Question about Garden
Diagram fuel lines poulan2075 chainsaw - Garden
  • 1,169 Answers
This should be what you need. Note you will to determine side of the primer is suction and which is pressure.
Diagram fuel lines poulan2075 chainsaw - 25282444-0tgw3fbu5w4thrdwa31lglfp-1-0.png
Posted on Nov 14, 2014
  • 384 Answers
SOURCE: mcculloch 4600 chainsaw fuel line routing
Shouldn't be that hard to do. Possible paths 1) Run hose from tank fitting to Carb fitting. 2) Run hose from tank to shut-off vale to Carb 3) Run hose from tank to shut-off to prime to carb 4) run hose from tank to shut-off to prime to filter to carb. Omit any item not on your saw.
Posted on Jun 12, 2009
SOURCE: Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Posted on Jun 22, 2009
dontbother10
  • 2220 Answers
SOURCE: Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Posted on Sep 04, 2009
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Posted on May 27, 2010
  • 4088 Answers
SOURCE: I Need Diagram of Fuel Line Hookups For a Poulan
The line at the rear of the fuel tank with the fuel filter is the main feed line to the carburetor and connects to the upper nipple. The lower nipple on the carburetor goes to one of the primer ports, and the other primer port goes back to the tank, which has no filter on the tank end. On the primer port, it is cut and try--remove the tank return connection and leave loose. Place the main fuel line on to one of the primer ports and try to pump fuel into it with several pumps.Make sure the filter in the tank is not plugged. If nothing, shift the line to the other port of the primer and try pumping again. When successful, remove the main fuel line and return it to the upper carburetor port. Run a new line from the lower carburetor port to the active primer port and try to pump fuel again. If it won't pump fuel, reverse the two connections at the carburetor and try to pump again. If still nothing, there is trouble within the carburetor which should be cleaned with spray carburetor cleaner and maybe re-kitted. When you can finally pump fuel through the carburetor, then attach the tank return line to the open port on the primer bulb. Hope fully, the engine should run at this point. Hope this helps!
Posted on Jun 19, 2010
Need a diagram of fuel line system for a 311y chainsaw
http://www.doityourself.com/forum/outdoor-gasoline-electric-powered-equipment-small-engines/279941-stihl-chainsaw.html#b
  1. Stihl Chainsaw - DoItYourself.com Community Forums
    www.doityourself.com/forum/outdoor.../279941-stihl-chainsaw.html
    Oct 4, 2006 - I am in the process of rebuilding my Stihl chainsaw carb. I am having troubles identifying this Stihl model. The only sticker on the saw is 311Y.
Mar 22, 2014 | Stihl 311y
Homelite chainsaw fuel line diagram
need a fuel line diagram for a homelite 330 chain saw
Oct 05, 2013 | Homelite Garden
Replace coil?spark plug wire on Poulan2075/16|"chainsaw-
The plug wire will come with the ignition pick up as an assembly. Youll have to take the plastic cover off the top of the motor to get to it.
Good Luck!
Sep 29, 2012 | Poulan Garden
Aug 23, 2009 | McCulloch Garden
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to replace the Husqvarna chainsaw fuel line.
let me knoe the model number and i'll see what i have....
Oct 29, 2008 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
