Question about Janome Memory Craft 9000 Computerized Sewing Machine
Why is bobbin thread showing through on pattern
  • Janome Master
  • 631 Answers
You need to loosen the top tension. if you notice the tension is too loose on top and bottom at the same time then go ahead and tighten the bobbin tension a small amount. then you can adjust the tension of the top. if the top thread tension is too tight the thread from the bobbin will penetrate through. the opposite is true. if the top is too loose then too much of the top thread will penetrate the fabric underneath. remember to get the tensions between the top tension and bobbin tension equal so the knot will end in the middle of the fabric.
Posted on Nov 14, 2014
Bobbin thread shows on embroidery pattern
The bobbin thread is being pulled too hard by the top thread. The idea is to get an even pull similar to a tug of war. When it is even the thread will form a knot in the middle of the fabric.
To fix this so the top thread isn't pulling too hard lower the tension of the top thread. This should fix it.
May 08, 2015 | Janome Memory Craft 10000
When sewing, it jams up right off the bat.
try rethreading the machine top and bobbin
try turning the bobbin the opposite direction
clean under the needle plate and in the bobbin area for lint or loose
threads
make sure the top thread has not come off the thread take up lever
Jan 22, 2013 | Sewing Machines
Drop in bobbin on singer 6234 will not thread empty Bobbiin thread winds around underside od bobbin
try using a different bobbin and see if that helps, if it doesn't
then the machine may need to be checked to see if there is
something wrong with the hook and the hook race.
Nov 29, 2012 | Janome Jem Silver 662 Mechanical Sewing...
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
When emroidering, the thread from the bobbin is showing through on the top embroidered pattern. Any suggestions
Make sure to use bobbin thread for machine embroidery, it is heavier and pulls the top thread slightly to the back of the design.
You could loosen the tension or use a double layer of stabilizer.
Mar 05, 2010 | Brother PC8500D
I have a brother sewing machine but all the patterns come out with the bobbin thread showing
When you pull gently on the thread from the bobbin area, do you feel slight resistance? There should be resistance but it should not be tight. If the bobbin thread is in the bobbin case tension area properly and there is no resistance then you need to tighten the screw on the bobbin case to increase the tension on the thread. Do not tighten the top thread tension. To get to the bobbin tension screw on the case, some models require that you remove the needle plate and then the bobbin case. Some have a hole in the front housing that allows you to reach the screw without taking off the needle plate. Also make sure you're hooping the fabric tightly. When you snap the fabric when it's hooped, it should make a drum like sound. If the fabric is loose in the hoop, bad stitching will result
Nov 09, 2009 | Brother Disney PE-400D Computerized Sewing...
Bobbin on SE 350
Hi there, this seems to be a common problem with this machine. I have owned mine for a couple months now. The problem seems to be in the threading. The only solution I have found (and others on many forums) is to rethread the machine and the bobbin. I have also re-wound some problematic bobbins as they just maybe did not wind tight enough. Don't delete your patterns, that is not the problem. I have had proffesional patterns turn out a dozen times and then give me problems only to be fine once the machine decided it was threaded properly.
Feb 14, 2009 | Brother XL-3500
Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
clarkco
Feb 08, 2009 | White Sewing Fashionaire Sewing 2380...
Stitch pattern not proper
be sure that the thread is routed properly. Then check on the bobbin holder, it may be defective.
Sep 05, 2017 | Sewing Machines
Janome Memory Craft 9000 Computerized Sewing Machine Logo
99 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
