CHANGE MY WEPKEY ON RCA DWG855TLG TURBONETT
WHERE DO I FIND THE CONFIGURATION TOOLS FOR MY MODEM?
  • 51 Answers
Use your web browser to type in the following URL - 192.168.1.1 and it should ask you for a user and password. If it doesn't work then type in 192.168.0.1
Posted on Nov 17, 2014
What is lynksysn600 wepkey?
WEP is a type of security mode for wireless networks. It is associated with a specific SSID. You have to know the WEP key to be able to use the WLAN that is protected by it. If you own the router, you can change the WEP key in the config. If you do not, you'd need to get the key from the owner.
Sep 01, 2014 | Linksys Zyxel Prestige 600 Series 645 Adsl...
I'm looking for the password to set up a kindle
You might check on the back of or under the modem to see if it is written on a sticker.
Else log into the modem using a computer. The address is usually 192.168.0.1 or 192.168.1.1. In your internet browser, type http://192.168.0.1 or http://192.168.1.1 to access the modem configuration interface. By default the username is blank, and the password is admin.
Click on the wireless tab, and you can view/change the settings.You will find the wep key there. It's what you will have to enter on the kindle when it asks you for a network password.
May 10, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Change MTU settings on an RCA DCW 725
  • There are no user configurable options to cable modems, everything is based off the configuration file that your ISP pushes to the modem during registration.
  • Try connecting your XBOX directly
Apr 07, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Where do I find the WEP key code on my modem model number 2247NWG
the network administrator (whoever configure your router) should have the wep key you're looking for, if you're that person and forgot your wepkey you need to reset your router so you can go back into the router configuration page and reset a new key (and hopefully you'll remember it next time).
here some instructions for your product:
check on page 14 (FAQ) of router's manual
resetting router to default configuration (router's manual)
good luck!
Dec 26, 2009 | Netopia 2247NWG-VGx Wireless Router...
How to secure my wireless connection for a DCM425 RCA modem
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 05, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How do I get into my RCA cable modem DCM315
For Me I Use 192.168.100.1 I don't know if that will work for you, but it might.
Apr 16, 2009 | RCA DCM315R Modem
Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Dec 30, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
How do I set up a secured internet connection?
You have to go to the router configuration. To reach it, you go with Internet Explorer (or Firefox, or else). In the documentation of your router, you will find an IP address by default for your router (or go to the RCA website and find the doc, by the model number). That IP address is the way to enter to the config. Enter the address in the address bar, for example http://192.168.0.0 in the web-browser. In the documentation, you will also find a login name and password for your router (that you will change afterwards). So, once in the configuration, you will find a section for the security, to select the security mode and choose a password.
Nov 29, 2008 | RCA Cable Modem DCM315R (11603540)
Frequency change
I figured out that with the RCA modems, if you pull them off the network ( disconnect the cable) , do a system reset (push the button on the back) for 45 seconds it goes into (what I call night rider mode) with the lights. After it is done with that it will give a class C address to the PC plugged into it. You can plug the gateway address into a browser and get into a configuration mode. There may be a place to reset the freq. not sure though. Sometimes you have to do it a few times to get it into this mode... once you lock in a configuration change I have never been able to get back into it without doing an other reset. Give it a try.
Oct 01, 2007 | RCA Cable Modem DCM315R (11603540)
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
