Question about Garden
How do I disassemble the Worx trimmer/edger plastic safety guard so it fits into box to return
I am not able to remove the orange plastic safety guard. It's plastic male pieces are clicked into female slots too tightly. Can't get into its box for a return if this can't be removed. I've pushoted, pulled at both sides--can't really reach the one closest to the trimming wheel housing due to its position. But sure can't get the other side to budge at all. Looked for videos, tried to find help on Worx website, etc. No videos for taking apart, yet others have returned their purchased of this not-very-good yarn work device. So, it MUST come off, right? PLEASE tell me it can. Thanks. Jane
  • 3 Answers
SOURCE: broken window regulator on right front
just got back from AAA. they wanted $100 just to take the panel off. They said it takes a special tool and about 3 hrs of labor.
Posted on Oct 16, 2008
trippssmengi
  • 76 Answers
SOURCE: putting gears back in echo trimmer
go to www.echo-usa.com/documentation.asp youll need your model number and you can get a breakdown of your machine which should help you to get it back together a little easier.
Posted on Jan 05, 2009
emissionwiz
  • 76109 Answers
SOURCE: 1998 Jaguar XJ8 front wheel bearing
it does press out/in, but they can get stuck. u are using a hydraulic bearing press?
Posted on Mar 20, 2009
SOURCE: replace rear turn signal bulb on 2007 H3 - driver side
1st::Unscrew the 2 screws that hold the light in.
2nd::Slide your hand behind the light and pull the light towards you. Make sure that you pull it straight, as if the h3 was driving away from you, so you dont break the two pins that are holding the light in...PULL ONE PIN AT A TIME!!!
Dont pull it to far away from the hummer as there are wires attached that need to stay attached.
3rd::turn the back of the bulb to unlock it from the lens...
4th:: slide the bulb out and remove thebulb by pulling it straight out.
5th::put the new bulb in, lock it back into the lens, then insert it back where you got it from,...
MAKE SURE you move the wires out of the way when you put the lens back in...they will get in the way and can be damaged.
Posted on Apr 07, 2009
  • 54 Answers
SOURCE: 99 Chevy 1500 heater core inlet hose male fitting broke
well you may need to replace the entire heater core if the remaining inlet/outlet nipple is not long enough. common problem many people have
Posted on May 27, 2009
Attach Worx Trimmer Safety Guard
check for a hole in the head or shaft that the screw will be positioned in when fully screwed in
Jul 31, 2016 | Worx Garden
How do you remove the worx trimmer head
Go here, select your model. Then at the bottom of the model page is the owner's manual on the right hand side.
https://www.worx.com/trimmers-edgers.html
Jul 04, 2016 | Worx Garden
Pineapple leaf jammed under spool housing. How to remove housing to clean out?
Usually the cutting heads have a couple of plastic tabs you push in to release the spool from the head
Mar 06, 2016 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Worx electric grass trimmer / edger wg116 restring. Need this one not 117.
Demonstrated on a Worx String Trimmer - YouTube
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
Sep 18, 2015 | Worx Garden
I used it yesterday and today it will not start. Battery is full charge. Button key is in place.
I would first take a meter and test that the battery actually charged. If that tests out fine ( should read at about 12.8 to 13.5 Vdc), I would then check all the wired connections to make sure they did not come loose.
Jul 19, 2015 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
How to put the worx gt 18v trimmer safety guard on
The trimmer comes with the screw "pre-inserted" on the TOP side of the guard. After 30 frustrating minutes--I realized it actually screws in to the BOTTOM side of the guard (beside the trimmer head.) Must've been designed by a Man! (ha ha) :)
May 19, 2012 | Garden
I need to remove the trimmer head, weeds are bound up between it and the safety guard
Please unattached the protective cover before you do anything, then remove plastic strings and unscrew middle to do this. You will see a screw to remove the head.
Thanks,
Jul 06, 2011 | Worx GT (10") 18Volt Cordless LithiumIon...
I received my LWG151P yesterdat and I am having problems with assembling the safety guard. It does not fit, it appears to be about 1/4" too short and the hole does not line for the screw to fit. Any...
If you can, just mark and drill out the guard with a powered drill and drill bit (not too big) in the correct location for the screw(s) to fit. When in doubt, just drill it out! Plastic or metal guard....doesn't matter....a steel cutting drill bit will go thru both. Sometimes drastic engineering flaws cause for drastic solutions.
Aug 27, 2010 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Im trying to figure out how to install the safety guard.Can you help me?
On this page you will find a tab for the owners manual. The regular site I use has no Worx machines listed at all. I hope this helps you. The tab for MANUAL is near the middle right of this page. Hope the assembly info you need is there.
http://www.worxyardtools.com/cordless/grass-trimmers.html
Aug 14, 2010 | Worx GT WG150-2 18 Volt 10 in. Cordless...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
