Why my Coaire ac/heat unit will not heat - Heating & Cooling
No it don't turn to heat mode it use to
Posted on Aug 30, 2015
  • 101 Answers
Is it electric heat? does it turn to heat mode?
Posted on Nov 26, 2014
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
Hi, warning light on the central display of the indoor unit Coair A/c mini split blinks continuously, and unit does not respond to on/off. What is the reason and how to solve this problem
Try unplugging for 30 minutes and plugging back in. Make sure remote has fresh batteries, make sure timer setting for proper time is accurate. A power source running nearby may cause this unit to malfunction. If you don't have auto start, all you should have to do is press the remote 'on' button once power is restored. Here is a link to your manual. http://media.hydroponics.net/item-documents/coaire/coaire_UserGuide-1.pdf
Apr 02, 2015 | Heating & Cooling
Mini split problems
One check your indoor fan is correctly running ( blowing a good quantity of air. Two look for oily residue around flare connectors indoor and outdoor usually indoor first. This indicates a leak. Thus why the ice . Good luck
Nov 27, 2013 | Heating & Cooling
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
Jun 21, 2009 | Goodman Heating & Cooling
Ac dose not work, but heat works
If the condensor fan is not functioning no latent heat will be removed and no cooling of refrigerant,
Subcooling needs to be completed get an Ac engineer to change the fan unit.
May 20, 2009 | Heating & Cooling
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
