Question about Samsung Office Equipment & Supplies
When i turn on my printer it says (system initializing) why
I am not able to use the maching at all it just say system innitializing
    Sergeant:
  • 320 Answers
"System Initializing" means the printer is going through it's startup process. If it hangs, it usually means something is wrong with the printer.
Make sure all printer cartridges are seated properly and securely. Make sure the paper trays are pressed all the way in and locked into place, make sure all doors on the printer are closed and latched properly.
Unplug the printer from power completely and wait about 30 seconds. Plug the printer back in and power it on without being connected to a computer or network cable (if applicable since you did not post make / model)
If the issue continues, the printer may be faulty and need serviced or replaced.
Posted on Nov 21, 2014
Cannot connect to network. It show IP address 0.0.0.0
contact your service provide for assistance on how to set it up
Apr 28, 2015 | HP LaserJet P2015n Printer
2ooo Ford Mustang,Got MP538U TUNER work. cd look like it was playin no sound though.Exchanged it for MP638u.SAME BULL. cAR GOT ripped out mach system. Carstereo wires without harness
If you are wiring a Kenwood KDC-MP638U to a 2000 Ford Mustang, then below information may be of help:
  • to my knowledge, the original stereo unit uses 2 8pin connector and a single 7 pin connector;
  • if the connector with the harness has been cut, then wire splicing may have to be used based below;
  • If you are using external amplifiers, then it is possible to trigger/switch them with the blue/white wire and their RCA INputs connected to the appropriate RCA OUTputs of the Kenwood;
  • Additionally, the KDC-MP638U has built-in USB port/interface.
  • Incidentally, if what was previously installed is a full Mach system, pls be informed that there are seven (7) versions from Mach 1000.0 to Mach 1000.7, which one was installed?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 17, 2008 | Kenwood Car Audio & Video
My 1999 tahoe has a security problem. The light comes on and goes off it will start.If the light flashes it fails to start. can you help
The pass lock is beginning to fail.You can try reporogramming it following this procedure. If it still continues to happen the pass lock/ignition tumbler may need replaced.
PASSKEY LOCKOUT RESET ALL GM CARS 1999 AND UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the PASSKEY system to recognize your key
Sep 23, 2010 | 1999 Chevrolet Tahoe
What folder is reboot in
  • Power is turned on.
  • Open Firmware code is executed.
  • Hardware information is collected and hardware is initialized.
  • Something (usually the OS, but also things like the Apple Hardware Test, etc.) is selected to boot. The user may be prompted to select what to boot.
  • Control passes to /System/Library/CoreServices/BootX, the boot loader. BootX loads the kernel and also draws the OS badges, if any.
  • BootX tries to load a previously cached list of device drivers (created/updated by /usr/sbin/kextcache). Such a cache is of the type mkext and contains the info dictionaries and binary files for multiple kernel extensions. Note that if the mkext cache is corrupt or missing, BootX would look in /System/Library/Extensions for extensions that are needed in the current scenario (as determined by the value of the OSBundleRequired property in the Info.plist file of the extension's bundle.
  • The init routine of the kernel is executed. The root device of the booting system is determined. At this point, Open Firmware is not accessible any more.
  • Various Mach/BSD data structures are initialized by the kernel.
  • The I/O Kit is initialized.
  • The kernel starts /sbin/mach_init, the Mach service naming (bootstrap) daemon. mach_init maintains mappings between service names and the Mach ports that provide access to those services.
Mar 08, 2010 | Apple MacBook Mac Notebook
I don't have the drivers on my computer and I am unable to find them amywhere. Also, right when it starts up it does innitializing. then it tells me to take out the cartridges. I have switched them...
Driver support for HP Officejet 6110 all-in-one:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=79477&lc=en&cc=us&dlc=en&lang=en&cc=us
Select your Operating System on the support site and go for the
latest software and drivers.
1. Disconnect the printer.
2. If present, remove the "old printer" in the hardware manager.
3. Install the software and drivers, using the download.
4. Do not attach the printer until the software did run completely or at the time you are being told to make a connection.
Oct 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
Feeder and glass product offset copies
check if the mirors are fixed and if not, bring them to the initial position! it's possible you should make an immage adjustement because teh scanner moved from the innitial position!
Nov 03, 2008 | Ricoh Aficio 2015 Copier
VISTA UPGRADE FAILURE
Hi ZJIM, download & run windows vista adviser fro microsoft.
This program will check your system & even your printer if its connected & turned on. After its runs the testing it will advise you what will & will not run with vista. It will also show you where to get updates for your system so you can run vista.
http://search.microsoft.com/results.aspx?mkt=en-US&setlang=en-US&q=vista+adviser
Good Luck!
Mike
Mar 25, 2008 | Mach Speed P4M800 (890552603480)...
365 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
