Question about Electric Demolition Jackhammer
Where can I find an operator's manual for a Pro-tech electric demolition hammer?
I am also trying to find out if this company is still in business and what kind/type of oil to use in this hammer.
Wat colour cable goes in which side inside a Bosch demolition hammer
That Depends on the model and the year of build or is it really a demolition hammer or a rotary hammer instead of a demolition hammer made much people made that mistake , the tools are different in the differend Countrys where the machines are made for , look for a manual its free for your model
https://www.boschtoolsservice.com/home.aspx?WT.ac=BT_Replacement
Jan 15, 2016 | Bosch Hammering
Demolition hammer model D25889 will not hammer motor turns on but not hammering
check the position of the operation lever
it should have 3 positions drill, hammer drill and hammer
make sure it is fully selected or the hammer action will not engage
Dec 31, 2015 | Hammering
Hammer not Jacking
Mine stopped and I took it apart and found a badly worn piston gasket. I can't however find a new gasket. Anyone know where to get parts for the sky687 hammer drill then let me know. Copipeworks@gmail.com
Sep 18, 2012 | Heavy Duty 1240w Electric Demolition Jack...
Complet break down of makitia demo hammer
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in the search box and hit the arrow or enter. Select your tool and the parts breakdown and owners manual will be available to view or download. The owner's manual has their recommended lubrication requirements.
Dec 26, 2011 | Makita HM1500B 42 Lb. Demolition Hammer
Where do you put oil in electric demilition hammer
Need to change the brushes in my chicago breaker hammer
If change brushes it has having its workinghours Use a service kit for your model if there is support for your hammer ??? on EBAY there is a set brushes parts are maybe hard to find for electrical demolition hammer of this brand.
Carbon Brushes Chicago electric UL breaker jack hammer NEW 46935 harbor...
Jan 30, 2011 | Electric Demolition Jackhammer
I need an schematic diagram for repair a kango demolition 900 bv where i get parts for it
they went out of business a few years ago,i have some parts no manual i need one also
Sep 23, 2009 | Dewalt D25330K 2KG Sds Plus Demolition...
Dewalt d25940k is a demolition hammer whith drill too?
No, the D25940K is not a Rotary Hammer. It is just a Demolition Hammer. (Jack Hammer). You can turn the chuck to adjust how your bit sits but that is it. Follow this link to the manual for this tool. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/581735-00,D25940.pdf
Aug 11, 2009 | Dewalt D25940K Heavy Duty Demolition...
Electric Demolition Jackhammer Logo
409 people viewed this question
Top Electric Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Dan Webster
Dan Webster
Are you an Electric Hammering Expert? Answer questions, earn points and help others
