Question about Comfort Zone Heating & Cooling
<!-- from fixya rte -->How many amperes does a cz1500wo require? - Comfort Zone Heating & Cooling
    Novelist:
  • 170 Answers
Need starting ampere load and running amperes
The inverter would have to be motor rated as the starting torque is much higher than the running watts required. Starting at 240v is around 5 amps, running about 2a at most.
Mar 30, 2014 | Freezers
My monitor doesn't have an adapter. It says 12 vDC but I don't know the amperes or mA it requires, What do I do?
moz-screenshot-7.pngHi
The supply would be 12v DC 1000mA you can even go little more in amperes like 1500mA also not a problem.
DO RATE MY SOLUTION
Jun 30, 2011 | Daewoo F227B Monitor
Hi power supply whent pop. PC worked on battery for 20 mins. got new power supply but will not charge. Is there any voltage protection inside and how do I get inside My Eeee900
It is very important to check the power output produced by the ac adapter. Make sure that the output voltage and ampere of the new power supply is the same with the original power supply provided with the laptop. The new power supply you purchased may be producing lower or higher ampere than the required power to turn on the unit and charge the battery.
I suggest to purchase ASUS Eee recommended power supply or ac adapter for your laptop before it gets damage by incorrect power voltage or ampere used.
May 06, 2011 | ASUS Eee 4G Notebook
What size breaker does the sm-11 require 2-30amp or 2-60 amp?
You will need the 2-60A breakers. 11kw is 11,000 watts. Watts = voltage X Current (amperes) If we take this formula and change it around to calculate amperes it is like this. Amperes = watts / volts amperes = 11000 watts / 240 volts This is 45.8 amperes or let us say 46 amperes. The closest breaker that you have would be a 50 amp breaker 2 pole of course . 2 - 50. If you cannot get a 2 - 50 then a 2-60 is fine. I would run with a #6 copper wire, I would check with local code to verify the wire size in your area. Make sure that the unit is grounded as well. Minimum of a #10 wire, I would also check local codes as well. Enjoy the steam!
Dec 27, 2010 | Steamist 11 KW Steam Unit SM11IM
I own 2 of these heaters and on both at the plug-in they have melted where they get so hot. Is there a re-call on this product or are they being repaired?
Measure your supply voltage to ensure you are getting the required voltage to this device. Extension cords and lose wires in the wall plug outlets can be your culprit! Low voltage increases amperes draw and vice versa. Low ampers will increase voltage draw. Goodluck!
Oct 07, 2010 | DeLonghi EWO507 Oil Filled Radiator Heater
I need the size or model number for a replacement charger for the gateway solo 9550.
Compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
Aug 30, 2010 | Gateway Solo 9550 Notebook
My netbook power cord is no longer working. the netbook charges fine on my labtop cord. will this cause any problems to the netbook?
Not at all. Especially if the power adapter is providing enough power to both run the netbook & charge the battery. A very good way to do this is to compare your netbook voltage & ampere requirements (written on a sticker on the bottom of the netbook) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the netbook's voltage rating. Amperage of the power adapter should be at least equal to or greater than the netbook's rating. It should never be less than the netbook's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
Aug 24, 2010 | Toshiba Computers & Internet
My gpx MW249s 2gb mp3 player keep saying error everytime i put a new battery in it. But everytime i put a old battery in it, it workS what can i do
Check the voltage and ampere output of the old battery. Make sure that the new battery that you're trying to put in has the same voltage and ampere output.
There's a possibility that some components of your mp3 player requires a specific amount of voltage / ampere out.
However, if you're putting a new battery with the same exact output, then you may need to verify it with the manufacturer. Because, this will be the first time I heard that an electronic device will give an error after replacing the battery.
Thank you and good luck!
Apr 11, 2010 | GPX Audio Players & Recorders
Kitchenaid oven model #KEBC207
this was taken from the installation guide
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kebc207&siteCd=WHRCOM#installation_instructions
Oven must be connected to the proper electrical
voltage and frequency as specified on the
model/serial rating plate. (The model/serial rating
plate is located on the oven door or on the oven
frame.)
Models rated from 7.3 to 9.6 kW at 240 volts
(5.5 to 7.2 kW at 208 volts) require a separate
40-ampere circuit. Models rated at 7.2 kW and
below at 240 volts (5.4 kW and below at 208
volts) require a separate 30-ampere circuit
Nov 15, 2008 | KitchenAid KEBC207 Electric Double Oven
What kind of fuse do i use for the radio on my 1988 camaro?
Most car stereos/headunits uses a glass type fuse. the ampere rating would depend on the power of the stereo. Most would do with a 5~7 ampere fuses but several high end/ high power would require 10 or more.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 27, 2008 | Chevrolet Camaro Cars & Trucks
Heating & Cooling Logo
59 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
