Question about Tablets & eReaders
My button on my tablet is loose and broken - Tablets & eReaders
  • Tablets & eR... Master
  • 5,631 Answers
Take it to an authorized repair service
Posted on Nov 13, 2014
How do i reboot my android tablet when the on and off button is broken
replace the on/off button and it will reboot no problems
Jul 05, 2017 | Tablets & eReaders
I CANNOT CHARGE THE TABLET THRU EITHER PORT- THE REGULAR CHARGING PORT OR THE USB PORT THAT I FOUND ALSO CHARGES IT. WHAT COULD BE WRONG AND WHAT ARE POSSIBLE SOLUTIONS?
could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
Jun 29, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
Power button missing
Usually there is a pc. of plastic that appears to be a power button but inside of the case there will be an actual button connected to wires that is pushed when you push the button outside of the case. Should be able to use a toothpick to push in on the little circle u see inside of the case. If not you can remove the cover and order the part that is broken.
http://www.androidtablets.net/forum/wondermedia-based/12092-android-2-2-via-chipset-7inch-epad-mid-power-button-not-working.html this person dropped theirs and the wires came loose inside of the case.
Jun 14, 2014 | ZEEPAD MID Android Tablet 7 Inch WiFi
Wont charge or turn on
it is a very highly chance your charging port is broken on the inside or is loose but if you know the tablet still has some charge left in it you can try holding down the power button for 20-30 seconds and see if it turns on.
Nov 12, 2013 | Samsung Tablets & eReaders
My charging port is broken or loose can't charge it . What are my options?
have you tried any other cables i have had problems with loose cable connections that were fixed by a new cable
Sep 08, 2013 | Craig CMP741d Tablet
How do I replace a broken power button on Zeepad 7.0
I couldn't find anyone selling the buttons so I just made mines by melting down plastic and rubber to the shape of the slot.
Jan 18, 2013 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Sep 03, 2009 | Gateway m1300-3004372 Tablet PC
Fixint the swivel hinge
The following website should help you out - if the problem is just a loose hinge.  Maybe you've already seen this webpage, but here it is again anyway.
http://www.insidemylaptop.com/tighten-loose-display-hinges-toshiba-tecra-m4-satellite-r15-tablet-pc/
Your problem may be just a couplI used the directions to take off my screen and then found out my hinge was broken.
Good Luck
Apr 30, 2009 | Toshiba Satellite R15-S822 Tablet PC
Tablets & eReaders Logo
23 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
