Question about HP Imaging Drum for Color LaserJet 1500/2500 [ C9704A ] Printer
<!-- from fixya rte -->C9704a will not fully install - HP Imaging Drum for Color LaserJet 1500/2500 [ C9704A ] Printer
  • Mark Schmit
    Mark Schmit Nov 30, 2014
    Make sure that the paper guide at the bottom of the cavity is not flipped up. Also make sure that you did not get the wrong drum unit. The drum unit for the 2840 is very similair but will not work. Was this a new or remanufactured unit?
  • HP Master
  • 1,121 Answers
Image drum shutter might be damaged(a shutter which covers OPC drum from day light falling on it), remove that shutter & insert it.
Posted on Nov 30, 2014
HOW TO INSTALL A BELT ON A OPTIMUS LAB-1100 FULLY AUTOMATIC TURNTABLE
See:
http://www.youtube.com/watch?v=FTJd_WbEhEs
If you have difficulty lifting the platter off, raise it as far as you can and gently tap the spindle with a sift-faced hammer.
Sep 23, 2014 | Audio Players & Recorders
The bios in this system is not fully acpi compliant
Guess your computer is not compatible with Windows 7. Reinstall windows XP run compatibility test from Microsoft
May 16, 2014 | Dell Inspiron 15 (N5050)
Flash player is not downloading
its possible you have a stuck installation that's not fully installed and cannot fully be uninstalled. Download Adobe uninstaller and run it to remove any or all instances of adobe from your hard drive. Then go to C:\Program Files\Adobe... and make sure the appropriate folder is not present. If it is, delete the folder. then reboot, and retry the installation. If it still doesn't work, provide me with more details please.
Apr 04, 2014 | Computers & Internet
1993 eclipse 2.0 non turbo crank angle senser where is the notch that alines with punch mark
To install:
  1. If the timing is not disturbed, perform the following procedures:
    1. Install a new housing O-ring and lubricate with clean oil.
    2. Install the assembly in the engine so the coupling is aligned with the matchmark on the housing and the housing is aligned with the matchmark on the engine. Make sure the sensor assembly is fully seated and the shaft is fully engaged.
    3. Install the hold-down nut.
    4. Connect the harness connector.
    5. Make sure the sealing O-ring is in place, install the cap and tighten the screws.
    6. Connect the negative battery cable.
    7. Adjust the ignition timing, if applicable, and tighten the hold-down nut.
  2. If the timing is disturbed, perform the following procedures:
    2. Position the engine so the No. 1 piston is at TDC of its compression stroke and the mark on the vibration damper is aligned with 0 on the timing indicator.
    3. Install the sensor in the engine so the factory matchmark on the coupling (notch) is aligned with the matchmark on the housing (punch mark) and the housing is aligned with the matchmark on the engine. Make sure the sensor assembly is fully seated and the shaft is fully engaged.
    4. Install the hold-down nut.
    5. Connect the harness connector.
    6. Make sure the sealing O-ring is in place, install the cap and tighten the screws.
    7. Connect the negative battery cable.
    8. Adjust the ignition timing, if applicable, and tighten the hold-down nut.
2.0L Non-Turbo Engines
See Figure 3
  1. Disconnect the negative battery cable.
  2. Detach the crankshaft position sensor electrical connector.
  3. Unfasten the retaining bolt, then remove the sensor.
Fig. Fig. 3: Location of the crankshaft position sensor-1997 2.0L non-turbo engine shown
Apr 24, 2013 | Cars & Trucks
How to trun xp into vista fully
You need a Windows Vista installation CD plus the product installation code.
Then boot up with the Windows Vista CD and follow the install instructions.
May 18, 2012 | Office Equipment & Supplies
How do i bleed cooling system
FILL THE RADIATOR UNTIL COOLANT LEVEL IN RADIATOR STOP DROPPNG.WAIT 5 MINUTES CHECK COOLANT ADD MORE IF COOLANT LEVEL DROPPED ANY.WHEN COOLANT LEVEL STOP DROPPING.INSTALL THE RADIATOR CAP TO THE PRESSURE RELIEF POSITION BY INSTALLING THE CAP TO THE FULLY INSTALLED POSITION AND THE BACK OFF THE FIRST STOP, THIS WILL ALLOW ANY AIR TO ESCAPE AND WILL MINIMIZE SPILLAGE.SLIDE THE HEATER TEMPERATURE AND MODE SELECTION LEVERS TO THE MAXIMUM HEAT POSITION. START THE ENGINE AND ALLOW TO OPERATE AT FAST IDLE FOR APPROXIMATELY 3 - 4 MINUTES.WITH THE ENGINE SHUT OFF,WRAP THE RADIATOR CAP WITH A THICK CLOTH,CAREFULLY REMOVE THE CAP AND ADD COOLANT TO BRING THE COOLANT LEVEL UP TO THE FILLER NECK SEAT.NOW INSTALL THE CAP TO THE FULLY INSTALLED POSITION, THEN BACK OFF TO THE FIRST STOP AND OPERATE THE ENGINE AT FAST IDLE UNTIL THE THERMOSTAT OPENS AND THE UPPER RADIATOR HOSE IS WARM, TO CHECK THE COOLANT LEVEL SHUT THE ENGINE OFF WRAP THE CAP WITH A THICK CLOTH AND CAUTIOUSLY REMOVE THE CAP,ADD MORE COOLANT IF NECESSARY, INSTALL THE CAP TO THE FULLY INSTALLED POSITION.
Mar 24, 2011 | 1991 Ford Explorer
Se puede resetear el contador de los tambores de la oki c3400n
Trata esto:
When installing the C3400n printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result. Note: (Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
          0.408?openelement&fieldelemformat=gif
    >> Insure the toner is fully locked, see photo below showing the correct and incorrect positions of the locked toner cartridge.
CORRECT (Fully rotated to lock position)
    91.28a2?openelement&fieldelemformat=gif
INCORRECT (Not fully rotated to lock position)
179.32a2?openelement&fieldelemformat=gif
Dec 01, 2010 | OKI C3400n Laser Printer
2001 Sable gets P0401 first, then gets P0442 some miles later. When P0442 sets, so does engine check light. Car runs well. What could cause this sequence of error codes?
This could be a small evaporative system leak. Check the gas cap to be installed fully. If fully installed may need replaced.
Oct 14, 2009 | 2001 Mercury Sable
Keep getting a blank screen and a pop up say system not fully installed
easy, you just have to install the OS again..
u can reinstall it through booting OS CD, maybe some OS instalation files are missing or corrupted.
or if you have the recovery CD from the hp vendor, just install it
May 30, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Can't use camera w/new dell XPS 410 pc-wont fully install from disc
what operating system Vista? Remove the software and iplug camera in- Computer should recoginse it and put up Scanner/Camera Wizard
Jan 02, 2007 | Canon PowerShot A70 Digital Camera
27 people viewed this question
Seeker5211
Seeker5211
