Question about Dishwashers
Dishes have bad odor after being washed. Changed dishes and detergent. What's wrong?
    Problem Solver:
  • 7 Answers
Bonjour mon ami,
Your dishwasher has a build up of bacteria that would be causing the smell. I would sugsuggest purchasing a rinse-aid from your local supermarket. This is a pack you place in your dishwasher and run on a full cycle without any dishes.
It should disinfect your device and clear up the issue for you.
Also at the bottom on the inside there will be a small drain be sure to empty this regularly.
kind regards,
Geoff
Posted on Nov 14, 2014
  • 677 Answers
SOURCE: Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Posted on Apr 12, 2008
  • 677 Answers
SOURCE: Whirlpool gold dishwasher leaves film on dishes
the problem is hard water i bet. there is a new product out that actually filters the water going into your dishwasher. this i think is awesome becasue who knows whats in the water cleaning the dishes you eat and drink with. my dishes use to be white and spotty and after the first load with the filter they came out spotless. you can get it at www.dishwasherfilter.com. you will be glad you did. oh it goes under the sink and is small and affordable.
Posted on Jun 01, 2008
  • 409 Answers
SOURCE: Detergent trouble
hi there,
sounds like the detergent dispenser is not working properly.
are the rest of your dishes clean? in other words, is there any food residue on them?
check the dispenser and make sure that there is nothing visibly wrong with it.
if the problem still persists, replace the dispenser.
Posted on Sep 13, 2008
CRTN
  • 716 Answers
SOURCE: Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Posted on Jan 06, 2009
tzweeb
  • 318 Answers
correct, no filters to clean, but what you are smelling is soap residues that have built up on the heating element and when it goes thru the heat dry cycle, it burns the soap causing the odors.
trying the cleaners you have may help but the cause is the residues. you need to use a d/w cleaner like d/w magic or citric acid. if you just run the unit with the waterheat option and vinegar in a bowl right side up in the top rack, it should rinse out the residues then dont use to omuch soap and only use dry powder soap. no tablets or liquids.
run hot water at the faucet first and then be sure to use the heat option. it may take a few cycles to get rid of the odor but it will go away as you get the unit cleaned out.
Dishwasher model FDB740RCS0. Has a unpleasant odor when door is opened. Dishes also have this smell.
There is usually a filter in the bottom of the machine where the perforations are.
Ofter you twist the cylinder around or turn a lever.
Try a full hot wash with detergent and nothing in it to see if it helps flush it out.
Is the drain hose into the sink, pipe or waste under the sink clear.
You may need to get down and dirty with the waste pipes to makes certain everything is flowing OUT easliy.
Nov 22, 2016 | Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Both dish drawers are leaving a chalky dried on residue on the dishes. I ran a cleaning detergent in both drawers, made sure salt in water softener was filled, checked filters, and they are still leaving...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Oct 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Foul odor on dishes and in dishwasher after cycle
It is very likely that your dishwasher is growing mold, in this condition. If it is causing your dishes the same issue, it may be wisest to obtain a dishwasher cleanser(Several detergent manufacturers now sell dishwasher cleaning items), which will hopefully kill off any mold colonies growing in your dishwasher's blades, and in your drain cap.
Apr 23, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Even after a wash-a white detergent residue is left.
I have a Whirlpool Gold dishwasher and had the same trouble. I found the solution. Fill the detergent dispenser to the top with Cascade Complete liquid gel - it is in a green bottle, then put a half a cup of white vinegar in the bottom of the tub before you start the dishwasher. I have tried them all and Cascade Complete Gel works best. Don't use powder. It really builds-up on my dishes and only the gel keeps the film off my dishes.
I also add Jet Dry in the rinse-aid dispenser but I have a friend who use vinegar in that too. The dishes come out sparkling clean with no film or white build-up. If they still are filmy after three washes using this method, then you may have some build-up in the dishwasher and you can put a cup or two of white vinegar in the bottom - with no detergent or dishes and wash and rinse well. That helps get rid of build-up.
Apr 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Sep 08, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
Smell in LG LDF8812ST
First, scrape your dishes clear of food before putting them in.  Rotten food makes smells.  Second, use a good brand of detergent in the recommended amount and use the heating cycle to heat the water up.
Most dish washers have a dryer heat cycle but this one apparently does not.  This may cause mold in the machine.
How to get rid of the smell:  With no dishes in the machine, add half a cup of bleach in the bottom of the unit and do a full wash cycle.  If the unit still has an odor, get some baking soda...about a half cup and put that in the bottom of the machine.  Close the door and leave overnight.  Then, run the machine through one wet cycle...say a wash cycle and then it should stop smelling.
Hint:  When leaving dishes in the machine between uses, leave the door ajar...do not close tightly.
Nov 13, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Detergent trouble
hi there,
Mar 11, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishes won't come clean
If you have dishes (typically cutting boards or really tall dishes) that block the dispenser door from opening, the water cannot wash out all the detergent during the wash cycle. Check to see that after loading the dishes, your detergent door has clearance.
Aug 26, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
