Question about Epson Stylus Photo R300 Inkjet Cartridges
The display on my printer has stopped working, can I still change an ink cartridge without it?
The display has recently stopped working, but printer is working but I need to change an ink cartridge, can I still do this without it? What could be wrong with display and is it fixable?
    Master:
  • 467 Answers
You should be able to change cartridges. It may be hard to determine what is wrong with the display but look for loose connectors on the back of the display, the controller board, etc.
Posted on Nov 14, 2014
SOURCE: remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Posted on Jan 23, 2009
SOURCE: EPSON DX7400 ALL IN ONE PRINTER INK CHANGE
ok just done it - i always have to look it up too!
find the default printer from your control panel
click right click and pick properties
then hit printing preferences
then click tab marked maintenance
and follow the ink cartridge replacement instruction
printer leads you through no probs - hope this helps
Posted on Apr 25, 2009
  • 20 Answers
SOURCE: Ink cartridges not working in epson sx100 all in one printer
hi.make sure there is no tape or dirt on cartridge chip contacts.if still no joy trying iserting one cartridge at a time then installing.say insert black then will say others carts missing red blue yellow.keep going till they are installed.sometimes helps.make sure the carts have lastest chips installed version 5 or higher if compatable cart.should not be a problem if bought from epson.eg t711 etc will fit but must be new carts with new chip otherwise may not accept.i belive the sx100 has something like t811 or something.this may be the new chip.otherwise may just be a faulty chip on the cart.you can get refillable carts or ciss system on ebay you put in your own ink.they are brillant.cart chips reset when low ink.hope this may help.
Posted on Jun 07, 2009
  • 61 Answers
SOURCE: I changed the black ink cartridge and now not working
Did you remove the plastic sticker over the print head of the cartridge?
Are you using a refilled cartridge? Most cartridges have a sensor that tells the printer how much ink is left. When companies refill them they do not replace the sensor, so a completely full cartridge will still tell the printer that it is empty.
Posted on Jul 01, 2009
  • 421 Answers
SOURCE: I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Posted on Jan 13, 2010
Why lexmark 3550 won't print after installing new ink cartridges
Check your manual for instructions about this type of problem. Are you using the ink cartridges meant for your printer? Sometimes using refillable cartridges instead of the manufacturer's cartridges can cause the printer to still think the cartridges are empty, and display an 'on-screen' message that they need to be replaced, which could stop the printer from engaging. I have a Canon Pixma printer, installed refillable cartridges, and now the unit displays a 'cartridges are empty' message on PC screen; but the printer still works. The system just recently went into a non-printable mode displaying a more convincing message that the black cartridge is EMPTY, and completely stopped printing. The solution to this: press and hold the Stop/Reset button for about five seconds, and it overrode the issue and started printing. Moral of the story, maybe its best to just buy the manufacturer's printer cartridges.
Jul 26, 2014 | Lexmark Office Equipment & Supplies
Both of my ink cartridges went out at the same time and i only replaced the black. now it has an error saying it will not print because i need to replace the color ink cartridge. but i'm trying to...
It depends on the model that you have. You can try one of the following to reset the ink counter and the printer will show a full color cartridge.
This is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
1. Disconnect the power cable.
2. Hold down "On/Off" button.
3. Reconnect the power cable.
4. With the power button still down, press the "Stop/Reset" button twice.
5. Release the "On/Off" button.
6. The printer is now in "factory mode".
- wait until "idle" is displayed.
7. Press the right arrow button (next to the "OK" button) repeatedly until "Shipping Mode 3" is displayed.
8. Press the "OK" Button
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470).
10. A test page should print.
11. Open the cover.
- the cartridges should position themselves at the far left - the cartridge removal location.
12. Disconnect the power cable.
13. Remove both cartridges.
14. Close the cover.
15. Reconnect the power cable.
16. Press the "On/Off" button once.
17. Wait until a "Replace Cartridges" message is displayed.
- insert cartridges.
18. Wait until the printer is operating in its normal mode. The display shows the normal start menu (ie: Copy).
The ink levels have been reset.
- check by going to printer>properties>maintenance>view printer status
this is what i had to do to get it to work with canon mp460
2. Hold down power button
4. With the power button still down, press twice the "Cancel/Stop" red button
5. Release the power button
6. The printer is now in factory mode...(wait about 30 seconds until it says "idle")
7. Press the down arrow (next to the "OK" button) until it says "Shipping Mode 1"
9. Now with it displaying "Without Cleaning" press the power button
11. Now open cover
12. Disconnect the power again
13. Take both cartridges out like normal
14. Close cover
15. Reconnect power cable
16. Press power button
17. Replace cartridges
MP-160 is different from MX300 so I tried my best with it...
The main solution is to reset the entire printer:
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button
Aug 30, 2011 | Office Equipment & Supplies
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
My canon MP 145 printer displayed E5. How can I solve my problem?
E5 means your cartridge error. May I know are you using original ink cartridge or yours has been modified before?
I assume you to refill your ink cartridge before because E5 error won't appear after replacing new cartridge.
So, you need to take out both of your ink cartridge and then use a clean cloth to wipe them. After that, slowly put in back into the printer. If the error is still there after wiping it, try to do it till the error is gone.
I had tested this way with my own printer and it works again without needed to buy a new ink cartridge.
All the best and good luck =)
May 20, 2011 | Computers & Internet
I have refiled an existing ink cartridge and now the printer keep displaying low ink and does not print? please advise? thanks michelle
Do the reset and it will display the required ink level for your cartridges/printer.
1 Switch off the Canon MX300 and disconnect the power cable.
2 While press and hold the power button, Connect the power cable to electric socket.
3 While pressing the power button, press the "Cancel/Stop" button (red button).
4 Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".
5 Press ">" (next button) once "Shipping Mode 3′ then Press the "OK" button. Press "OK" again for "without cleaning".
6 A test page will print.
7 Open the cover, like you are about to change the cartridges.
8 Disconnect the power cable again without switch off the printer.
9 Take out the both cartridges.
10 Close the cover.
Connect the power cable and turn on the printer.
Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Regards,
Ron
Feb 25, 2011 | Canon MX300 Office All-In-One Printer
I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
Dec 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Change ink cartridge
For many you need to turn the printer on, lift the lid that covers the ink tanks, and on the on printer display scroll menu to change ink or something to that effect. Alternatively, if you have the Epson printer utilities on your system, go to Control Panel, hit the printer icon, properties.......
Apr 02, 2010 | Epson Stylus CX6600 All-In-One InkJet...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
How to reset the Canon MX850 Printer, after ink change and counter reset? After I had changed ink cartidge and reset ink counter, I was able to print without problem. But this was only for a few days. ...
One way is to hold the 'Stop/Reset' button for at least 5 seconds until the display shows a new message about ignoring the current ink condition. This does not reset the chip but it does allow you to continue printing with the refilled ink tanks.
Mar 04, 2009 | Canon PIXMA MX850 Multifunction Printer
Error
Have you changed the ink cartridges recently? A mis-seated new cartridge was sufficient to stop my epson printer working (different model). A check you might run to verify this would be to try to check the ink level from the printer control panel in windows. If the ink cartridge is not seated correctly you will not get an ink level displayed.
Aug 24, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus Photo R300 Inkjet Cartridges Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
