Question about Leviton N3008-00D 3000 Series DMX Controller, 8 Channels -
Hello, I have a Leviton N3008-00D 8ch. DMX Console. The DMX chip "U2" is fried. It is an 8 pin dip and I cannot read the part number. Anybody know what the part number is for this IC? Thanks!
  • K.N. Nov 14, 2014
    I was able to read the part number through the burned top of the IC using a jewelers Loupe. The part number is SN75176BP. This is the RS-422/RS-485 8 pin driver chip.
    Thanks
I have four 200b lights that i must have connected to a wrong device and all 4 blew fuses. I replaced the fuses but they continue to blow as soon as I plug them in.Any suggestions would greatly appreciate.
first need to know if the other device you connected it is with dmx and if not, the most likely need replacement on the circuit 8 pin controller dmx its easy to know the locate its the circuit most close to the input signal, I hope you test the input volt regulators and are well, if not also need more data presents fault.
Feb 16, 2013 | Chauvet (2) Chauvet Ledsplash 200b Dmx...
Aei music prodisc/ds play and remix lights flash but no sound
DMX Music prodisc systems. I own one. I have had multiple errors, what sequence do the diodes flash in, is it green-orange-green-orange, or do they both flash at the same time? One at a time means a stuck cd drawer, and two together is "Generic Error 000x80x87. Try a DMX lens cleaner through the system. If you do not have one of those spare, look at the back of the player, you will see DIP Switches, flip the 1st one up and you may play normal cds, try a generic lens cleaner though it, if it doesnt work, try contacting Mood Media (The new name for DMX Music)
Oct 30, 2011 | Nintendo DS Lite Console
D4dmx-md5 stop working. No schematic. Problem came slowly then it stop working. Get a bit of light on the led display Maybe a power supply problem
You did not post enough information on symptoms to get a good answer. However, the most common problem with these dimmer packs is a failure of the sermiconductor that controls the amount of power going out to the attached light. In the D4DMX, there are 4 such, of a type class of semiconductors known as "triac", part industry part BT16A (the "A" is important, as it indicates an internally insulated mounting/heatsink tab). When this part fails, the output channel stops working, but the other 3 channels continue to work. Altho rarer, it is possible for multiple channel triacs to fail. The failure of a triac is typically due to (1) attached bulb filament failure (in a manner where a filament fragment shorts across the mounting posts), (2) channel overload (eg, plugging in a greater load (significantly greater wattage) than the D4DMX channel is rated for), (3) AC power line surge. You need to be a trained & experienced ELECTRONICS (ie, NOT electrician) to accomplish this repair safely & satisfactorily, and it involves soldering & specialized test equipment.
The D4DMX series is also known for failures of its control cable interface circuitry, both for Microplex and DMX. Microplex failures is more common, as that type of interface is more sensitive to induced noise from nearby AC wiring, radio signals, and standing wave reflections from varying lengths of control cabling. DMX uses a differential control signal interface, which makes it much more immune to induced noise, but it operates at a lower signal voltage which makes it more sensitive to accidental application of improper voltages on the control cable...which often happens when someone connects the DMX ports on the dimmer pack to a Microplex connector on another pack or the control console. One clue is to look at the single tiny LED right next to the control cable connectors; if it's lit green, then the Microplex signal is detected, if it's lit red the DMX signal is detected, if it's not lit at all (off) then no signal is detected which just may be an interface circuit failure. Such problems are a bit more challenging to troubleshoot internally, and requires a proper oscilloscope or logic analyzer.
In both of the above cases, you will see what may look normal on the LED display, but the dimmer pack will not function properly.
You should describe more symptoms of your problem, such as: Are all light output channels not working, or just 1 or 2? Which control interface are your using (Microplex or DMX)? What is your LED display saying? What are the present settings programmed into your D4DMX? Are any other working channels responding to the control console normally? What is the total length your control cables, including those between serial connected ("daisy-chained") multiple D4DMX dimmer packs? Do you have any non-D4DMX dimmers in the control chain, and are they all connected using the same type of control interface (Microplex or DMX)?
May 23, 2011 | Leviton D4DMX-MD5 4-Channel Programmable...
Using 24 chauvet par 56 led and chauvet obey 40. when going to bank 5, 6 or even 11, some fixtures will remain on while some will flicker. 2 fixtures per channel on the console. DMX addess starting at 1...
Read about terminating the chain with a resistor 120 ohms. If your run has appreciable length, a termination MAY be necessary to avoid digital reflections that can corrupt the message between the control and the lights. Having separate power sources CAN subject the units to "ground bounce" that can also corrupt the digital control. You need to power all the units from a single source or conditioner if possible. Another solution might be to use one of the DMX radio links which would isolate the ground problem. Another fix you MIGHT try is to get some of the clamsheel ferrite devices that clamp around the wires. Put these around the digital cables, not the power cords:
http://www.google.com/products/catalog?hl=en&sugexp=ldymls&xhr=t&q=ferrite+core&cp=8&bav=on.2,or.r_gc.r_pw.&wrapid=tljp1304006132890014&um=1&ie=UTF-8&cid=761843538070174409&sa=X&ei=-Y25TaXFGsjYiALh_8ky&sqi=2&ved=0CFEQ8wIwAw#
Apr 28, 2011 | Chauvet (4) Chauvet Led Par 56-24c 7...
How can I program my Leviton timer model 6651-I?
Leviton 6651 Manual.
http://waterheatertimer.org/pdf/Leviton-6651-manual.pdf
Timer requires a battery which should be replaced each 12 to 18 months.
Timer replaces single-pole or 3-way switch, and does not need a separate neutral wire.
Timer is for incandescent lights only.
500 Watt capacity
Push the door for manual override to reverse program that is in effect.
The 14 hour timing period is represented by 24 dip switches.
Each dip switch is positioned for ON or OFF.
Click the dip switch right or left
Start at the bottom
For example: ON for 3 hours, OFF for 4 hours, ON again for 3 hours:
Click dip switches 1 thru 3 to ON position, 4 thru 7 to OFF position, 8 thru 10 to ON position
ON position is to the right.
OFF position is to the left.
At the end of the 14 hour program, the timer turns lights OFF until the original start time is reached after 24 hours.
Timer will operate like this while in AUTO mode, until function switch is moved from AUTO to MAN or OFF modes.
Function switch is located at very bottom of timer door.
To activate program (on first day), function switch is set to OFF position for 2 seconds, and then move function switch to AUTO mode, and programming cycle begins.
Nov 11, 2010 | Solar Leviton 6651 Decora Programmable...
Dont know wii pin or secret question answer, any
1. Turn on your Wii console and go into the Wii Options Menu
2. Click on Wii Settings and click the right arrow until you see “Parental Controls”
3. Say “Yes” to “Change Parental Controls?”
4. Click on “I forgot” when it asks you to enter your pin
5. It will ask you for your secret question, click on “I forgot” again
6. The screen will read “If you have forgotten both your PIN and secret question, call the consumer service number listed in the Wii Operations Manual and provide the confirmation number below. You will be issued a master key.”
7. Call Nintendo at 1-800-255-3700 and give them the confirmation code listed on the screen. They will give you a new Master key to enter on the next screen.
8. The PIN is now reset/disabled
Nov 25, 2009 | Nintendo Wii Console
Don't know how to find code
You should have a tech number to Leviton on your instalation instruction.
May 09, 2009 | Electrical Supplies
Sony cdx m800 head unit
If it is the security code you are looking for, try these solutions. See how you get on. Solutions that have been tagged as workers... try the soft fix first, then if your game,the 4 blob trick... dunno bout that one??
http://www.fixya.com/support/t225385-sony_cdx_m800_code
 I recall changing out the 8 pin eeprom chip where the security code was stored on Sony and Pioneer Head units where customers had forgotten their code when the units were brought in for service, so  you start with a fresh code. That was a few years back but:).
Will have an 8 pin dip chip as detailed in this post if thats the case for this unit. You may need to supply your Identification toSony to order the part. This is how it used to be,and it may be doable only at a sony agent, this being a security part for the unit. Let me know howyouget on.
regards robotek .
Jan 29, 2009 | Sony CDX-M800 CD Player
Leviton N3008-00D 3000 Series DMX Controller, 8 Channels - Logo
686 people viewed this question
Top Leviton Photography Experts
pontelemon
pontelemon
Tony
Are you a Leviton Photography Expert? Answer questions, earn points and help others
