Question about Soleus 10,000-BTU Portable Air Conditioner with Dehumidifier/Heater - MAC10
How do I remove outer casing of my p210r32 air conditioner
Thought we would look inside to see if we can fix it. but can't get outer case off.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Remove screws from panel , it mar require tamper resistant tool kit .
Posted on Nov 30, 2014
I need a wiring diagram for a ge window air conditioner
Need model number to try and find you one. Older ge air conditioners had the diagram glued to the inside of the outer case. Newer ones had a sheet of paper folded up and stuck near the control panel sometimes in a plastic envelope.
Jun 09, 2015 | GE Refrigerators
Can i take my frigidaire ac out of the case without removing it from the window?
Good Afternoon Friend,
I understand that you want to know whether you can take your Frigidaire air conditioning, model# FRA256ST2, out of the case, without removing the case from the window. Yes you are. Below are step by step instructions for removing your air conditioning from the case.
    1)Unplug your air conditioner.
    2)Take the front grill off.
    3)Remove the filter.
    4)There are four panel screws, two on each side of where the front grill and filter were. Remove these screws.
    5)Gently pull out your air conditioner.
    For replacing your air conditioner, follow the steps in reverse. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer light status has changed successfully. Hope this is helpful.
    -Best regards-
    WP
May 31, 2014 | Frigidaire FRA256ST2 WallWindow Air...
I have a GE Air Conditioner ASW 180AS1. It has a WJ26X10084 ARC-715 remote control that does not work!
You can access the circuit board by first removing one small phillipshead screw from inside the battery compartment. Next, pry the case apart at the parting line toward the front of the remote. On either side of the IR LED's you'll be able to push a very small flat tip in there and get the case to start coming off.
Once you have the case off, you cannot miss the capacitor. Its either blue or black with words like 4.7uF (microfarad) 50V 85degrees with a stripe on the right side.
Use a 30 watt soldering tool ($7 at an electornics store) to heat the solder mount and a pair of pliers to tug gently at the wire as you remove them from the liquid solder. Install the new capacitor into that same solder paying special attention to the matching stripe marking on the capacitor and PCB. Make sure you do not overheat the new capacitor as you install it.
Jun 21, 2012 | GE Air Conditioner Remote Control -...
I am installing a unit owned by my son in his former home. I am unable to find the cable and plug. The closest I have come is a rubber electric cord (3/8" dia.) at the lower right corner. If this is the...
If it's the cord, It should have a plug on it unless someone cut it off.which some people do to hardwire into an outlet. There should be three wires inside an outer cover of rubber. Black, white ,and green. If so, that should be the power cord. You may have to install a new three pronged plug. Good Luck.
Aug 23, 2009 | Danby DAC9003D Air Conditioner
Doesn't quite fit into the wall sleeve. Can I remove the outer case of this a/c to get enough room to slide it all the way in?
I assume you have a window type aircon. if you can't slide the main unit into the shell then maybe the hole in the wall needs to be chipped. Although you can remove the outer case, it is not recommended because the internal parts would be exposed to the elements and would shorten the units life.
I hoep this helps.
Jun 03, 2009 | Heating & Cooling
Nuetral through casing
if your getting current to the casing it means that you have a live wire inside that is coming in contact, and i'm surprised that it has not tripped a circuit breaker. this is something to be taken seriously. if you have someone that knows how to work on things like a handyman have hime take the outer cover off the unit and find the pinched positive voltage wire. please rate this thanks
Sep 26, 2008 | DeLonghi Pinguino PAC-GSRU Air Conditioner
My window air is leaking on the inside of my house
usually because the drain hole/duct/tube, on the outside is blocked, or the aircon is mounted leaning Into the house, condesate that is supposed to drip into the outer casing and run out the hole is funneled over the lowest point of the casing, the house side.
check and unblock the drain,
and ensure the aircon is mounted tilted back.
Aug 02, 2008 | Haier hwr10xc6 Air Conditioner
Getting a/c out of window?
Fix It was a waste of time!!!
After recieving four emails from Fix it, purporting to have collected solutions offered by "experts" -- each turning out to be solicitations for paid services and memberships but offering no solutions to our problem -- we decided to tell everyone we know that Fix It is not worth trying.
Fix It is either an outright fraud or should police the profiles and accounts on their site.
REMOVE MY MEMBERSHIP.
Jun 20, 2008 | Goldstar R1203 Air Conditioner
Re:Whirlpool Dehumidifier Model# AD40DSL5 This product still runs fine but it does not remove moisture from the basement, The water bucket is empty and dry. I removed the outer-casing and cleaned the...
This generation of Whirlpool dehumidifiers and the one that came after it just don't run forever like they used to. If you hear the compressor start to cycle when it is first turned on and you verify that it's fan is circulating air, it should be removing water. If it's not, a service tech would probably charge you $30+ to tell you that the compressor is not producing sufficient pressure. Time to buy another one.
May 29, 2008 | Heating & Cooling
Heating & Cooling Logo
87 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
