Question about Dehumidifiers
How do I add oil to fan motor
I know I need # 20 oil but where do I put oil in?
  • 2,760 Answers
Well 1st remove power plug from outlet
next remove cover of unit and locate the cooling fan
its about ten inches round and has blades on it kinda like a motor boat prop , in the center theres a shaft and then a motor , it's most likely a open frame type (has no cover to it) there are two brass bushings one on front and one on back put 3-4 drops of oil into each ones center, and spin fan with your hand several times to work oil in, wipe up any that runs out , put cover back on and run it normaly
Posted on Dec 09, 2014
The unit is not drawing water from the air
Mary,
There is a recall on Whirlpool dehumidifiers that may cover your unit, the website lists serial numbers of units on the recall list.
Dehumidifier Recall FAQs
I assume from your question that at least the fan is running. There are many reasons why a dehumidifier is not removing water from the air. Most likely is accumulation of dust and pet hair that restricts the air flow. If you can, unplug it, take off the covers and vacuum out all the dirt from the evaporator and condenser (little radiator like parts). This website has some good blow up pictures of how it is put together and part nomenclature:
WHIRLPOOL DEHUMIDIFIER Parts Model AD25J3 SearsPartsDirect
If the air flow is restricted, the compressor has to work harder to the point that the overload gets tripped. It may or may not be resettable; it is part #10 in the diagram on this page:
http www searspartsdirect com Whirlpool Dehumidifier Parts Model AD25J3...
If you do take the covers off, check that the fan turns freely and you may want to add a drop of oil to each end of the motor if there is a place to oil it. Light oil like sewing machine oil or light engine oil will do.
You cannot really tell if the compressor is working with all of the covers on; and I cannot recommend plugging it in with covers removed because there may be open electrical connections that you do not want to touch. However if the compressor is running, the outlet tube will get hot; that is the one that goes to the condenser [radiator like bundle of tubes nearest the fan] [it may get too hot to touch]. The evaporator [bundle of tubes farthest from the fan] should start to get cold where the tiny little tube from the condenser joins. If neither is happening and you are sure the compressor is running, it is out of refrigerant [freon] and may or may not be worth fixing. If the evaporator ices up [gets covered with frost] it may be low on refrigerant indicating a leak; again it may not be worth fixing.
Jan 15, 2015 | Whirlpool Dehumidifiers
MY DEHUMIDIFIER COMPRESSOR SOUNDS LIKE IT IS RUNNIN BUT, THE FAN WHEN ENERGISED IS TIGHT & WILL NOT RUN. WHEN NOT ENERGISED THE FAN SPINS FREELY. SHOULD i REPLACE THE FAN MOTOR???
Definitely sounds like the thing to do. However, before you do that, try lubricating the fan motor shaft with some light oil (like sewing machine oil). That may free it up.
Jun 28, 2011 | LG LHD65EBL Dehumidifier
The fan squeeks
Oil it. Just a drop or two where the shaft enters the motor (if the motor does not have oiling holes). Make sure you are conservative with the oil. Use a thin machine oil.
Jun 11, 2011 | Woods WMD40W Dehumidifier
HOW DO I OIL THE FAN MOTOR FOR A WHIRLPOOL MODEL aha-015-20 DEHUMIDIFIER?
Look on the each end of the motor. If you see a rubber plug that you can remove then it can be oiled. More than likely you will find none. The vast majority of electric motors today are sealed for life and there is no provision to add oil.
Jun 06, 2010 | Whirlpool AD50DSL Dehumidifier
Hi... I have a challenge ram 710 dehumidifier, the fan has stopped working but there is power to it, when i took it out it is all greasy and black like all the lube has seeped out... does anyone know where...
I also had exactly the same problem with my RAM170 Dehumidifier, it's a very common problem with them. The good news is, assuming the motor winding has not burnt out, then problems with the fan motor can easily be corrected. It's now over two years ago that I carried out the following procedure with the motor in my RAM 170 and it has continued to function with no further problems. Firstly take a photograph or make a drawing of the motor assemble, then fully dismantle it. Thoroughly clean all the black (gungy) mess off the spindle and bearings, WD40 is good for this. Next apply a small amount of light grade oil (it must be thin oil) such as Singer Sewing Machine oil (about 60 pence for a small can) to the spindle and bearings, then fully reassemble. When assembled the motor should spin freely.
Feb 15, 2010 | Dehumidifiers
Fan won't spin. seems to be stuck and it hums.
The motor bearing may need some machine oil or the fan set screw that attaches the fan blades to the motor shaft may be loose.
Sep 30, 2009 | Haier Dehumidifiers
The fan seem to have quit working and the unit got loud. i oiled the fan but it doenst turn on but the compressor comes on but overheats quickly.
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Jul 31, 2009 | Dehumidifiers
How to clean filter
The de-humidifier is a niche product. Its only job is to remove moisture from air to alleviate the problems of mould and mildew. It is very similar in operation to a window air conditioner.
A dehumidifier though will add heat to the room, while an air conditioner will remove heat.
The de-humidifier is an appliance that requires regular maintenance. This may be because it’s icing up, overflowing, not removing enough moisture, or simply time for a good cleaning to maintain its efficiency. If you don’t feel handy enough to attempt this project contact your appliance repairperson.
The following is a step-by-step method used to return your de-humidifiers to its peak efficiency.
Tools required
1 Multi pocket container (old ice cube tray)
2 Long handled brush
3 Oil can
4 Rags
5 De-greaser or spray detergent
6 Selection of screwdrivers
7 New filter
1… Remove water collection bucket and put aside.
2… Remove the filter from rear of machine. Filer is usually within a frame and simply pops out. If no filter proceed to next step. If it is a disposable filter simply replace it with a new one. Other types are made in a plastic frame and can be cleaned and reused. To clean a filter lay it flat in the sink and sprinkle surface with powder laundry detergent. Plug sink drain and turn on hot water. Cover filter with enough water to submerge. Soak for 15 minutes. Remove from water and rinse. Hang up to dry while proceeding to next step.
3… Remove the rear grille from the main body of de-humidifier. If none proceed to next step. If there is resistance then look for hidden screws. If grille locks into cover proceed to next step. Once removed place the grille aside until later.
Tip: Dehumidifier may use different types and sizes of screws. Use ice cube tray to segregate.
4… Remove metal cover of de-humidifier to access inner workings. Cover screws may be difficult to see because are often painted to match body color. Usually two or three screws along each side of base. Once screws are removed lift the cover straight up. Use extreme caution at this point. Front grille may be secured to cover. Some fronts are put together like a puzzle. Parts often interconnect or are screwed to one another. If front grille lifts off with cover try to separate before proceeding. Front grille may lock into groove along front edge of cover. Avoid pulling off any wires from humidistat or indicator light.
5… When cover removed this will expose the heating and cooling coil. They may appear as one but are actually two separate coils in very close proximity. Both will need to be cleaned.
Use a narrow brush to remove surface dust and dirt from the front and rear surfaces of coils. Use an up and down motion to avoid bending fins. Area between two coils must also be cleaned. Use caution, the fins are soft aluminum and can be easily damaged. Once surface dirt is removed, spray with de-greaser or light cleaner. There is a good product on the market called HVAC cleaner. As the name implies it is meant for Heating, Ventilation, and Air Conditioner coil cleaning. If this is not available Fantastic Spray cleaner used in kitchens and bathrooms works quite well. Remove dirt and excess cleaner by slowly pouring warm water into fins. Do not allow the water to enter any electrical connections or components. As an added precaution cover the motor with one of the cloth rags to protect it from the water.
6… With cover, rear grille, and front grilles removed locate fan motor for oil holes. Add a few drops of oil to each end of the motor body. Use a general purpose (3in1) oil or clean motor oil. A #30 oil is sufficient. Three or four drops on both ends of the motor body are sufficient. Add the oil slowly, pausing a few seconds between each drop. If added too quickly over-lubrication will result.
7… Straighten any bent fins. Use a fin comb if available. If no fin comb then use something soft such as a Popsicle stick. Straightening the fins will increase the efficiency of the airflow through the coils. Use caution as these coils are filled with high-pressure refrigerant.
8… Wipe any dirt from fan blade using a soft rag. Do not bend blades. This would cause a vibration that would harm the motor.
9… Vacuum all surfaces including front and back of grille assembly. Vacuum underside of metal cover. Vacuum dirt buildup from base and any other exposed surfaces.
10… Drain any water left in the base and allow it to dry.
11… When completely dry plug in and test operation. On some models testing may require temporary override of bucket overflow switch. Test that cooling coil begins to sweat water within few minutes of operation. If everything appears okay unplug and reassemble. Insert water collection bucket slowly to avoid damaging float switch mechanism.
Jul 17, 2009 | Dehumidifiers
How do I oil and Clean the Whirlpool dehumidifier Model AD0402XS
I like to take my dehumidifer outside, rinse it off with water, scrub it with soapy water, and rinse.
Then I take compressed air and blow it off let it dry in the sun. While I have it apart I will put a drip or two of oil on the fan shaft.
Be careful anytime you remove a cover you are exposed to sharp edges!
Sep 28, 2008 | Whirlpool AD40DSL Dehumidifier
Fan not working
THE FAN MAY OR MAY NOT HAVE OILING PORTS ON THE MOTOR. IF NOT, THE MOTOR NEEDS REPLACED. IF THERE ARE OILING PORTS ON THE FAN MOTOR, TRY SPRAYING SOME WD-40 IN THEM AND THEN ADDING SOME LIGHT MACHINE OIL TO THE MOTOR. THE OILING PORTS ARE SMALL HOLES AT EACH END OF THE MOTOR WHERE THE MOTOR SHAFT EXITS THE MOTOR HOUSING.
Mar 22, 2008 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
