Question about Dryers
<!-- from fixya rte -->Fabric sheet stuck in fan - Dryers
  • Dryers Master
  • 744 Answers
Hello Thomas;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number, so I can not tell you how to access the fan wheel.
Posted on Nov 14, 2014
How can I clean the plate of my Oliso pro. It has wonder under on it
get the iron hot. Take a piece of fabric and a dryer sheet. Put the dryer sheet between two layers of fabric. Place this at the edge of your ironing board. With the iron hot, run the sole place over the "fabric/dryer sheet set" several times. This will remove wonder under and many other adhesives from your iron.
May 31, 2016 | Oliso Tg1600 1800 Watts Smart Iron Pro
Why does stretch fabric keep getting stuck in needle plate?
Your needle may have a slight niche in the end. Run your finger around the tip on the needle. Good Luck...xo
Sep 19, 2014 | Sewing Machines
Bed sheets turn orange from sweating,why
It might be the fabric of bed sheets you have. If you were wearing orange clothing that was new, it might have rubbed off onto your sheets. I would assume it was the fabric dye. You can try getting something like sferra sheets. I have never had a problem with them.
Elisa Jed 'http://www.jbrulee.com/cat-sferra-bedding-sheets.cfm#gsc.tab=0
Jan 15, 2014 | Computers & Internet
What are the requirements for a sheet metal fabrication company?
You need many different metal cutting equipment for your metal fabrication. Some of them are laser cutting machines, band saws, drill presses, belt grinders, lathes, shop presses, and sheet metal fabrication. Metal fabrication equipment is used to build metal structures by cutting, bending and assembling processes.Visit: https://metalscut4u.com
Aug 30, 2013 | Central Machinery 18 Sheet Metal...
I have a sheet stuck under the agitator of my GE gtwn3000mws. I've tried to use leverage to brute force the agitator out and it was a no go. Then I took off the top cup looking for the bolt to r
Remove the fabric softener cup, remove the plastic insert, then there is a 7/16th bolt you need to remove and the agitator will lift out.
Here is a diagram of the tub assembly.
Regards,
Richard Roth
http://appliancecafe.com
Nov 13, 2012 | GE GTWN3000MWS Washer
Printer keeps saying i got a jammed paper there is no jammed paper
There are many places in a printer where a small piece of paper can get stuck. It's not always a sheet of paper. Open all the access panels and check the roller track for pieces of paper. If it is clear, unplug the printer for a few seconds and the plug it back in. This should clear the problem if it was in error. Also check the paper feed for too many sheets stuck together jamming the feed. Before loading paper always "fan" the paper first to avoid sheets being stuck together.
Apr 14, 2011 | Canon Office Equipment & Supplies
Grey marks on sheets etc. Not there before washing
Try to dilute your Fabric Softener, in some cases the marks are formed by clots of Softener stuck between sheets.
Hope this helps
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Apr 04, 2011 | Washing Machines
Is it ok to use fabric softener sheets with the
Use the liquid. The sheets will clog up any exhaust pipe or other parts in the dryer. If you live where you vent through the roof, definitely don't use the fabric sheets.
Jun 24, 2009 | Samsung Dryers
I just purchased . new GE dryer [DCVH515EFW]....is it okay to used dryer sheets, or is it better to use liquid fabric softner
just varies really
either way they both get the job done
the draw back to the sheets is they can get stuck on the vents and cause heating or exhaust issues
liquid if not diluted or residue from liquid can cause oil spots
May 02, 2008 | Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
