Question about JVC HD-52FA97 HDTV
I have no picture...
I have no picture... I have sound and I have replaced my lamp. I have also unplugged unit from wall for a few minutes to reset microprocessor. Sound is good and it displays channel selection and menu. Just no picture for the show you are listening to.
    President:
  • JVC Expert
  • 300 Answers
Which input does it show? Try connecting the signal to that input.
Posted on Feb 27, 2015
SOURCE: Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Posted on May 11, 2008
  • 2920 Answers
SOURCE: REPLACED LAMP AND NOW NO PICTURE OR SOUND
take it to a shop and let them fix it right
Posted on Feb 13, 2009
  • 22 Answers
SOURCE: Picture went out had sound..replaced
This unit has cooling fans and it sounds like they are either plugged or not working. When a ballest usually goes out it does not come on and then go out. It is the coming on part that is hard for the ballest to do when going out. Sounds like over heating problems and if it is the ballest it could be any were on a tv and in many different locations. I would type your model number in and replacement ballest for this model number and go from their. Thanks
Posted on Oct 05, 2010
  • 301 Answers
SOURCE: No audio. Sound comes up in the menu but I can
SRA-1016A-M2-R - Analog Pwb Assy is most likely the part that is got a problem. i have seen many time on the JVC HDILAs have audio circuit failures. the audio amp will usually fail sometimes i have seen speaker issues but they are very rare. good luck that board cost is around $140.00
Posted on Jan 07, 2011
SD Tech
  • 14553 Answers
SOURCE: no sound or picture on jvc 52fa97
If lamp is bad set will detect that (or other issues) and kill all functions=not unusual to have no sound if lamp is bad.
Posted on Apr 16, 2012
No sound and no video when i turn it on only the green light becomes red. thx
This indicates a problem in the power supply or the scan drive.
Try unplugging it from the wall, wait about ten minutes and then plug it back in. If it works then you have reset the microprocessor to the start up default. If it doesn't then there is an internal defect and it's time to check on repairs. That reset procedure works for anything that has a micro processor in it. If it's a battery powered unit then remove the batteries and then reinstall them after a short wait (about 10 minutes)
Aug 24, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Picture comes on for a few seconds then it goes black. Sound continues to work but no picture. After turning off and on a dozen times in a row, the picture may stay on
These t.v.'s have a microprocessor in them, similar to a computer. Try unplugging it from the wall for a few minutes then plug it back it. If that doesn't work try removing the cables and plugging those back in.
Mar 29, 2010 | Memorex MLT1912 19 in. LCD TV
Since retuning Novemder 2009 cannot receive BBC1, BBC2 or BBC3
sounds like power surge. try unplugging unit from wall. wait 2 minutes. this reset the microprocessor in the tv. plug back in and enjoy!
Nov 09, 2009 | Toshiba 50H81 50" Rear Projection...
Freezes
Leave it unplugged for 24 hours. Sounds like the failsafe for a power surge. This is typical for RCA products. I have a 54 inch rear projection TV that will only tune 16 channels and none of them are correct when it surges. The solution: 24 hours unplugged. I also have the same type of thing with my RCA DVD recorder... Never had it happen to surround sound, though.
Sep 26, 2009 | RCA RT2380 Home Theatre System System
65" mitsubishi tv blinking red and green no sound or picture model is wd 65100 the motor turn on for a few minutes and then turn off
unplug unit from wall-remove lamp see if you can see if its physically broken-look at the ellement,you may simply need a lamp
Sep 01, 2009 | Televison & Video
I have a Hitachi 55 inch plasma tv. i have no picture but i have sound.
Unplug the unit to reset the microprocessor, then reconnect the power in a few minutes and try it. Next step is to disconnect it from all other components and see if it will turn on from the set itself. Next step is to call a repair shop that is factory authorized for Hitachi, or order the digital, sub digital and power supply boards, at a cost of about $500. On this model trying to fix it yourself is a costly experience. Good luck, Russmann.
Dec 08, 2008 | Televison & Video
After a few minutes of the t.v being on the picture will suddenly go of as if the T.v. puts itself into standbye mode, once this happens the only way to get the picture back is but switching the T.V. off...
Sure wish we knew which brand and model of set it is, but it sounds like the tv is going into shutdown possibly caused by bad solder connections or a weak component on the circuit board. The only thing you can do yourself on this one is to disconnect the power cord from the wall for a few minutes and hope it clears out any confusion in the microprocessor. Otherwise, you need a service person to go in and check it with test equip. Good luck, Russmann.
Nov 12, 2008 | Televison & Video
No picture
Good Day;
Try resetting the TV by unplugging from the wall A/C outlet for 3 to 5 minutes, plug back in. No fix? Your TV's LAMP needs to be replaced. Part number; UX21516, for Model 55VG825.
Good Luck, big IRISH.
Jul 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
The picture on my RCA Scenium HDLP61W151 61 in - was completed black
unplug both the TV and the cable box for 2 minutes then replug them in. this will reset the micros in both units. if there is still no sound check your SAP setting make sure its off.
Feb 06, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
JVC HD-52FA97 HDTV Logo
54 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
