin. Need to disarm. What can we try next?
Sep 05, 2009 | Harley Davidson FLSTFI Fat Boy Motorcycles
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
