Question about Keurig Elite B40 Coffee Maker
My Keurig was accidentally plugged to a 220 v outlet instead of a 110. Need a repair shop located in the Philippines. . It won't operate anymore.
The power in the Philippines is 220v. I bought my Keurig in the US. It is 110 volt.
  • 3,904 Answers
Chances are pretty good that you blew a fuse in the unit. I think it would be worth it for you to take it apart and check. If there is not a fuse you have lost nothing.
Posted on Nov 14, 2014
SOURCE: Need to no know how to take apart!!!!
I hope this reaches you, as I had the same problem. You start with the metal screws attaching the handle. The screws are strange, but you can use a small phillips... you need enough force to turn them, but don't break the plastic. Get the handle off, then look under the housing on top of the needlle... if you look in there, you will see 2 screws... then when housing is removed, you'll see 2 more screws... in other words - carefully keep turning screws until you have the part open that you want. I started with the screws near the needle that is the spout. just remember the steps, so you can reverse and close the thing up. Any problems, you can email me at: bdubois@maharam.com, and thank you for serving our country! If you need a new machine, maybe I can get you one. Barbara
Posted on Apr 17, 2008
rickzilla
  • 706 Answers
SOURCE: Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Posted on Aug 31, 2008
SOURCE: I am moving to a 220 volt country
Get a transformer to take with you, but make sure it is sufficient
for the watts of the Keurig.
Posted on Feb 03, 2009
SOURCE: I need a 14.5 volt
Had the same issue , Found a Philmore tr215 transformer...15 v 1amp. Had to modify the Keurig by cutting the plastic transformer compartment to fit the new transformer. also had to remove the transformer mounting bracket from the transformer to get it to fit. Keurig now works great.
Posted on Mar 01, 2011
heatman101
  • 43501 Answers
SOURCE: The machine won't turn on
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Posted on Sep 03, 2011
Can you pls tell me the service center of keurig k40 and k45 coffee maker here in the Philippines?
don't bother with a service center ( incorrect voltage will have burnt the board and other components )
get a new machine to the correct voltage
Sep 20, 2016 | Keurig Coffee Makers & Espresso Machines
I accidentally plugged my kuerig 45elite to 220v, it's not working now. Can you repair it and how much?
Everything inside it electrical will be ruined. I don't understand how you can get 220 volts into a 110 appliance as the plugs and sockets are so different?
Anyway, you would have to phone them as their website is useless unless you want to buy one.!
Brewer Support
1 866-901-2739
Search service Keurig
Jan 31, 2016 | Office Equipment & Supplies
Wrong outlet
You've overloaded an internal fuse, or blown the heating element but it's not usually repairable. George would far prefer you to buy a whole new machine so that's how it's been designed, but you can thwart his money-grabbing plans by asking for one on your local FreeCycle or Freegle group.
There are millions of them sitting unused in the back of people's cabinets and although they might need a clean, the price is right. I've never had to pay for a George Foreman grilling machine.
May 24, 2010 | George Foreman GR30 Indoor Grill
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
Accindentally pluged it to 220 volts instead of 110 volts
hello , i suggets you replace the power supply with a 110 v input boerd .
or do this if the damage is big replace the all sytem with a new one then get a voltage step down ie 220 to 110.
thank you
May 06, 2009 | Yamaha DVR-S120 DVD Player
Wii 110 voltage plugged into a 220 socket
Well your warranty won't cover it thats for sure. So with that bit of knowledge, locate your nearest console/modchip shop. They also do console repairs etc and should be able to repair or replace the power supply as long as the internals are ok apart from that.
Apr 16, 2008 | Nintendo Wii Console
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Keurig Elite B40 Coffee Maker Logo
789 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
