Question about Kitchen Ranges
My kia Avella hatchback 2000 will not start
When I try to start the car engine wont do it, it's like its gonna start but it wont
Check battery alternarer
Posted on Nov 13, 2014
Testimonial: "The lamps and radio is on, so its not the battery. It looks like it start but he dont"
Hi..my kia avella rpm reaches for about 1200 rpm when I start up in the morning and gradually decreases to about 600 rpm.but it takes 10 mins bfore the rpm goes down.is this normal?m And my engine loses...
Yes, that is normal operation for an engine. It needs to run at higher idle when cold and the computer does that through the temp sender. Make sure it's not excessive due to any vacuum leaks. This and the AC power loss would be exaggerated if the engine is not running correctly.
Aug 18, 2013 | Cars & Trucks
Common problem when kia avella shut off engine if the aircon turns on
my kia avella is turn off randomly long time driving and hard to start again..how to fix this problem?
Jun 24, 2013 | 1997 Kia Avella
My kia avella 2007 model runs at 5kl per liter..what is the proble with this and how do i fix it to make it fuel efficient..
Have the fault codes read. Replace the faulty units with
genuine one because most aftermarket units are not set for OEM cpu units and
are not completely compatible.
May 05, 2013 | 1997 Kia Avella
I have a 2000 kia sportage 2.0 liter engine. it will not start right away like it should, it takes a few times to get it to actually start and run, then when u turn it off it wont start up again. A me
replace fuel filter replace air filter,clean fuel injectors because they could be dirty clogged with carbon causing injectors to stick open and keep spraying fuel when engine off flooding engine.code scan for faulty engine coolant temperature sensor or CMP sensor.
Oct 01, 2012 | 2000 Kia Sportage
2000 kia sephia fuel pump/overheating/not turning over
sorry to tell you but you have a blown headgasket or cracked cylinder head. that is why the coolant blows out of the radiator and the engine won't start due to engine compression getting into the cooling system.
Jun 06, 2012 | 2000 Kia Sephia
My Kia Avella RPM will go on high at 1200 if i on the aircon,if i switch off the aircon,the RPM is back to normal at 400,what kind of trouble is this?Is the coolant thermostat need to install it back in...
That engine should never oveheat unless the thermostat is defective or it has a plugged radiator or other serious problems inthe cooling system or engine, I live in the desert of the USA and it reaches 125 Farenheit here, never had any overheating issue on any car I have ever owned.
Feb 10, 2012 | 1997 Kia Avella
When starting the engine of kia sportage,the water from the radiator overflows
hopefully its just a jammed thermostat,other wise its gonna cost...replace asap.
Oct 14, 2010 | 2000 Kia Sportage
Kitchen Ranges Logo
74 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
